<SFR> ::FAQ:: SFR 2.0T Turbo ECU Reflash - Hyundai Genesis Forum
post #1 of 127 Old 02-24-2012 Thread Starter
Quoted: 215 Post(s)
Since search function on this forum isnt' the best outthere and a lot of people don't tend to do some search , we've decided to make a thread of FAQ on our 2.0T Genesis Coupe ECU reflash.
I will be truly honest that we've been a bit afraid to put up a thread like this and stating all the facts.
This probably has been one of the most sensitive topic that we didn't want to cause any kind of frame or fanboy war like usual since we have many vendors offering their own ECU flash as well as piggyback and stand alone.
This is what I can think of right now but as we get more questions, I shall update on this.
Please keep it in mind that we've been offering this ECU reflash service since July,2010 yet we have at least 400+ customers out there running our ECU reflash as of today (Feb,2012)
Basic feel of reflash
2.0T SFR ECU Reflash F.A.Q
*Video of dyno results from SFR canned tuned on 2.0T with AEM intercoler kit+piping+downpipe+axleback exhaust.
~35rhwp ~70lbs/ft gains on Mustang MD Dyno with load!
* 4th gear results that should be easy 45rhwp 100lb tq on 5th gear
- What does it exactly do?
1. Throttle response
Since Genesis Coupe has E-throttle body that is controlled by sending signals
with ECU, there are some delay/hesitations with throttle body. It also has to
do with notorious rev hang issues we've seen and experienced especially with
automatic tranny. With SFR reflash, we can control the timing and
responsiveness of throttle body remapping the logic of the throttle body.
Reaction time will be a lot quicker and all the lag that used to be with stock
tune will be gone. We don't want it to be too touchy especially for the
customers located in East coast where they get snow in winter, so we've put
it in the safe range. Going into full throttle (80% opening) is going to be
much faster resulting to reach desired RPM faster than stock tune. It also
saves gas mileage since car will be more responsive with throttle (with less
amount of gas on the foot moves the car... Injection = amount of foot to the
gas)
As you can see in the video, even with bumped RPM (7200rpm) whole transition to next gear comes way faster than
using stock throttle response and RPM reaction causing smoother transition between the shifting yet faster WOT times.
2. Upping the boost level
Stock boost level is usually 12-13psi peak and 10-11 psi hold being internally
waste gated type.
We usually offer about 4-5psi bump on the boost if the car is bone stock.
We give next next upgraded tune when the customer comes with
intake/exhaust/ most importantly FMIC which should bump at least 10-15rhwp
and another 10-20lb tq.
A lot of people never understood this but one of the most important
components for turbocharged car is FMIC where it really cools down the
HOT compressed air in the piping. Without having legit brand of core and
quality FMIC, heat soaking stock or low quality core will definitely cause
damage to the motor.
We will require to come with a legit brands (nothing that looks big but it's made
of cheap core)with good efficiency.
(We will recommend the brands by PM or email.. we don't want to name any brands online)
* A lot of people also make mistakes playing with stock actuator thinking adjusting it will add power.
It may add a bit more power that's when you are running with stock boost level
or little more with adjustment.
As soon as you add boost with ECU reflash, ECU will automatically think
actuator is over boosting and will put your car into notorious "Limp Mode".
We highly recommend not to play with actuator if you are thinking of getting
the tune in the future.
We find a lot of people try to adjust back to stock and it's very hard to go back
once it's been touched.
Same deal with the aftermarket boost controller, ECU will be limiting powers of
upping the boost without properly flashed ECU.
3. Advanced timing
We give out timings depends on what octane rate you are running the car.
The higher octane you are running with the car, the more aggressive timing
we will be given to each flash.
We usually do not add much timing on stock turbocharged car for safety and
longer life for the motor especially the ones that do hardcore driving (Drifiting,
etc) on 2.0T motor.
Also note to use legit brand named Gas stations to get octane rate as
advertised.
Giving more timing will make more power throught the RPM, and the customer
definately feel the aggressiveness of power and torque.
We recommend one or two step colder spark plugs for 93+ (octane) tunes (especially the custom tunes)
4. ECU year/model/version
As most of you know, there are many different versions vary by the
manufactured years/model.
SFR is very proud to say that we are the only company who can reuse your
factory equipped ECU version to flash your ECUs.
What gives?
It is very important that though with same engine and other components, Hyundai has put in more safety features in newer year of ECUs.
Sure it could be Hyundai's protection not allowing the owners to play with their cars but we really think it's there for multiple reasons.
You can sure flash older year versions over newer years but it might cause constant limp mode problems, loosing power, Check engine light, immobilizer problems, knocking, etc.
It's already been discussed that it is not possible to flash back to exact stock tune while SFR is the only company that collects and saves all versions of data allowing us to go back to exact stock version.
https://www.gencoupe.com/2-0t/53998-r...tock-tune.html
Our each ECU flash is using all based versions after receiving,seeing,pulling the ECU version labelled on the ECU that all calibration data of each ECU will remain the same under same version.
It will allow customers to run their cars safely with less troubleshoot.
5. Core/Pretuned ECU
What we started offering is cloning or offering pretuned ECU for owners while
stock ECU is pretty much untouched.
We've sure already covered all versions of 2009-2012 stock ECUs that we can
offer pretuned ECUs flashed in the same versions of stock ECU.
The owners can visit the dealership for major services with their stock ECU
while they can switch back and forth with our pre-tuned or Core ECU.
6. Bigger turbo/Injectors/Hicam/etc
We only offer canned tunes for stock turbocharger/injectors/etc.
Aftermarket intake/exhaust/o2housing/downpipe/mid pipe/FMIC are only
considered as "basic bolt ons".
We sure will be offering canned tunes for Staged packages in the future, and
we are still in process of collecting data for brands of
injectors,turbochargers,etc.
We highly recommend going for custom tunes if vehicle is equipped with bigger
injectors/turbos/etc since every car is different and it could be very dangerous
running canned tune for such equipped vehicles.
7. Rev limiter/Top Speed governor
We can only change the rev limiter on Manual tranny cars.
The usual and proven RPM bump is @ 7200rpm. Neutral RPM rev limiter is still
@5000rpm like stock. We can always change this but in case of dealers
checking things out with possible alternations, we didn't want to put
anything too obvious. Top speed governor will be taken out and there will be
no limit to the top speed.
- What parts to buy/what mods to do?
We have brands and parts to recommend in order to maximize the outcome of
the reflash. We've done quite many custom tunes for certain brands and
combination. Some wrong modifications such as taking out all catalytic
converters will loose power (Your car isn't 80's Honda civic). o2 sensors not
only monitors the amount of o2 but the temperature of the cat and etc that
if it is not reading right bascially A/F ratio map on ECU that is connected to o2
sensor would also get messed up resulting high risk of running extremely lean
or rich. If it runs lean, ECU will pull timings resulting loss of power as well as
running rich. So please contact us for any modifications prior or after the ECU
flash. We'd be more than welcome to help out selecting parts as well as
locating and giving the best pricings as possible. We'd refuse to tune certain
cars that have the parts already on the car we aren't really sure about. I
- Retune?
If you are only putting in some bolt on parts such as intake/exhaust/etc, you
don't need the retune. Flahsed ECU will act just like stock ECU that will
relearn itself overtime. It only takes few seconds to reset the ECU by pulling
the ECU fuse in the fuse box located near the battery. No you will not loose
the flash by disconnecting the battery or pulling the fuse out. ECU flash is
permanenant. ECU will go back to when we first flashed the ECU after the
reset.
If you are coming with other tuner's tune, we will have to charge extra to
returning ECU back to stock first to get the basedata made. So far we are
the only vendor that reuses the ORIGINAL stock data converted to tuned
data.
Custom Tune
We can sure offer custom tunes for bigger turbo/injectors/etc that we've been doing.
You can either pay the visit to SFR USA or grab us while we are doing the tour in your area.
We refuse to tune the vehicles that are equipped with anything that we think it's dangerous or will give problems on the dyno.
Please contact and provide us pictures of the set up and list of parts on the car prior to the tune session so we can give some suggestions.
We've already done Evo X/Evo 8/9 kit/19T turbo/GT35R/Precision 6262 turbo, 550cc/750cc/1000cc injectors, etc.
450rhwp Precision 6262 Turbo custom tune
19T turbo upgrade tune (303rhwp 333tq/lbs)
Stock turbo Stage 2 ( 270rhwp 331tq/lbs)
Optional Launch control
- Warranty
We don't guarantee anything about Hyundai's warranty with ECU flash. Get
this at your own risk just like any other aftermarket parts you put on.
However, it's not obivously seen or detected compared to any visible mods
such as intake/exhaust/etc.
We always use original stock data pulled then modified to tuned data, so all
the calibration data and other ECU functions remains exactly the same as
stock.
We also have just started offering the ECU core for those of people who are
really worried about their warranty, and you can keep you stock ECU and
tuned ECU.
Then, basically switch them out when you go to the dealer for any services.
- Feedbacks
As of today 02/25/2011, we've done little over 400+ Genesis coupes ECU flash
(both 2.0T and 3.8 combined) since July 2010.
We've been getting bunch of positive and "WOW" responses, but feedbacks
are all over the places that can't get all of them at one place.
We've been collecting some of feedbacks that we can find and it's here:
(Please read through the initial thoughts and impression that fellow Genesis
owners have experienced)
https://www.gencoupe.com/seoulful-rac...ck-thread.html
Thank you
post #2 of 127 Old 02-24-2012
Take 'em Fei!
WildBill's Avatar
Quoted: 50 Post(s)
Very nice write up. Great info Jay!
Senior Member of the Genesis Coupe High Mileage Club
2010 Hyundai Genesis Coupe 3.8L V6 Track M/T in Mirabeau Blue (Eva) - Retired
Bought - 25 miles, Retired - 145,000 miles, Total Miles - 145,000 miles
2012 Hyundai Genesis Coupe 3.8L V6 Track M/T in Interlagos Yellow (Fei) - Active
Bought - 22,000 miles, Currently - 83,000 miles, Total Miles - 61,000 miles
Total Miles in a Genesis Coupe - 206,000 miles
WildBill is offline
post #3 of 127 Old 02-25-2012
Boost Fiend
it works for the 2012's as well?
GimmeThe2.0t is offline
post #4 of 127 Old 02-25-2012 Thread Starter
Quoted: 215 Post(s)
Yes. We've already done 10+ 2012 2.0T Genesis Coupes using 2012's own individual's original data versions.
We do have an ECU reflash dealer in FL as well.
post #5 of 127 Old 02-25-2012
See You Spring 2013
Mira2White's Avatar
Very nice info Jay and I think it was a great Idea for you to compile all these video's and threads into one. So when the new guys and gals come to GenCoupe they do not have to post three different questions they can just come here and find out what SFR reflash is!
Sold:2010 MB BR Stage 3 Auto Test Pilot
Sold:2012 KW BR Stage 3 MT
Current: 2012 Apex Silver Evo X GSR
Auto Guys Message Me With Any Question Or Concerns!
Mira2White is offline
post #6 of 127 Old 02-25-2012
Boost Fiend
Jay, can you pm me the info for the dealer in florida? what does the reflash run?
post #7 of 127 Old 02-25-2012
how much is their flash ?
i can find any info on there site.
and how much if it want them to just send me a Ecu with flash ?
birel is offline
post #8 of 127 Old 02-25-2012 Thread Starter
Quoted: 215 Post(s)
i think they are relocating their shop so Idon't know their new phone number.
You can definitely get a hold of SN: Smokes here on Gencoupe.com
Canned tune is $400
Reg price is $550 but we are still offering at $400 for canned tune
Pretuned ECU is extra $250 so it's $650 for 2.0T
We do not advertise them on our website in case of dealerships finding out the relationships with our website for their customers' cars.
Sure we will get less sales but this is the main reason why you don't and won't see this on our website.
post #9 of 127 Old 02-26-2012
Sm30's Avatar
Great info here. I've always wanted to go with the br tune, but the more I read about this the more I'm warming up to it.
Jay, Maby you can talk a little bit about having gauges? I know when you start modding the engine you should be able to monitor it, but how safe are your base tunes, and how do you feel about not having gauges. And gauges I mean a/f ratio and boost.
Genesis Coupe 2.0 M/T-Bathurst Black-Gina
Xxr/Eibach/Synapse/TurboXs/Injen/Sarona/DiodeDynamics/JLAudio/Alpine/CompetitionClutch /DepoRacing
BTRcc Tuned
Sm30 is offline
post #10 of 127 Old 02-26-2012 Thread Starter
Quoted: 215 Post(s)
Boost/AFR gauge is must for turbo cars especially internally waste gated type of controlling the boost.
I also recommend Exhaust temperature gauge if you can afford to get it as well.
This thread is basically self explanatory how safe our ECU reflash is that we are one of the vendors that is offering the tune for the longest time yet you do not see any major problems along after getting the tune.
Sure we have customers from babying the car to daily drive/weekend race cars (Drift/Gymkana/Track/etc).
As long as your car is catted properly and the actuator was never touched, you will be more than safe to run with the tune without gauges.
Hope this helps
post #11 of 127 Old 02-26-2012
Sm30's Avatar
Hope this helps
Thanks for the response. It's looking like I'll be seeing you April 15th.
BTRcc Tuned
Sm30 is offline
post #12 of 127 Old 02-26-2012 Thread Starter
Quoted: 215 Post(s)
Sounds good!
post #13 of 127 Old 02-27-2012
Discount Tire Co.
Vedran's Avatar
I have the Reflash and yes it Rocks, but i dont see how they are different from the other ones?? No one can answer which tune is better, SFR, BTRcc, BR, PA, ect ect... How can someone really tell? lol
Jay do you have a tune for 16G turbo?
Vedran Duras
2011 GENESIS Coupe 2.0T Rspec
327WHP 270TQ
BTRcc TUNED
Vedran is offline
post #14 of 127 Old 02-27-2012 Thread Starter
Quoted: 215 Post(s)
^ Someone who actually tried them can ONLY tell! and nobody has done that yet.
Sure some of our customers have done their own comparisons with certain vendors' tunes and they don't wanna talk about it since again it's a very sensitive topic to discuss online.
Just upping the boost of 2.0T will be "night and day difference" being a factory turbocharged car.. but the main part of it is how safe/reliable without issues.
This is why we've been bragging about our tune that differentiates from others that we always reuse stock version/data for certain year/model/tranny/etc as mentioned above.
There isn't such thing as canned tune for upgraded turbo or injectors.
They gotta be custom tuned since every car is different yet they all have different bolt on mods. Sure I can tune any bigger turbos if it's set up right.
post #15 of 127 Old 02-28-2012
Redsox0721's Avatar
Awesome write up. I now made a decision on which tune to get. I'll cya on April 15th!!!
Redsox0721 is offline
post #16 of 127 Old 02-28-2012 Thread Starter
Quoted: 215 Post(s)
See you
post #17 of 127 Old 03-11-2012
SFR Tunes go BOOM!
Silent_J's Avatar
Hello Jay...will SFR be at the tail of the dragon meet next month? I heard talk about it but havent really got a definite answer
KW 2010 Genesis Coupe R-spec
--Mishimoto R-line FMIC
--HKS ssqv bov
--TurboXS 3'' Catless o2 Housing
--TurboXS 3'' Catless Downpipe
--Custom straightpipe
--AEM cold air intake
--Bosch 750cc injectors
--TurboXS 20g Tune
323whp/284wtq @ 18psi
--Competition Clutch stg 2+ with lightweight flywheel
--Powered By Max Coilovers-comp version
--Megan Racing Rear upper arms, rear trailing arms, rear toe control arms
--ST suspension Front and Rear sway bars
-Painted Roof 350z Black
-M&S Grill
Silent_J is offline
post #18 of 127 Old 03-11-2012 Thread Starter
Quoted: 215 Post(s)
Yes that's what we are shooting for!
We try to keep our promise as much as possible.
post #19 of 127 Old 03-12-2012
Shift's Avatar
I would like to get a reflash but i cant pm yet for the pricing can you plz help Jay?!
That's What She Said!
Bathurst Black 2.0T
AEM FMIC
Silencer Delete (2)
WGA Mod
No Exhaust after o2 housing
Tinted Taillights
Ixion Rear Diffuser
Tein Springs
Xxr 521 Flat Blk 20x8.5+35(f) 20x10.5+30(r)
Shift is offline
post #20 of 127 Old 03-12-2012
SFR Tunes go BOOM!
Silent_J's Avatar
Cool deal...also I was wondering could i run this tune on stock i/c with hardpipes and water/meth injection?
--HKS ssqv bov
--TurboXS 20g Tune
-M&S Grill
Silent_J is offline
2.0t turbo XS reflash customers chime in turboflagship 2.0T Discussion 2008-2012 3 02-04-2012 08:45 AM
help? why can't i use pa reflash w/garrett 350hp turbo rfcmaratita 2.0T Discussion 2008-2012 15 12-08-2011 07:25 PM
Why not just reflash with new turbo and injectors? Rotarywng 2.0T Discussion 2008-2012 87 02-05-2011 03:58 AM
which mod first? reflash or turbo back exhaust? jvsantosmd 2.0T Discussion 2008-2012 32 03-16-2010 09:35 AM
Reflash, higher boost, and turbo life expectancy alejan 2.0T Discussion 2008-2012 63 11-01-2009 05:20 PM
