Megan Engine and Transmission Mount Review - Page 3 - Hyundai Genesis Forum
 3Likes
post #41 of 90 Old 07-14-2013
CrownRoyal79's Avatar
Well that seals it, this will be ordered NOW!! Thanks all for the reviews, as of late I have been very skeptical of drive train mods because of horror stories, but this new mount seems to have been well engineered and thought out.
Legal Disclaimer: Anything that I or anyone else says about my vehicle on this website (www.gencoupe.com or any affiliated or non affiliated sites), pertaining to modifications and/or events, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car or real world experiences, and thus, cannot be held against me in any issue, i.e. warranty claims, that may arise.
CrownRoyal79 is offline
post #42 of 90 Old 07-14-2013
Mazukou's Avatar
Quoted: 251 Post(s)
im pretty sure i know the answer but just want to check, do you need to get the engine mounts too when you do the transmission mount? i know you can get them separate but what i mean is will there be any negative side effect to not doing both at once.
and has anyone figured out if doing this wheres on the clutch faster as teh OP asked in the original post?
2013 Gran Premio 3.8 Track M/T
Stoptech SS Brake Lines, Agency Power Clutch Line, R2C SRI, Agency Power Catback, ARK DP/TP, PBM Coilovers, BTR Tune, EBC Redstuff, UR L/W Pulleys, Ported Throttle Body, Competition Clutch, Gram Lights
Mazukou is offline
post #43 of 90 Old 07-15-2013
You got passed by a Girl.
GenisisPrincess's Avatar
I bought only the trans mount and working oh so fine
2012, 3.8 Track M/T, Bud Light Platinum Blue
Favorite vendor: GC Tuner
Mods? what mods its a chick car...don't blink
GenisisPrincess is offline
post #44 of 90 Old 08-09-2013
instroke's Avatar
Can't wait - It was suppose to arrive this week but was delayed due to "Genesis Tuners"... bad mistake in there shipping dept. As usual, should have got it from Jay, I will know for next time. Should have it installed mid-next week.
2010 Genesis Coupe 3.8 GT M/T KW
- Turbokits Turbo w/AEM meth kit
- Koyo Rad - Mishimoto hoses
- Prodigy Front lip
- M&S Type D front grill
- M&S Foglight grills
- BBM rear Spoiler
- Tein S-tech
- Grimspeed IM Spacer/P2R spacer
- MXP Catback
- Testpipes
- TWM shifter TIC bushings
- U/R Water pump/Alternator pulleys
- BC Racing ST08 19x9.5/19x8.5 25/20 offsets
- Conti DW's 275/35 245/35 - R1 Slotted Drilled rotors
- 3.9 gear LSD
Best ET 13.28 Best MPH 110
instroke is offline
post #45 of 90 Old 08-16-2013
nice review!
Dingo Wango is offline
post #46 of 90 Old 08-25-2013
Severed member
sd_davis's Avatar
Great review. Thanks!
Ordered a meagn transmission mount yesterday...
- PRW FMIC & Piping kit
- CP-E differential mounts
- K&N Typhoon SRI; Forge BOV
sd_davis is offline
post #47 of 90 Old 08-25-2013
I have the same question. If you only put the transmount it will be the only hard part of the engine-trans unit, putting most of the stress on the transmount and shortening it's life?
2011gencoupe is offline
post #48 of 90 Old 08-25-2013
Mazukou's Avatar
Quoted: 251 Post(s)
im less concerned with wearing the trans mount out, its 85 bucks, than i am the fact that the engine will still be flailing around while the transmission isnt. im worried about the clutch and gears and all the mechanical stuff inside taking a beating from everything not moving the same amount at the same time like one big chunk.
either way i need the trans mount im just trying to figure out if i have to do both or can get away with just the trans mount for now. when im turning hard or hit my brakes hard my shifter moves around because the entire trans is rolling around under the car. probably not hurting anything but makes the car look cheap and pisses off my ocd like no other lol
Mazukou is offline
post #49 of 90 Old 08-26-2013
Jedi Master
cris90's Avatar
i was thinking about this but if u go back and watching snoopys "transmission" video on youtube where he shows the internal parts, the problem straight fo factory clearing is lack of sability of internal parts vs load transfer.
In there looose state u might cause more damage, loose parts means metal to metal contact, while stiff means les vibrational movement
https://www.gencoupe.com/2-0t/94778-fuel-system-what-you-need-know.html
https://www.gencoupe.com/2-0t/86146-wastegate-101-a.html
https://www.gencoupe.com/2-0t/91199-compressor-maps-how-read-them.html
Fav. JT Quote
cris90 is offline
post #50 of 90 Old 08-27-2013
Mazukou's Avatar
Quoted: 251 Post(s)
so your saying getting the trans mount will lessen the damage if im understanding right?
Mazukou is offline
post #51 of 90 Old 08-27-2013
Jedi Master
cris90's Avatar
yes for 2 reasons 1 it'll take the weight of the bearing holding the shifter assembly
also because member have already mentioned that when they installed this the clutch chatter, random vibrating mental, went down.
So if chatter isn't benefital for the trans at least it does that much.
any damage worst case would be the input shaft coming from the engine, but i doubt it
Fav. JT Quote
cris90 is offline
post #52 of 90 Old 08-27-2013
Paps511's Avatar
Quoted: 44 Post(s)
i ordered my trany mount today along with some mt90. next up are some coils and i will be done for now
Blue 2015 Mazda 3 iSport
6sp Manual
Black 2011 2.0T R-Spec
GT3071R
392whp @ 21#
Paps511 is offline
post #53 of 90 Old 08-28-2013
Severed member
sd_davis's Avatar
Originally Posted by Paps511 View Post
i ordered my trany mount today along with some mt90. next up are some coils and i will be done for this week
There ya go; fixed it for ya!
sd_davis is offline
post #54 of 90 Old 08-28-2013
Paps511's Avatar
Quoted: 44 Post(s)
i've run out of things to buy... =(
6sp Manual
GT3071R
392whp @ 21#
Paps511 is offline
post #55 of 90 Old 08-28-2013
Function Over Form
1320drift's Avatar
Motor mounts work great. Not half as hard as it appears to install. Didn't even have to remove the steering rack. Driver side comes out if you just lift up that side a couple mm more with a bar. Should have done this a long time ago. Trans mount is a definite improvement to. The torque gets to the ground much quicker, shifting is improved and the flywheel chatters less. There is little movement transferred from the engine to the chassis while getting on and off throttle. There is more vibration felt at idle but its not much and you get used to it.
Parts Shop Max Level Up
SFR tuned
1320drift is offline
post #56 of 90 Old 08-31-2013
Can you check if the engine is sitting at the same height? Common issue with swapping out to Nismo mounts on the 240 occurred due to the fact that the same mold was used with a higher durometer rubber. In turn the weight of the engine wouldnt compress the rubber, raising the engine height..
Bart
dj_sunrise is offline
post #57 of 90 Old 10-25-2013
Klafranka's Avatar
I recently bought the transmission mount, but I cant seem to find any torque spec on the bolts. Anybody know off hand what the torque specs are on these?
  • Matte black wing emblems
  • Carbon fiber wing wheel caps
  • 20%/15% window tint
  • Custom DIY engine dress-up bolts
  • TWM STS w/ Leopard A6 Shift knob
  • R2C CAI
  • Mangnaflow exhaust
  • Megan Racing transmission, and motor mounts
  • SFR subframe rigid collar kit
  • Eibach Pro-kit springs
  • Garageline spacers 20/25
  • Agency Power clutch line
  • Saikou Michi Dual catch cans
  • 4 inch LCD Reversing Rear view Mirror Monitor, and back up camera
Klafranka is offline
post #58 of 90 Old 10-25-2013
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 91 Post(s)
Snoopy0812 is offline
post #59 of 90 Old 10-26-2013
Jedi Master
cris90's Avatar
can't wait to get this and the moto mount, shipping mistake, they sent me the motor mounts wihout the transmount so waiting for that to arrive
Fav. JT Quote
cris90 is offline
post #60 of 90 Old 10-27-2013
Klafranka's Avatar
Originally Posted by Snoopy0812 View Post
36.2 ~ 47lb-ft
Thank you sir. Greatly appreciated.
  • R2C CAI
DIY polyurethane transmission mount gunluvS14 Engine and Drivetrain 80 03-16-2017 09:59 AM
2.0T Motor Mounts and Transmission Mount MN_Coupe Want to Buy 2 04-19-2013 11:30 AM
GROUP BUY: Megan Racing Transmission Mount Kyoshiro Engine 122 04-03-2013 03:12 PM
Megan Racing trans mount review Jmichetti 2.0T Discussion 2008-2012 5 02-09-2013 01:23 PM
Transmission mount bourré, quelqu'un d'autre l'a fait? Gymkhana Québec 17 06-08-2012 08:44 AM
