Power windows hard bottoming - Hyundai Genesis Forum
post #1 of 35 Old 08-05-2018 Thread Starter
Both my power windows have developed the hard bottoming. I can reset the limits per the manual and it works for a couple days. Then back to the clunk when it hits bottom. I have only reset from the drivers windows switch FWIW.
Here's the procedure.
If the power window is not operated correctly, the automatic power window system must be reset as follows:
1. Turn the ignition switch to the ON position.
2. Open the window fully by manual down (press the front portion of the switch to the first detention position.).
3. Turn the ignition switch to the OFF position and to the ON position again within 2 seconds.
4. Press the front portion of the switch 3 times within 5 seconds.
5. Close the window and continue pulling up on the power window switch for at least 1 second after the window is completely closed.
I see inside the door and attached to the motor is the window safety module. There is one on the passenger side too. I assume this is where the memory is stored for the stops.
I have not tried the reset using the passenger window switch. I will do this today.
But I am guessing the module is bad or has a bad connection.
Here are the wire diagrams and connector pinouts along with the interior door pictures.
post #2 of 35 Old 08-05-2018 Thread Starter
The safety module appears to be part of the window motor.
right side motor #824602M000
left side motor #824502M000
post #3 of 35 Old 08-05-2018 Thread Starter
Looking at the wire diagram the only common places for both sides are two connections on the left side of the drivers side footwell. FD11 and MF11
post #4 of 35 Old 08-05-2018
In Charge of Snacks
Odelagt's Avatar
Quoted: 207 Post(s)
Thanks for this research, Red. I'm having this issue in both windows, too
'11 3.8 R-spec
Odelagt is offline
post #5 of 35 Old 08-06-2018
LPGenCoupe's Avatar
I've had this problem on my BK1 and now my BK2 multiple times. The dealership has "fixed" it several times. I was told that the rubber "bump stops" that the regulator stops on eventually get crusty and break off, causing the "hard stop" at the bottom. Seems to me like another design corner that was cut to save money rather than using Polyurethane or something that would out last the car...
Sent from my SM-G955U using Tapatalk
LPGenCoupe is offline
post #6 of 35 Old 08-07-2018 Thread Starter
I don't believe it is mechanical wear as I again reset the windows limit three days ago. So far all is well but that is what usually happens. I'll report back when it starts the hard bottoming again. This time I did the reset for the passenger window from the passenger switch.
I find it odd that the passenger window does it too as I seldom lower that window. It does get the door opened frequently and that is the most use for the window drop.
post #7 of 35 Old 08-07-2018
LPGenCoupe's Avatar
In case you get into the door again, this is a pic of a new window regulator with the "stops" intact. I haven't personally tore into it, but this is what I was told causes the "thump". I'm sure setting the limit also has a lot to do with it also.
post #8 of 35 Old 08-07-2018 Thread Starter
Have you tried the reset procedure yourself to see if the thump goes away?
post #9 of 35 Old 08-07-2018
Chinaman_Chong's Avatar
Quoted: 38 Post(s)
Just some more info that may be relevant to solving this problem.
I had no issues with my windows till I physically removed them to install sound dampening inside the inner door panel.
After putting them back, I did get a really loud sound. I readjusted the windows, one side went completely away, the other side is noticeable quieter, but is louder than before I removed the glass.
It isnt something that has bothered me too much, as most noises will easily drown it out. So i havent actively tried to fix it too much.
I feel it is simply something that is not aligned perfectly. My next step to trouble shoot this would be to get one of those flexible snake cameras and see if I could see where it is hitting.
'13 White Satin Pearl 2.0T
SFR stage 1.5|downpipe/testpipe|custom midpipe|DynomaxVT muffler|Brembo caliper and rotor swap |OEM LSD install|Synapse BOV |R2C intake|rigid collar kit|Brembo brake caliper upgrade|dual switchbacks, fog &drl|brake led turn signal mod w/ turn signal delete|VLEDS 18w reverse LPF|custom license plate light|painted oem fogs with drl led|20% tint|gloss black vinyl roof|
Chinaman_Chong is offline
post #10 of 35 Old 08-07-2018 Thread Starter
Have you tried the reset procedure?
post #11 of 35 Old 08-07-2018
LPGenCoupe's Avatar
I haven't tried it yet. Every time I've had a problem, the dealership replaced the regulators under warranty. Now that my warranty is finally gone, I'm gonna have to try the reset when the noise comes back...it always comes back eventually...
post #12 of 35 Old 08-07-2018
Quoted: 38 Post(s)
yep, one of the first things that need to be done once the window regulator has been unplugged
post #13 of 35 Old 08-08-2018
Quoted: 235 Post(s)
Mine have always clunked a little, i just assumed thats just how they were before reading this thread, I did have to replace the battery last year, I'll give the reset procedure a try and see if the clunk goes away.
lvdukerider is offline
post #14 of 35 Old 08-11-2018 Thread Starter
4 driving days and one sitting day and the drivers side needed reset again. Passenger side was still OK.
post #15 of 35 Old 08-11-2018
LPGenCoupe's Avatar
Same here. Not sure if it even lasted 4 days...
post #16 of 35 Old 08-12-2018
In Charge of Snacks
Odelagt's Avatar
Quoted: 207 Post(s)
So, I just read the instructions again... Would it not be possible to leave the windows just a tad high from the full down position at the start of the reprogram sequence to get the system to register a higher stop point? Or perhaps the computer needs the regulator to be bottomed out/immobile to recalibrate the system... IDK, It's worth a try.
'11 3.8 R-spec
Odelagt is offline
post #17 of 35 Old 08-12-2018 Thread Starter
You could try. I think the normal way they sense the stop is current draw. If it's based on time though that idea should work.
post #18 of 35 Old 08-12-2018
In Charge of Snacks
Odelagt's Avatar
Quoted: 207 Post(s)
I had considered that, too. It's possible that the window being able to move will cancel out the maintenance mode entered by futzing with the ignition. I'll give this a try tomorrow and report back. I doubt it can hurt anything to try.
'11 3.8 R-spec
Odelagt is offline
post #19 of 35 Old 08-13-2018
IG: jasonlikedthis
mrGainZ's Avatar
Quoted: 234 Post(s)
Funny how when I see this thread that I started noticing my windows are hard bottoming lol. Looks like I'm gonna give this a try!
2014 Tsukuba Red 2.0T AT
SFR Stage 1.5 Tune
Injen SRI
Synapse Radial BOV
ISR Race CBE / TP / DP
Khartunerz CF Lower Grill
Boostec CF Lip
Carbon Creations CF Trunk
VIS VIP CF Diffuser
BC Racing Coilovers
mrGainZ is offline
post #20 of 35 Old 08-21-2018
LPGenCoupe's Avatar
Well, I've done the reset several times now...it never seems to last more than a week. There's gotta be more to it than just that memory position, on my car at least...
Power Windows Question MN_Coupe Electrical & Wiring 2008-2012 0 05-15-2013 01:35 PM
Bottoming out Coilovers matik Suspension 2008-2012 6 04-02-2013 08:56 PM
