Sound coming from passenger rear tire area - Hyundai Genesis Forum
post #1 of 14 Old 3 Weeks Ago Thread Starter
JibbelSandwich's Avatar
Quoted: 23 Post(s)
Hey guys, I keep hearing this sound coming from the rear on the passenger side. I only hear it at lower speeds. It's hard to describe but here's a video of what it sounds like. It isn't the loud clanks you hear. It's a continuous popping sound I guess. You hear it right when it starts at it stops at about :08 and starts again at about :16. I just want to know if anyone has a guess at what the problem could be.
2010 Genesis 2.0T R-Spec
2005 Sentra Se-r Spec V
JibbelSandwich is offline
post #2 of 14 Old 3 Weeks Ago
br2
Bill
Quoted: 133 Post(s)
Sounds to me like something's loose.
I'd have it in a suspension shop to evaluate it. At least get it up in the air and examine everything.
Safety issues aren't good trial and error candidates.
br2 is offline
post #3 of 14 Old 3 Weeks Ago Thread Starter
Quoted: 23 Post(s)
Any idea on what could be loose? I'd rather just find and tighten myself but I don't want to be blindly looking around and at least have some idea on what I should be looking for. I hate taking my car to shops if I don't absolutely have to.
post #4 of 14 Old 3 Weeks Ago Thread Starter
Quoted: 23 Post(s)
Bump
post #5 of 14 Old 2 Weeks Ago
br2
Bill
Quoted: 133 Post(s)
told you what i think you should do.
if you don't want to pay for expertise, you can rent a lift bay. at least get it up on jack stands and crawl around under it.
br2 is offline
post #6 of 14 Old 2 Weeks Ago
IG: jasonlikedthis
mrGainZ's Avatar
Quoted: 242 Post(s)
Go around with a couple sockets/ratchet and tighten every bolt you see in the area. If you have coilovers, check that your preload adjustment is tightened.
2014 Tsukuba Red 2.0T AT
SFR Stage 1.5 Tune
Injen SRI
Synapse Radial BOV
ISR Race CBE / TP / DP
Khartunerz CF Lower Grill
Boostec CF Lip
Carbon Creations CF Trunk
VIS VIP CF Diffuser
BC Racing Coilovers
mrGainZ is offline
post #7 of 14 Old 2 Weeks Ago
Quoted: 693 Post(s)
what recent parts were working on, on the car?
post #8 of 14 Old 2 Weeks Ago Thread Starter
Quoted: 23 Post(s)
Okay, I'll try to tighten down everything I see to make sure nothing is loose then. The last thing in the rear that's been worked on is just changing the diff fluid which was last year. I did have a hit and run some months ago in the front but I remember hearing this noise before then. Obviously I should've tried to diagnose it much sooner than now but I haven't had as much free time as I do right now.
post #9 of 14 Old 2 Weeks Ago Thread Starter
Quoted: 23 Post(s)
Okay I got around to checking everything out today. Everything that I could fit what tools I had on were tight. I couldn't tighten down anything. The only thing I got to budge a little more was one of the 2 bolts that bolt the strut to the top. I pulled on the CV axle and heard a clank when I would pull in and out but I read that is normal as it needs that small amount of movement. Here are 2 pictures of the only things I could possibly think were of any concern. The O ring (at least I think it is some sort of O ring) on top of the spring looks cracked and then this bolt isn't completely seated but I couldn't budge it at all so I'm assuming it's supposed to be like that. I'm not super savvy with suspension haha.
post #10 of 14 Old 2 Weeks Ago
GenMeow's Avatar
I have a similar sound coming from my left tire area. I had an inspection done at a dealership two days ago and they said it was possibly my strut mount. I haven't looked into confirming it. They told me to jack the car up and let the front wheels hang, and then try to shake the strut and see if it's loose. Also, try driving on a smooth road and turning back and forth to see if the sound happens when you turn aswell.
GenMeow is offline
post #11 of 14 Old 2 Weeks Ago Thread Starter
Quoted: 23 Post(s)
The bolt I was able to tighten a little more was the strut mount I believe. I'll try gong on a smooth road and doing that too. It's the most audible when I'm going at a slow speed. I don't hear it all the time but when I do it's like a spongy click type of sound. It sounds a little different in the video since I was going about 30 mph.
post #12 of 14 Old 2 Weeks Ago
IG: jasonlikedthis
mrGainZ's Avatar
Quoted: 242 Post(s)
Check and see if the ring pointed out in the picture is tight. Mine was loose one time and made sounds on every bump. Might not be it but worth a shot!
SFR Stage 1.5 Tune
Injen SRI
Synapse Radial BOV
Boostec CF Lip
VIS VIP CF Diffuser
BC Racing Coilovers
mrGainZ is offline
post #13 of 14 Old 2 Weeks Ago Thread Starter
Quoted: 23 Post(s)
Yes I checked all of the rings when I was down there yesterday. I didn't check with a spanner but I did check if they were loose enough for my hand to move them. I had hoped this was the problem haha
post #14 of 14 Old 1 Week Ago Thread Starter
Quoted: 23 Post(s)
I was able to get another video of the sound. Maybe this will help more. I'm going about 5mph in this clip. It's almost like a rubbery type of sound.
