BTR Stage 2 Custom Tune - Page 2 - Hyundai Genesis Forum
post #21 of 40 Old 01-08-2014
BoostedCoupe11's Avatar
I will be going BTR once I have all the supporting mods. Great review man
90 Eclipse GSX Fully built sold
2003 IS300 Sport Design sold
2005 Tacoma TRD Offroad 4x4 sold
2013 2.0T R Spec
-R2C
-Synapse
-Depo Racing
-Diode Dynamics
BoostedCoupe11 is offline
post #22 of 40 Old 01-14-2014
sjmcdo3's Avatar
BTR,
What is the idea behind Stage 3? Turbo swap? Which Turbo were u guys thinking?
2013 Genesis 2.0T R-Spec Black
13.813 @ 102.09 (.5 tune)
Mods:
  • SFR 1.5 Stage Tuned ECU
  • Injen SRI (Black)
  • ISIS DP & TP
  • Magnaflow 3" CBE (16478) Quad Tip
  • NGK 2309 Plugs
  • Prosport EVO Boost, Oil Temp, and Wideband
  • TurboXS H-RFL BOV
  • R1 Premium Rotors
sjmcdo3 is offline
post #23 of 40 Old 01-14-2014
Bill@BTRcc's Avatar
Originally Posted by sjmcdo3 View Post
BTR,
We have not made a final decision on hardware. It will be a significant jump in power though.
post #24 of 40 Old 01-14-2014
bayousnail's Avatar
With a "significant power jump" any idea if we are lookin at internals yet?
bayousnail is offline
post #25 of 40 Old 01-20-2014
sjmcdo3's Avatar
^ We won't know this until after long term testing I believe....
Bill?
Mods:
  • Injen SRI (Black)
  • ISIS DP & TP
  • NGK 2309 Plugs
  • TurboXS H-RFL BOV
  • R1 Premium Rotors
sjmcdo3 is offline
post #26 of 40 Old 01-27-2014
Agreed
Wsrisinger is offline
post #27 of 40 Old 02-18-2014
sjmcdo3's Avatar
sub'd
sjmcdo3 is offline
post #28 of 40 Old 02-26-2014
sjmcdo3's Avatar
How much boost is used for BTR Stage 2?
Mods:
  • Injen SRI (Black)
  • ISIS DP & TP
  • NGK 2309 Plugs
  • TurboXS H-RFL BOV
  • R1 Premium Rotors
sjmcdo3 is offline
post #29 of 40 Old 02-26-2014
I believe its in the high 20s
Engine:
BTR Stage 2 Dyno Tuned (302WHP/355WTQ)
Beyond Redline Exceladyne CBE.
Auto Select Tuning Divided Racepipe/02 Housing and Downpipe.
R2C Intake.
Snapse Eng. BOV.
Exterior/Lighting:
3M 1080 Series Metallic Matte Blue Wrap
Diode Dynamics 6000k HIDS
DD Stage 2 Switchbacks
DD Stage 3 License Plate/Dome Lights
Suspension/Wheels:
Megan Coilovers
Incurve IC-S5 F: 20x9+20 R: 20x10.5+25
Need help wrapping parts or have questions on the process? PM me and I will help you!
muhaha is offline
post #30 of 40 Old 02-26-2014
Quoted: 14 Post(s)
my logs showed peak 21.8
is it ok, or should I search for boost leak? :/
I only have O2 housing and downpipe.
NODO-GT is offline
post #31 of 40 Old 02-26-2014
Pretty sure its not in the high 20's. I dont know for sure but Im guessing 22psi or so. I think water/meth injection is needed to get much higher.
2013 2.0T R Spec
-R2C
-Synapse
-Depo Racing
-Diode Dynamics
post #32 of 40 Old 02-26-2014
Ahh meth! I remember seeing a coupe with 27-28lbs but he may of had a meth kit!
Engine:
R2C Intake.
Snapse Eng. BOV.
Exterior/Lighting:
Suspension/Wheels:
Megan Coilovers
muhaha is offline
post #33 of 40 Old 05-07-2014
Just had to chime in real quick as I just installed my BTR S2 canned last night, first impressions are holy crap! car is MEAN! Got the S2 ECU straight from korea about 3 weeks after ordering which I thought was pretty cool considering the theft issues and all, I am currently working on installing wideband and boost/oil gauges so I can monitor things. This may be a stupid question as I haven't had much time to drive since S2, how do I get the launch control to work? I was also wondering at what point would BTR recommend an injector upgrade for my setup?
Also SUB for info on possible S3/S4 upgrades and ETA!!!
BTR FTW
Injen CAI
TXS FMIC
Tial Q 50mm BOV
Autoshin o2
TXS RP
Solo CBE
BTR S2
PSM Pro Coilovers
TS STS & bushings
ProSport EVO Boost, AFR, Oil Temp gauges
Vossen CV3R 20x10.5 R 20x9 F
Irish13GCR is offline
post #34 of 40 Old 12-01-2014
ThE DuDe
R=SPEC_T's Avatar
Quoted: 51 Post(s)
man im really glad ive read all these btr vs sfr tune reviews. enough said
R=SPEC_T is offline
post #35 of 40 Old 12-16-2014
I've got a question about the stage 2 tune that I didn't see answered anywhere. Since the tune turns off some gauges, what all do I need to install/do to get some working gauges? Not really comfortable with driving around with no info. Thanks
gambi is offline
post #36 of 40 Old 12-16-2014
Jzen16's Avatar
Quoted: 43 Post(s)
it doesn't turn the gauges off ^^
it simply means the stock boost gauge is no longer functional since it can't read higher than 15 psi
2014 Casablanca White R-Spec 2.0t
Injen SRI
ISIS tbe
HKS bov
BTR Stage 2
Niche Targa 19x8.5/10
Eibach Sportlines
Jzen16 is offline
post #37 of 40 Old 12-16-2014
That means our stock gauge isn't ever functional, since we push over 15 psi stock... Ok well thats not too bad then.
gambi is offline
post #38 of 40 Old 12-17-2014
mdelement88's Avatar
Quoted: 126 Post(s)
BTR FTW
For the launch control, hold your traction button down until everything is turned off. Then just throw it in gear, depress the clutch, brake and gas and have some fun!! As far as upgrading injectors, don't worry about it. The stock ones can handle plenty, even if you upgrade the turbo.
2013 rspec * 6 speedo * ATP GT3076R *
mdelement88 is offline
post #39 of 40 Old 06-14-2016
Super excited to get a tune from BTR as everything I have read is really positive. Just wondering if the stage 2 tune still makes for a good daily driver.
Zeddgc is offline
post #40 of 40 Old 02-09-2018
GeneRS's Avatar
Why is this tread call BTR stage 2 Custom Tune as i understand from the OP he got a custom tune at an event a btr stage 2 tune is something you order from their website this brings a lot of confusion to anyone looking for info
GeneRS is offline
Sfr tune vs btr tune packattack 2.0T Discussion 2013 and up 193 04-10-2017 02:34 PM
SFR stage 1 custom tune with results! meangreenchevy 2.0T Discussion 2013 and up 33 07-24-2013 03:06 PM
18g turbo + BTR Stage 3 tune 2K11G3N 2.0T Discussion 2008-2012 4 06-08-2013 09:01 AM
BTR Custom Tune CHICAGO matik 3.8 V6 Discussion 2008-2012 0 12-02-2012 11:47 AM
