oil weight - Hyundai Genesis Forum
  • 1 Post By -fritz-
post #1 of 19 Old 09-20-2019 Thread Starter
gen10-38's Avatar
Quoted: 38 Post(s)
oil weight
I moved to a hotter area (Phoenix) where the temperatures are slightly higher than before (believe it ranges from 40-120 F here). I have a 3.8 bk1 and wondering if I should switch oil weight to something thicker. Currently using a full synthetic 5w-20 per the manual. Am wondering if this is too thin for this kind of heat. This is for a stock gen.
2010 Genesis Coupe GT 3.8 Auto
gen10-38 is offline
post #2 of 19 Old 09-20-2019
Quoted: 127 Post(s)
I would go up to 5w30 or 5w40.
Genesis306 is offline
post #3 of 19 Old 09-20-2019
Quoted: 248 Post(s)
I run 5W30 synthetic in my 14 3.8 coupe and my 4 other vehicles here in vegas and have never had a problem.
lvdukerider is offline
post #4 of 19 Old 09-22-2019
2012 Gen. 3.8 Track w/ZF
-fritz-'s Avatar
Quoted: 86 Post(s)
I live in Vegas...same weather as Phoenix. I have always used full synth 5W20. No problems in 105,000 miles because of it.
Red Raspberry likes this.
Gencoupe Wings emblems.
Quad exhaust tips.
-fritz- is offline
post #5 of 19 Old 09-23-2019
NOOB
Thraxbert's Avatar
Quoted: 42 Post(s)
The manual recommends 5W30 for your temperature range. I'd stick with it. There are some really great oils out there that aren't often mentioned on here:
5W30 Amsoil Signature Series has incredible wear protection and temperature tolerance. Pretty affordable.
5W30 Renewable Lubricants SHPPV Bio-SynXtra has great wear protection. Also biodegradable. Ever wanted to run on vegetables?
5W30 Valvoline Full Synthetic High Mileage with MaxLife Technology (API SN/GM dexos 1 in silver bottle). Cheap and widely available! You can buy it at Walmart if you want.
2013 Grand Touring 3.8: 3p8p True CAI | ISR Single Exit | 3p8p Manifold Riser | TROS Potent Boster 2 | 3p8p Engine Leash | Saikou Michi | Klutch KM20 | Whiteline Sways | Parts Shop MAX Comp Coilovers | Moog & Powergrid Links | Brembo Swap | Android Auto
Thraxbert is offline
post #6 of 19 Old 09-24-2019 Thread Starter
gen10-38's Avatar
Quoted: 38 Post(s)
I thought the manual says 5w-20. I'll take a closer look to see if it's 5w-30 for higher temp climate. I hate to deviate from what the manual calls for... im just nutty like that...
Good inputs.
gen10-38 is offline
post #7 of 19 Old 09-24-2019
Gaijinn's Avatar
Quoted: 240 Post(s)
If your really concerned, even el cheapo crap oil will do well,.....with an oil cooler. Changed frequently.
Here we go again !
Gaijinn is offline
post #8 of 19 Old 09-24-2019
dagreekgencoupe's Avatar
Quoted: 80 Post(s)
On a BK1 you can use either 5w20 or 5w30. Going with the extra viscosity of a 5w30 will only help. Now if you had a BK2 with that God aweful invention of GDI that dilutes oil and kills it's usefulness, I would say 5W30 all they way.
2010 2.0T Premium 6 Speed M/T
SFR Stage 1 Tune 93 Octane
Homemade SRI
Homemade single exit exhaust
Megan Racing Tranny Mount
Actuator arm baseline adjustment, needed 3 whole turns
Injen Intercoolers Pipes
Turbo Boost Gauge
HID Headlight Conversion Kit
Red LEDs in Dash, Center Display, HVAC Controls, Steering Wheel Controls and Window Switches
Spyder LED Taillights
Rear Lip Spoiler
dagreekgencoupe is offline
post #9 of 19 Old 09-26-2019
Quoted: 42 Post(s)
Damn and I'm running 5w50 in 2.0bk1, guess will need to switch for winter to something not as viscous.
Pchelka is online now
post #10 of 19 Old 09-27-2019
Quoted: 80 Post(s)
You're running 5w20 on a 2.0 BK1? There was a bulletin quite a few years ago that recommends 5w40 for high performance driving. If you aren't hard on the car, then you can go with 5w30.
Homemade SRI
Turbo Boost Gauge
Rear Lip Spoiler
post #11 of 19 Old 10-01-2019
Quoted: 42 Post(s)
I'm running 5w50, may switch to something thinner for the winter like 0w30 or 0w40 as we get sub freezing temps here
post #12 of 19 Old 10-03-2019
Quoted: 80 Post(s)
Sorry, got old man eyes. LOL!!!!
Homemade SRI
Turbo Boost Gauge
Rear Lip Spoiler
post #13 of 19 Old 10-04-2019
-fritz-'s Avatar
Quoted: 86 Post(s)
When I had my 2006 3.5 Altima I used German made Fully Synth. 0w30 Castrol for 100,000 miles. Never a problem! I regularly changed it at 4500 miles.
Quad exhaust tips.
-fritz- is offline
post #14 of 19 Old 10-05-2019
Quoted: 42 Post(s)
In my case its just for winter, normally we get -10C (14F) and extreme cases up to -30C (-22F), so easier flowing oil is welcomed for these cold starts i.e 0w30 or 0w40. Trade of is highway driving as i often sit 4-5k rpm in 5th or more for prolonged time on highway so for that type of driving w50 is simply safer
post #15 of 19 Old 10-05-2019
Quoted: 52 Post(s)
I think you guys are mistaken on what the w30/40/50 means. If you constantly do spirited driving or have direct injection then yes, I'd recommend W30 or W40 for the summer. But in the winter does the oil ever even get close to 350 degrees that would make it start breaking down and increase wear? If not then what's the point of getting a heavier weight? It'll just cause more wear on warmup. API Oil lubricates and protects 98% similarly. That 1 or 2 percent you think your saving by going heavier is more likely to kill your oil pump and then your engine than using a lighter weight oil. Heck, Japan will likely have 0W8 and 0W16 oils soon. The lower the number the faster the oil can circulate on startup. And as we all know, most engine wear is from cold starts, not mid/high rpm driving unless you're constantly at the redline.
JOutterbridge is offline
post #16 of 19 Old 10-05-2019
Quoted: 52 Post(s)
Sorry about that rant. My point is I see too many GC owners blowing 3.8 NON TURBO engines and destroying bearings due to failed oil pumps and having the wrong oil for the climate. A 3.8 should almost never die unless you really screw something up or have a bad tune with bad gas. The desert and very deep south excluded, I'd always go OEM so you dont get declined warranties. This excludes track drivers obviously
post #17 of 19 Old 10-06-2019
Quoted: 42 Post(s)
This is why for the winter I'm switching to 0w40 or 0w30, just need to watch constant high load rpms on highway. But for summer and hard driving its 5w50
post #18 of 19 Old 10-06-2019
Quoted: 248 Post(s)
The cap on my 2014 3.8 says 5W30, as well as on my other five cars so thats what i use year round, and im in the desert. Ive owned and been responsible for many different vehicles for over 50 years,i was responsible for and worked on a fleet of rental cars for eight years. Ive never experienced a oil related failure as long at its changed at some reasonable interval and isn't run without oil, such as a hole in a oil pan. I dont think i know more than the engineers that choose the oil spec for my vehicles. Im not going to give the dealer a easy way to decline a warranty repair, if i ever have one, by deviating from the manufacturers recommended oil specification. I get this may not apply to competition or some highly modified vehicles but does for most applications and situations. Just my personal experience FWIW.
post #19 of 19 Old 10-06-2019
Quoted: 42 Post(s)
hehe ... my car is copart car transported over the pond to eastern europe - warranty is a word that doesn't literally exists here so i don't relay care.
