[INFO] General Coilover DIYs/Tips/Tricks/Knowledge - Hyundai Genesis Forum
post #1 of 53 Old 12-19-2012 Thread Starter
1stgengen
ByByCavalier's Avatar
Hey Guys,
I noticed that there is a lack of easy to find info here related to coilovers. I've assembled a few threads that I'll link here that might help and hopefully this can be stickied for future use by members. Please link any other relevant coilover info you might stumble upon and I'll add it to the list.
All coilover suspension systems for the Genesis Coupe should fit, regardless of model year, trim and engine type, including 2013+ years. There is a slight difference in end links for the front suspension in years 2011+. I'll update with further info on that topic shortly, unless someone else can elaborate until then. Bascially, 2010 coupes have different sized endlinks than 2011+, meaning you have to take that into consideration. Thanks to rogkum for the info on endlinks provided in his post below.
I'll leave product reviews out of this for the most part, just to be all inclusive.
Enjoy! [FYI, read whole threads, as things are often updated and explained further]
ISC Install by xGuMB1x
https://www.gencoupe.com/suspension-2...diy-video.html
ISC Install by Kepone w/ lots of info on rear preload
https://www.gencoupe.com/suspension-2...pics-info.html
BC Racing Install by Sigel
https://www.gencoupe.com/diy-do-yours...r-install.html
Turn In Concepts suspension overview
https://www.gencoupe.com/suspension-2...-revealed.html
General Help w/ HSD adjustment guide
https://www.gencoupe.com/suspension-2...ll-help-2.html
Good info on spring rates
https://www.gencoupe.com/suspension-2...ing-rates.html
Thread on roll stiffness and weight transfer
https://www.gencoupe.com/articles-cha...ould-know.html
Available Coilovers w/ spring rates and dampening
HSD HR
16 way dampening
6kg (f)
7kg (r)
camber plates
HT series w/remote reservoir available
48 step rebound
12 step compression
BC Racing
30 way dampening
5k
8k
camber plates
ARK ST-P
16 way dampening
12kg
10kg
ARK DT-P
16 way dampening
12kg
10kg
camber plates
Stance GR+
15 way dampening
6kg
7kg
camber plates
KW Variant 3
14 way compression dampening/infinite rebound w/ two stage valving
400lbs/min front spring rate
progressive rear spring rate
Cusco Sport Zero-2E
5 way dampening
9kg (f)(r)
24 way avail. (Zero-3)
external reservoir avail. (Zero-3x)
D1 Factory
8 way dampening
6kg
5kg
Eibach Pro Street
no dampening adjustment
8.2kg
2.75-4.07kg progressive
Tein Street Basic
Megan Racing
32 way dampening
7kg
8kg
camber plates
PBM Max Pro USA
12 way dampening
8kg
6kg
Camber/Caster adjustment
ST Speedtech by KW
No dampening adjustment
CX Racing
32 way dampening
10kg
7kg
CX Racing V2
32 way dampening
5kg
8kg
camber plates
K-Sport Kontrol Pro
Research before you buy!
Still updating as info is found.
kimnat0r likes this.
One standardized US gallon of displacement compressed using 6 pistons housed in a 60 degree all aluminum V shaped block to 10.4 atmospheres injected and ejected via 24 valves and 4 camshafts. Mix part 100% organically produced air w/ part refined 91 octane liquid hydrocarbons. Expose to electricity and pressure within the energy extrapolater to produce forward thrust via a fully synchronized helical gear set coupled to a minimal slippage differentiator and rubberized traction disks.
ByByCavalier is offline
post #2 of 53 Old 12-20-2012
Quoted: 15 Post(s)
PBM
MAX PRO coilovers have many of the best things you have come to expect from our competition coilovers like front and rear pillowball spring perches, light weight mounting brackets and full tap super low independent ride height adjustability. They also have high quality components and a robust damper but unlike the comp. coilover which is a pretty stiff ride that compliments lower power cars, the damping on the PRO coilover has been fine tuned for a softer range by Eisuke Kawamori of Parts Shop MAX Japan to give high grip that high power cars require. The softer damper with more adjustability also compliments the NEW SLL Springs which feel softer than our standard springs because the rate is more linear. The SLL springs make this pro coilover even lighter than the comp coilovers. This pro coilover also feels comfortable on the street and has increased stroke.
Your requests on our wish list forum were taken into account here. These have been development for over a year after and prototypes have seen action throughout the 2010 Formula D season on Tommy Roberts and Matt Powers car (before Matt finally got picked up by major FD sponsor KW). The 2011 season will see Ryan Kado running these on his 350Z and for the 2012 FD Season we will add Matt fields S14 to the Pro roster. I have personally put more than 10,000 daily driven miles into testing these on the streets in my genesis. With the success of our exsisting coilovers over the last 5 years, we were in no hurry to release a new coilover line until it has met our expectations and withstood more abuse than you will give them through competition and crashes. They had to be dead sexy too - so we came up with a new look that has never been seen before by replacing orange and gold with real copper and mirror gold so we cant be mistaken for other products out there who use similar colors. Look for this color scheme in 2012 products designed to compliment the PRO coilovers. We hope you enjoy what we have worked so hard to create for you.
Sincerely, the entire team at Parts Shop MAX Japan and USA
Unique Features:
~ Super Light Linear Spring
~ CNC aluminum components double coated with pure copper, sealed with clear urethane
~ Pillowball uppers front and rear (teflon lined maintenance free)
~ Pillowball lower mounts (except Z33)
~ Fine damper threads to resist loosening
~ Rebound Infinitely adjustable with 12 click tactile feedback knob.
~ Damping has more adjustability all on the soft end of the range to compliment the swift springs and big traction on high power cars.
~ Camber AND CASTER adjustable front upper mount
~ 2 Degrees of negative camber built into lower mount
~ Lifetime warranty against manufacturer defect
MAX PRO COILOVERS BK Genesis 8/6KG $1,350.00 USD, 6 in stock
Benedict is offline
post #3 of 53 Old 12-20-2012 Thread Starter
1stgengen
Thanks, Benedict. I've updated with dampening and spring rate info.
post #4 of 53 Old 12-21-2012
'11 3.8 Silverstone
rogkum's Avatar
I wanted to add a bit of related info, about the end links change. All models built after 9/15/2010, have longer end links, and are not compatible with any coilover system designed for 2010 models (unless you get a set of the shorter 2010 end links of course).
It is commonly believed that the increased end link length was to reduce bump steer, which is true, but there is more to it. Snoopy0812 was able to elaborate, hope he doesn't mind me posting this:
Originally Posted by Snoopy0812
The endllinks don't just reduce bumpsteer, it's actually a side affect of their main purpose which is primarily handling. The shorter tighter endlinks are for high speed (think over 150km/h) stability and improved feedback in aggressive scenarios such as tracking and drifting. However the negative effect is DD handling, increased NVH and tramming. If you're not familiar with tramming, it's when the wheels are forced into grooves in the road and it becomes stiff or difficult to get out of them.
The longer, softer endlinks do nearly the exact opposite of the sorter ones. They trade highspeed performance for better DD. Some may notice the difference in handling, most however notice the bumpsteer change. To regain some of that highspeed performance without adversly affecting the DD characteristics you can use tighter bushings and ball joints while still maintaining the fundamentals of the longer endlinks. The 2013's went this route so they could run a softer more tolerant suspension while not sacrificing anything in handling and it works.
rogkum is offline
post #5 of 53 Old 12-26-2012 Thread Starter
1stgengen
Thanks for that, rogkum.
List has been updated a bit.
post #6 of 53 Old 12-27-2012
Car Nut's Avatar
Great thread and contribution Cavalier!!
2013 Genesis Coupe 3.8 Track | 6 Speed Manual | Becketts Black
2011 Sonata 2.4 SE | 6 Speed Auto | Radiant Silver
2000 Yamaha YZF R6 | Carbureted | Blue
Car Nut is offline
post #7 of 53 Old 12-27-2012
Genesis OG
J Long's Avatar
Quoted: 190 Post(s)
Only thing this thread is missing is tips/tricks on camber adjustment (using camber plates) and tips/tricks on adjusting ride height in the rear (mainly quickest/easiest way)
2013 3.8 Track M/T
BC Racing Coilovers
R2C Intake
ARK Downpipes
ARK Test Pipes
Custom CNT V3 w/ X pipe
SFR Custom Tuned
19x11 +18 265/30
Xenon Depot 6500K D1S HIDs
6000K Switchbacks
6000K LED Fogs
Full Time DRL's
RGB Halos
Custom Interior LED Kit
6W Reverse LEDs
20% Tint
J Long is offline
post #8 of 53 Old 12-28-2012 Thread Starter
1stgengen
I'll see what I can do. Thanks for the suggestion!
post #9 of 53 Old 12-28-2012
13gencoupe's Avatar
Any tips for pbm install? Ordering coils and rlca's from pbm in the next day or two
Sent from my DROID3 using AutoGuide.Com Free App
13gencoupe is offline
post #10 of 53 Old 12-28-2012 Thread Starter
1stgengen
As this is just a general guide for most coilover type, I would contact PBM or perhaps members who have installed that specific set of coils for installation tips. PBM has a "coil over damper" setup in the rear, where all the other brands have separate coil/damper assemblies, just like OEM. However, If I come across anything in my searches, I'll be sure to post it up.
post #11 of 53 Old 12-28-2012
13gencoupe's Avatar
O ok cool
post #12 of 53 Old 12-28-2012
제네시스 쿠페
jjashaa's Avatar
^ install is straight forward.
for the fronts, you can follow any of the DIY above but you can use 1320drift's specs for caster/camber adjustment by switching the position of the top hats.
The rears, once you have it, you will know. Don't worry about the empty OEM spring seat area.
2010 Genesis Coupe 3.8 Track 6MT w/Navi - Karussel White
2015 Lexus GS350 Fsport - Ultra White
1995 Mazda Miata MX-5 5MT - Black
█▄▄ ███ █▄▄ _ █▄█▄█ █▄█ ▀█▀
ಠ_ಠ
jjashaa is offline
post #13 of 53 Old 12-28-2012
Would you recommend using PBM for daily cars J? I don't track my car, but am looking for something comfortable and that will also allow for easier ride height adjustment in the rear. It was a lot of work every time I wanted to go lower or raising up my car with the Megans and BC I'd have to pull the whole rear assembly out.
2011Genesis is offline
post #14 of 53 Old 12-29-2012
13gencoupe's Avatar
You plan on adjusting ride height that often?
post #15 of 53 Old 12-30-2012 Thread Starter
1stgengen
Another question, why would you pull the whole assembly out?
post #16 of 53 Old 12-30-2012
Lord Stig
El_STiG's Avatar
I would. Already have spent a Day DD with them. I have the rear at 8 and up front at 0 clicks like 1320Drift has it. Its pretty comfortable for me. I'm sure if I left it at 0 click all round it would be super soft.
Raising and lowering the rears with the PBM rear coilover is cake! You dont have to romve the whole assembly off. Just the Spring and strut. thats it.
"Some say he disappears months at a time, and when he comes back, a new record for driving to and from a taco truck has been set. all we know is, he's called el_stig" [email protected]
Trusted with INVISION.
Suspension:
Powered By Max Pro Coilovers, Eibach Sways, Cusco Type MZ L.S.D., Achabono pads.
Engine:
GReddy FMIC, ARK DT-S TBE, Tuned by PowerAxel, ACT Street Clutch & Flywheel
El_STiG is offline
post #17 of 53 Old 12-30-2012
제네시스 쿠페
jjashaa's Avatar
I daily my car when I do happen to drive it around my town.. i'm at 0 clicks front and back and man.. its nice to have a smooth ride but also ready for any hoon-ing that needs to be done even at 0 clicks. haha
It's not THAT super soft compared to lets say.. megan and BC racing at full soft. but with those two coils at that soft, it just feels unnatural imo. (i've had BC racing coils)
Adjustment is easy... REAL easy.. i left my threads remaning same on front and back and suprisingly, the height came out the same. lol.. It definitely saved me a lot of headaches from my previous coilovers
ಠ_ಠ
jjashaa is offline
post #18 of 53 Old 01-01-2013
13gencoupe's Avatar
Just ordered my PBM coils and rlca's....thanks for the info so far ....will be a huge help come install/setup time
post #19 of 53 Old 01-01-2013
Lord Stig
El_STiG's Avatar
Crazy. When I ordered there were like 6 sets. Since I posted that I was getting these it went to 3. Insane. Lol
Suspension:
Engine:
El_STiG is offline
post #20 of 53 Old 01-01-2013
13gencoupe's Avatar
Its cuz i wanna be just like you...hah...i had been thinkin bout them for awhile...
BTRcc Stage 3 Turbo Upgrade for Autos - Tips/Tricks/Deep thoughts etc... andrusk 2.0T Discussion 2008-2012 134 02-08-2013 06:27 AM
OFFICIAL Genesis Tips & Tricks thread Cobra Jet General Discussion 4 03-10-2011 03:07 PM
Any tips and tricks when gettin' a GC? GTA newbs.... yellowmp5 Ontario 0 04-23-2010 08:37 AM
[Info] compressor maps/turbo knowledge whatnot 2.0T Discussion 2008-2012 9 01-30-2010 09:43 PM
Tags
coilovers , handling , suspension
