PTP Turbo blanket Review - Page 2 - Hyundai Genesis Forum
post #21 of 37 Old 09-08-2010
Uber Member
stevie's Avatar
Originally Posted by 1sty View Post
Same exact mark on my heat shield.
I am concerned by a product like this though.
Wouldn't something like this lead to premature turbo failure as it essentially cooks the turbo in its own heat which should be allowed to dissipate?
I would think this would cause the oil/coolant of the car to also increase in temperature as the turbo heat has no other place to go.
Pure speculation of coarse. hopefully someone with an oil temp gauge can tell us what they find before and after this install.
having some more info on this would be amazing because im wondering the same thing
2010 2.0T Base A/T
BR 91 Octane Reflash
Glowshift Boost Gauge
AEM CAI
M&S Carat Type-D Front Grill
Exceladyne Catback Exhaust
Enkei Raijin 18x8 +40, 18x8.5 +38
BFGoodrich GForce Sport Comp 2 235/45/18, 255/45/18
Waiting to be installed:
Stoptech SS Brake Lines
Hawk HPS Pads
stevie is offline
post #22 of 37 Old 09-08-2010
Sex Machine
Spool2Go's Avatar
Originally Posted by Mcmonopoly View Post
Are you getting CEL's with the DP? I was looking at getting one but with a Hi-Flow cat also.
Never had a CEL whatsoever with the hi-flow cat. But then again I have a custom tune on my car because the a/f ratio changes when u get rid of the stock emissions stuff.
Genesis Coupe 2.0T GT MIRABEAU BLUE
BR Reflash w/custom tune|DW 550cc Injectors|CP-E Downpipe w/Hi-Flow Cat & 3" Mid-Pipe|Depo Racing FMIC|G&M SRI|HKS BOV w/Block-off plate|NRG Ground Wire Kit|PTP Turbo Blanket|Eibach Sportlines|R1 Drilled/Slotted Rotors|SS Brake/Clutch Lines|Frixa Brake Pads|19" Bronze 5Axis S5:F Rims|Meaty Continental Tires|ACT Clutch w/ Fidanza Flywheel|
Dynoed 262whp & 282wtq @ 17psi on the Mustang Dyno
Spool2Go is offline
post #23 of 37 Old 09-09-2010
Sex Machine
Spool2Go's Avatar
OK as I said here's a better pic of the wrap. It's not that pretty white wrap anymore. 1 cool note is the flange that connects the manifold to the turbo turns bright orange now when I do hard pulls. The wrap is doing its job because my intake is staying nice and cool.
u can see what part of the manifold lets out the most heat
Spool2Go is offline
post #24 of 37 Old 09-09-2010
3.5L TT but wrong body
CrookedH's Avatar
I'm sure PTP has a much more in depth answer they can provide but my take on it is, since we have water and oil cooled turbos it's a non issue for the most part. If we only had oil cooled turbos it might end up baking the oil on shut down but the water cooled section, since it's still hot, will actually keep the coolant flowing slightly until the thermostat closes, keeping any oil from getting cooked in the turbo.
Heat isn't a turbo's enemy. Ambient heat / high underhood temps is an engines enemy though as the rest of the component will get heat soaked. By trapping in the heat on the turbo you're actually increasing scavenging effect since the exhaust gasses don't cool down as much, giving you better spool times and potentially increased power. By trapping that heat in you're also lowering underhood temps and saving the rest of the engine from heat soak...
CrookedH is offline
post #25 of 37 Old 09-09-2010 Thread Starter
Out Pissing Off cops!
Mcmonopoly's Avatar
Not an expert, but looking at the color change in the heat wrap, we can safely say that the cylinder nearest to the firewall is the hottest one.
When we look at the intake manifold layout and comment made by MSUGeoman, this would confirm the fact that this cylinder is in fact running lean, since from what I read, the leaner the mix, the higher the power, but also the higher the EGTs.
Again I think that the intake is being a culprit in the blown up engines...DeRost's engine had that cylinder imploded/windowed when they took the engine out.
Any thoughts?
2010 2.0T GT Genesis Coupe
|Beyond Redline-Stage 3|
wHP/Tq-TBD-Mustang Dyno
Mcmonopoly is offline
post #26 of 37 Old 09-12-2010
I got my 3" catted O2 sensor and dpfrom Ultimate Racing. Very good quality. No CEL. Very pleased. An unexpected bonus: not only the exhaust note changed for the better, (ear candy), my (butt) dyno swears by a good noticeable jump in power.
jvsantosmd is offline
post #27 of 37 Old 05-03-2011
Finally put mine on today. Thanks for the tips.
post #28 of 37 Old 05-04-2011 Thread Starter
Mcmonopoly's Avatar
Looking Good MAn!
post #29 of 37 Old 01-17-2012
Jedi Master
cris90's Avatar
any updates on the blanket after extensive use... just wondering, it's winter and was wondering would the blanket help the car warm up faster being that it's keeping th eheat in, also did anyone compare with a oil/water temp a before blanket/wrapping and after blanket/wrapping?
https://www.gencoupe.com/2-0t/94778-fuel-system-what-you-need-know.html
https://www.gencoupe.com/2-0t/86146-wastegate-101-a.html
https://www.gencoupe.com/2-0t/91199-compressor-maps-how-read-them.html
Fav. JT Quote
cris90 is offline
post #30 of 37 Old 01-17-2012
I don't drive the car in the winter. But/And I doubt if it affects oil or water temp at all.
post #31 of 37 Old 01-17-2012 Thread Starter
Mcmonopoly's Avatar
The blanket was removed form the original turbo that was on my car, but unfortunately, something attacked the outer silicone layer and it dried up and became brittle, so when I took it off it tore all over.
I think the salt got the better of it. But for the time I had it one there it was ok for the price.
Also I tried contacting PTP about this but never got a reply back.
Since I got refunded for my initial purchase because I did a review, I can't complain at all.
post #32 of 37 Old 04-30-2012
chase jones's Avatar
what would be a good manageable way to cool the manifold/turbo down? is there anything that you guys prefer or know that works really well?
chase jones is offline
post #33 of 37 Old 05-06-2014
MZ777's Avatar
Quoted: 181 Post(s)
not installing the PTP one but rather a copy from GSP.. Sure can use the tips! thanks
MZ777 is offline
post #34 of 37 Old 03-16-2019
steven riggs's Avatar
Hey, I see that this thread is pretty old but I've just recieved my turbo blanket and was hoping your post could help me with my installation. Unfortunately I can't see the pictures. It says they are blocked. Is there any way to fix this?
steven riggs is offline
post #35 of 37 Old 03-17-2019
post #36 of 37 Old 03-17-2019
Yeah that's the one picture I could see before you reposted it lol. Thanks anyways. I was hoping to see the ones where he shows which parts he is wrapping the wire around. Oh well. I'll just have to mess with it till I figure it out.
post #37 of 37 Old 03-18-2019
The wire gets wrapped around to the lower part of the blanket where the tie offs are. You can just barely see it one on the bottom right.
Turbo Blanket BigManCollins 2.0T Discussion 2013 and up 4 01-12-2018 06:56 AM
*NEW* ISIS Performance Titanium Turbo Blanket - Hyundai Genesis Coupe 2.0T Enjuku Racing Engine 0 09-12-2014 02:15 PM
Turbo blanket? Cazmir 2.0T Discussion 2013 and up 6 05-12-2014 11:37 AM
Red CX turbo blanket FS Terrance32 Engine 1 05-31-2013 03:21 PM
ARK DT-S turbo back and competition clutch stage 3 review usafcase45 Drivetrain 8 02-27-2013 09:32 AM
