R1 Concepts Genesis Coupe Limited Time Rotor/Brakes Sale!!! - Page 14 - Hyundai Genesis Forum
 18Likes
post #261 of 835 Old 04-22-2013
RWDcoupe's Avatar
Originally Posted by Mclovin50 View Post
Those 2 screw holes aren't really necessary as the rims with lug nuts provide enough force to keep the rotors in place when driving. I had an RSX and didn't use the screw holes and my rotors were fine. No vibration or anything.
Yes they have screw holes just installed these 2 weeks ago or so
2010 R-Spec 2.0T BB
SFR Tune
M&S Grille
black bezel headlights
Forge Bov
Depo Racing Intercooler Kit
Sequence CF Diffuser
UR CBE
Ralco STS w/ TIC Bushings
Blox 490 GM shift knob
Dark Chrome Wing Emblem (Rear)
Dipped Superlux Tails
custom triple gauge pod
1500 watt System
8000k hids, halo yellow fogs
Varrstoen es332 19x9.5 +12/10.5 +22
BC Coilovers
ViS AMS CF Hood
Vis CF Fog Surrounds
Prodigy Lip
Coming Soon
Ixion Rear Lip
vis k2 trunk
RWDcoupe is offline
post #262 of 835 Old 04-23-2013 Thread Starter
Originally Posted by osakeru View Post
PM for quote on drilled & slotted front rotors by them self & also a total for the rotors & Hawks HPS w/Brembo to ZIP 90723 please.
PM Sent! Thanks.
Do the premium rotors have the groves for the 2 screws that attach to the nuckle to sustain the rotor? or they dont need that? the product picture don't show the 2 holes only the 5 spoke holes.
The rotors do have the 2 holes for the placement screws. Although they are not necessary. I stripped my screws when I was removing it, and never replaced the screws. These screws are not whats holding your rotors in place, your lug nuts are. Typically these screws are used during production to hold the rotors in place through the assembly lines.
Originally Posted by GenTeq View Post
PM quote for brembo front/rear drilled & slotted rotors and stoptech pads to 20170. Thanks.
Pm'ed. Thank you!
Originally Posted by redhotpokerb View Post
hey. If I have non-brembo brakes, can i use these rotors to switch into brembo brakes??
Yes, and no.... there will be plenty of discussions on the forum about this. But brief summary....
Yes you can use the Brembo discs, but you would need the Brembo calipers to go with them. They pretty much bolt on with the exception of the rear. There will be some modifications needed to the rear dust shields. Other then that they bolt right up.
r1concepts is offline
post #263 of 835 Old 04-24-2013
Pm quote of hawk hps w/ brembo shipped to 08551
kimjongGen is offline
post #264 of 835 Old 04-29-2013
Thank you very much I appreciate your response. Considering your quotes I would like to order a front rotor set ($225) and a front Hawk HPS pad set($100) for Brembo brakes. Unfortunately I'm still new in this forum and I'm not allowed to send PM's back, would calling you to give you my personal info a better option? If so what number can I reach you in? And would you still consider this quote valid through the phone? Or what other options do you consider to finalize this purchase.
osakeru is offline
post #265 of 835 Old 04-29-2013
Here is there website...R1Concepts - OEM, Drilled & Slotted Brake Rotors - Brake Pads - Brake Calipers
Phone Tel: 714-777-2323
General Email - [email protected]
In case you need it.
2013 Gen Coupe 3.8 GT
Mclovin50 is offline
post #266 of 835 Old 04-30-2013 Thread Starter
You can reach me by several ways. Email, or phone if needed to be.
All the contact info was on my sig down below each post
But here it is~
Phone - 888-712-6623 x7017
Or you can contact the general line if your having issues contacting us as Mclovin50 generously pointed out.
Thanks for helping out
post #267 of 835 Old 04-30-2013
Thank you guys. appreciate it. Ill be contacting you Mr. Young probably by tomorrow. Thank you again.
osakeru is offline
post #268 of 835 Old 05-04-2013
PM quote front + rear Brembo drilled rotors + HPS pads to 19446 pls. Thanks.
2010 Nord Gray 3.8 Track M/T
sbphelms is offline
post #269 of 835 Old 05-10-2013
BobLoblaw's Avatar
PM quote for front and rear Hawk HPS pads for Brembo to 45419 please. Thanks!
BobLoblaw is offline
post #270 of 835 Old 06-11-2013
BobLoblaw's Avatar
PM quote for Dimpled and Slotted Rotors for Brembo please to 45419. Thanks!
post #271 of 835 Old 06-11-2013
GC13PAT's Avatar
cross drilled brembo front/rear for '13 with stoptech brembo pad front/rear 94015.
'13 Gen Coupe 2.0T Premium A/T
Parabolica Blue - YU5
Mods
DD Switch Back // DD 8K HID Low Beam Kit w/ Relay // Plasti Dip Rim, Matte Black // Magnaflow CBE // Injen SRI // .5 SFR Custom Tuned / 243whp 282 Torque // Isis Downpipe / Testpipe // AGP Catch Can x2 // Ixiom Spoiler / Plasti Dip Matte Black // Brembo Swap // Synapse BOV Kit // Matte Black Wing Emblems // Stage 1.5 tune // NGK 2309
Pending : Dyno / PnP Grimspeed Intake manifold
GC13PAT is offline
post #272 of 835 Old 06-30-2013
Break Necks - Kill Egos
johal's Avatar
Quoted: 111 Post(s)
Can I get a quote for this set up shipped to T1X 1W3 Canada.
https://www.gencoupe.com/media/103935...pic-heavy.html
johal is offline
post #273 of 835 Old 07-29-2013
Quote for rear Hawk Pads only, to Zip code 90723 for Hyundai Genesis Coupe 2012 2.0 R-Spec (Brembo)
osakeru is offline
post #274 of 835 Old 08-06-2013
POV Futografee
Tilley's Avatar
Quoted: 36 Post(s)
I'm assuming that the nothing changed for the '13's lol PM for front and rear, slotted and drilled (w/ Brembo's) shipped to 85747. Thanks!!
Tilley is offline
post #275 of 835 Old 08-06-2013 Thread Starter
Yup! Nothing changed for 2013 Base brakes and Brembo brakes the same deal.
post #276 of 835 Old 08-27-2013
emailed about pricing since i can't pm (still too much of a n00b)
mike05 is offline
post #277 of 835 Old 08-29-2013
Please pm me with total price for shipping set of slotted with Hawk HPS pads for Brembos to 27502. If I get my order in today, when do you figure that you could get them to me?
Thanks,
Alan
2010 2.0T R-SPEC
BTRcc Tune, K&N Typhoon, Forge BOV, TurboXS RS
Alan is offline
post #278 of 835 Old 09-01-2013
My mistress is a GC!!
Videopho's Avatar
PM me front and rear slotted rotors Premium series to 75082, Brumbo setup. Thanks
2010 Genesis coupe blanc/noir 3.8 Track.
SFR stage 1.5 custom [email protected]271whp. HSD coilovers, R2C sri, Magnaflow CBE. PrecisionLED, UniqPerformance Rigid Collar, wing badges.
2013 Genesis ReSpect Noir/Noir.
Aluminum brush pedals. Winged badges all around. K&N A/F. PrecisionLED. Trunk Lid Spoiler.
What exactly is a r-spec Genesis? It's sort of like Rodney Dangerfield's favorite sport ride.
Videopho is offline
post #279 of 835 Old 09-03-2013
Videopho's Avatar
^still waiting.
Timing sensitive order. Please respond.
Videopho is offline
post #280 of 835 Old 09-03-2013 Thread Starter
Originally Posted by Videopho View Post
^still waiting.
PM Sent.
Sorry for the late reply. But we do not open weekends, and we were also closed Monday for Labor day
Let me know if you have any other questions or concerns. Most PM's are replied same day or within 24hr period. (as long as its within business hours)
R1 Concepts Limited Time Rotor/Brakes Sale!!! Hawk, Stoptech r1concepts Suspension 26 01-23-2012 01:38 PM
GReddy to Debut Performance Parts for Hyundai Genesis Coupe rntibbyboy Engine 23 10-19-2009 05:37 PM
Buschur Racing 2.0T Genesis Coupe *OFFICIAL PARTS RELEASE* Lineup & Pricing! [email protected] 2.0T Discussion 2008-2012 45 07-06-2009 07:33 AM
Canadiandriver.com First Drive of Genesis Coupe el_capitan General Discussion 5 04-07-2009 12:21 PM
Street Concepts to Develop Customized GenCoupe for SEMA john General Discussion 22 10-21-2008 03:17 PM
Tags
ate , brake , ceramic , drilled , g2 paint , hawk , pad , r1 concepts , r1concepts , rotor , slotted , stoptech
