[INFO] General Coilover DIYs/Tips/Tricks/Knowledge - Page 3 - Hyundai Genesis Forum
post #41 of 53 Old 04-15-2013 Thread Starter
1stgengen
ByByCavalier's Avatar
Check your sway/roll bar to be sure the end links are tight.
One standardized US gallon of displacement compressed using 6 pistons housed in a 60 degree all aluminum V shaped block to 10.4 atmospheres injected and ejected via 24 valves and 4 camshafts. Mix part 100% organically produced air w/ part refined 91 octane liquid hydrocarbons. Expose to electricity and pressure within the energy extrapolater to produce forward thrust via a fully synchronized helical gear set coupled to a minimal slippage differentiator and rubberized traction disks.
ByByCavalier is offline
post #42 of 53 Old 04-15-2013
Dwy6262's Avatar
Also the nut on the top of the shock make sure it is tight. If its lose it will make a tapping sound when you go over a bump
Interlagos Yellow
2010 3.8 track m/t
AEM cai
Phenaulic spacer
Cat delete pipes
CNT cat back exhaust
SFR custom tune
283Hp, 254ftlbs. At the wheels
Dwy6262 is offline
post #43 of 53 Old 04-15-2013
Skywalker07's Avatar
One I'd my Megan's was clanking, I didn't have the shock locking collar tight enough.
Skywalker07 is offline
post #44 of 53 Old 04-23-2013
pinter's Avatar
Any recommended settings for the HSD coils in terms of adjustment? I have the front on 8 clicks from full soft and the rear on 6 clicks. Rides good but if it's all wrong, I rather switch it up.
2010 GC 2.0 GT
pinter is offline
post #45 of 53 Old 04-23-2013
My mistress is a GC!!
Videopho's Avatar
How would you characterize the ride right now with that setting? Soft, firm, or what?
I currently have 10 front and 8 rear from full soft and I may adjust it again until I find the sweet spot if there is any.
2010 Genesis coupe blanc/noir 3.8 Track.
SFR stage 1.5 custom [email protected]271whp. HSD coilovers, R2C sri, Magnaflow CBE. PrecisionLED, UniqPerformance Rigid Collar, wing badges.
2013 Genesis ReSpect Noir/Noir.
Aluminum brush pedals. Winged badges all around. K&N A/F. PrecisionLED. Trunk Lid Spoiler.
What exactly is a r-spec Genesis? It's sort of like Rodney Dangerfield's favorite sport ride.
Videopho is offline
post #46 of 53 Old 04-23-2013
pinter's Avatar
I have a Canadian GT which I believe is a US Track and I would characterize the suspension as softer then stock and a little bit bouncier. when it's really bumpy. I like it as it's not so rough over the bumps.
I might test it 14 front and 12 rear when I have time to adjust it again just to see the difference but I am more for comfort until I want to drive aggressive.
2010 GC 2.0 GT
pinter is offline
post #47 of 53 Old 04-23-2013 Thread Starter
1stgengen
I usually sit around the 8-10 range, depending on what type of driving I'm doing.
It really is just based on your comfort and the type of driving you're going to be doing.
Soft for long drives, stiff for spirited drives.
post #48 of 53 Old 04-23-2013
pinter's Avatar
Is 2 more clicks in the front compared to the rear proper?
2010 GC 2.0 GT
pinter is offline
post #49 of 53 Old 04-23-2013 Thread Starter
1stgengen
I dunno, I usually keep my rears stiffer to limit bounce. By about 2 clicks lol! Again, depends on hat your going for.
If I remember correctly, stiffer in the rear will cause the rear to step out faster, inducing oversteer.
post #50 of 53 Old 05-20-2013
Dwy6262's Avatar
That is true. I run my cx racing v2 coils at 12 from the stiffest setting in the front and 14 from the stiffest in the rear. Its a little softer in the rear but with the weight of the motor in the front it feels like it ballances out well around the corners.
Interlagos Yellow
2010 3.8 track m/t
AEM cai
Phenaulic spacer
Cat delete pipes
SFR custom tune
Dwy6262 is offline
post #51 of 53 Old 05-03-2014 Thread Starter
1stgengen
Could I get some people here with various coilover setups to get some rough measurements for me?
I need you guys to take a look at your rear dampers while they are loaded (car on the ground at ride height). Take a measurement from the top of the strut rod to the strut body to determine your real suspension travel available. This applies to separate damper/spring coilover assemblies (unlike PBM).
I assume everyone has preload set up as described by the various posts on here. I'm trying to come to a conclusion on the whole rear preload and suspension travel issue we have here. It would seem that the popular preload setup instructions does not allow for enough suspension travel, especially on lowered cars.
post #52 of 53 Old 10-06-2014
Phila36's Avatar
Hey cav. Did you ever figure out another way to do the preload? I've followed your rear preload instructions and I still get huge bumps when going over little cracks or little potholes. I've tested both rear dampers and none of them are blown. The car rides pretty smooth on new roads but when I hit a tiny pothole or even a small crack, the car launches vertically. is there anything else I could try to fix this?
2013 2.0T R-Spec
Gran Premio Grey
6M/T
TurboXS GT Catback
TurboXS Racepipe
TurboXS SML-Hybrid Blow Off Valve
HPS Racing Short Ram Intake
Grimmspeed/Snoopy BOV Solenoid
PBM Comp Coilovers
EuroTek U02 Matte Black w/ Achilles ATR Sport 2 Tires
--19x8.5 245/35/19
--19x9.5 275/35/19
Phila36 is offline
post #53 of 53 Old 09-12-2019
just a quick question here, but in your opinion, what are the best lowering springs for the money or coil-overs.
I just don't have that much money to spend and I want to make sure I do this right the first time hahaha thanks guys
Lucas Ramirez is offline
BTRcc Stage 3 Turbo Upgrade for Autos - Tips/Tricks/Deep thoughts etc... andrusk 2.0T Discussion 2008-2012 134 02-08-2013 06:27 AM
OFFICIAL Genesis Tips & Tricks thread Cobra Jet General Discussion 4 03-10-2011 03:07 PM
Any tips and tricks when gettin' a GC? GTA newbs.... yellowmp5 Ontario 0 04-23-2010 08:37 AM
[Info] compressor maps/turbo knowledge whatnot 2.0T Discussion 2008-2012 9 01-30-2010 09:43 PM
Tags
coilovers , handling , suspension
