HSD Coilovers - Page 2 - Hyundai Genesis Forum
post #21 of 113 Old 04-15-2012
Out Pissing Off cops!
Mcmonopoly's Avatar
Originally Posted by ByByCavalier View Post
You might be a tad lower than me.
I'll even say a smidge...The angle makes it look like your car sits a bit higher.
The rim was rubbing the very top of the inside rim lip, so have I been ~1/4" higher, it wouldn't have touched.
2010 2.0T GT Genesis Coupe
|Beyond Redline-Stage 3|
wHP/Tq-TBD-Mustang Dyno
Mcmonopoly is offline
post #22 of 113 Old 04-15-2012
1stgengen
ByByCavalier's Avatar
Maybe this one is better LOL, another fine photo by me. Yeah, I would say your about 1/4 to 1/2 inch lower than me, but not much more. I'll have to double check the space now that you mention that. I haven't had any rub yet though. I keep checking the tire surface for evidence.
One standardized US gallon of displacement compressed using 6 pistons housed in a 60 degree all aluminum V shaped block to 10.4 atmospheres injected and ejected via 24 valves and 4 camshafts. Mix part 100% organically produced air w/ part refined 91 octane liquid hydrocarbons. Expose to electricity and pressure within the energy extrapolater to produce forward thrust via a fully synchronized helical gear set coupled to a minimal slippage differentiator and rubberized traction disks.
ByByCavalier is offline
post #23 of 113 Old 04-16-2012
I maxed my front coils but left all the collars in for the front and I removed one collar from the rear.
It rides great on these even at full stiff.
I've had megans, stance, and hsd's so far (on other cars) and prefer the hsd and stance > megan.
dominic is offline
post #24 of 113 Old 04-16-2012
Mcmonopoly's Avatar
There not exactly of the same "caliber" let's just say...
post #25 of 113 Old 04-17-2012
Just fine tuned the settings on the coils and I can say they ride amazing. Love them. Sometimes I forget that I'm low to the ground and drive aggressively on bumpy roads though LOL!
tmx220 is offline
post #26 of 113 Old 04-17-2012
SomeGuyDave's Avatar
From full soft, I have mine at 8 front 6 rear. I'm also riding on 20s and 30 series tires though. On my stock 18s I had it around 12 front 9 rear. My rears are maxed with collar removed. Fronts set to match.
I also put about 30,000km on mine this winter alone and they were regularly white from all the salt. I just rinsed them off once or twice a week and I've had no issues whatsoever.
SomeGuyDave is offline
post #27 of 113 Old 04-17-2012
Mcmonopoly's Avatar
I'm running mine @ 12F/10R.
post #28 of 113 Old 04-17-2012
With what wheel/tires specs?
I find my setup to be quite comfy and I want it to be like that for my daily commute since its an hour each way right now. When I first went to the 20s I had it at 4F/0R and it was really comfy but performance was lacking in the corners. Highway on/off ramps that had expansion joints felt a little dangerous as the back end would bounce around a lot at every joint.
I'll probably go to 10F/8R and try that for a while but not much stiffer.
post #29 of 113 Old 04-17-2012
Mcmonopoly's Avatar
245/35 R19 on 9.5", 275/35 R19 on 10.5" rim.
See my garage for the complete information.
post #30 of 113 Old 08-06-2012
06les's Avatar
Anyone know how much each notch on the camber adjustment is? .5 degree? trying to get my camber set up
2010 Black GC 2.0T Track (flexfuel)
-----424whp/406wtq on corn-----
--CP-E TBE
--CP-E FMIC
--Tial BOV
--Haltech PnP
--Haltech Flex Fuel sensor
--Ace Alloy Convex Wheels
--HSD coilovers
--Whiteline Sways
--Wiseco Pistons
--K1 rods
--BR Stage 4 turbo kit (Ball Bearing)
--BR twin fuel pump and return line kit
--FIC 1100cc Injectors
--ACT clutch with BR Flywheel
--Acer Iconia tablet in dash
06les is offline
post #31 of 113 Old 09-01-2012
OgRe's Avatar
Anyone help me out on adjusting damping?
First time insatll coillovers
Sent from my iPhone using AG Free
OgRe is offline
post #32 of 113 Old 09-01-2012
OgRe's Avatar
What do you mean by full soft and full hard?
OgRe is offline
post #33 of 113 Old 09-02-2012
06les's Avatar
Full soft would be the damping adjustment knobs turned all the way counter clockwise. and full hard would be turned all the way clockwise. just adjust them to where you like it. right now i have mine on 12 click from full soft, but thats because my camber isnt set up quite right and i want to eliminate rubbing. suprising enough, it still rides pretty good
--CP-E TBE
--CP-E FMIC
--Tial BOV
--Haltech PnP
--HSD coilovers
--Whiteline Sways
--Wiseco Pistons
--K1 rods
06les is offline
post #34 of 113 Old 12-19-2012
Krystalwhyte's Avatar
do you have pics??
2010 GC GT (Canada) Karussell White / tinted windows, Sequence front grill, Ark GRIP true duals with DP and TP
Krystalwhyte is offline
post #35 of 113 Old 05-14-2013
Red Thunder
2012-Genesis's Avatar
Hey man, im just about to order these coils. But Zi want a shop to install, mind me asking how you payed for install? And where abouts? Thanks
2012 - 2.0T Gen coupe
SFR- Custom Tune
AEM Cold Air Intake
MXP 3" Exhaust
DC 3" Downpipe
HSD Coil Overs
2 UNIQ Strut Bar
20mm front wheel spacers, 25mm Rear
M&s GriLL
Stage 2 Comp Clutch
Stock 18's
2012-Genesis is offline
post #36 of 113 Old 05-14-2013
Black 3.8GT
Reyza's Avatar
Running the same for a week. I'll add my review.
No instructions so I relied on the how-to's on here :P. Came in very handy.
20" Incurves and I think i'm running em pretty low.
Maxed the fronts at first but realized my fender guards won't like that that too much. Raised em up after 1 day of scrapping.
They ride really smooth considering I'm on 20" and pretty low. Very happy.
2010 2.0T Premium (Black) - RIP
2010 3.8GT (Black)
Reyza is offline
post #37 of 113 Old 05-14-2013
Mazukou's Avatar
Quoted: 251 Post(s)
Originally Posted by CanadianEH View Post
it looks like you left your camber the same as it came straight from the box?
2013 Gran Premio 3.8 Track M/T
Stoptech SS Brake Lines, Agency Power Clutch Line, R2C SRI, Agency Power Catback, ARK DP/TP, PBM Coilovers, BTR Tune, EBC Redstuff, UR L/W Pulleys, Ported Throttle Body, Competition Clutch, Gram Lights
Mazukou is offline
post #38 of 113 Old 05-17-2013
yimnvs's Avatar
What are your dampening and height settings with those 20's? I have 20's too and would like to have an idea before I install my HSD coils sometime next week. Thanks.
Luxon Grill
Superlux Tails
DD 6K HID
Stance SC-5
HSD Coilovers
Magnaflow CBE
BTRcc Canned Tune
yimnvs is offline
post #39 of 113 Old 05-17-2013
Black 3.8GT
Reyza's Avatar
I've set mine to 5 from full soft on front and rear for city driving since my city has a lot of bad roads. You'd probably want to run stiffer if you plan on tracking it or take hard corners :P
2010 3.8GT (Black)
Reyza is offline
post #40 of 113 Old 05-17-2013
yimnvs's Avatar
Nice, I don't track at all so I don't need to be so stiff..just stiff enough to lose some ricers in the corners...lol
I drive in the city most of the time and my pro-kit has been hurting my butt from all the potholes here so i need something smoother.
Did you have springs before or were you on stock suspension? and if u did have springs..was there a big diff in comfort going to HSD? or even a diff from stock?
Luxon Grill
Superlux Tails
DD 6K HID
Stance SC-5
HSD Coilovers
Magnaflow CBE
BTRcc Canned Tune
yimnvs is offline
Hsd coilovers!!! Sale!!! [email protected] Suspension 289 11-26-2016 09:41 PM
HSD Coilovers? Anyone used? Snoopy0812 Suspension 2008-2012 112 05-11-2012 07:10 AM
HSD Coilovers? Junior's GC Suspension 2008-2012 21 10-15-2011 04:35 PM
new HSD coilovers = new video Jm_Dug Media 19 09-05-2011 10:14 AM
