It's 2019 - 2013+ Front end link options - Hyundai Genesis Forum
 2Likes
  • 1 Post By Thraxbert
  • 1 Post By andbudzi
post #1 of 9 Old 05-11-2019 Thread Starter
superchode's Avatar
Quoted: 324 Post(s)
Haven't been here is a while. Been sifting through some of the older threads in here lately and just didn't find what I was looking for. I remember bits and pcs from old discussions a few years ago but cant find the freaking the original threads and then there is the dreaded "dead links". So sorry for re-starting an end link discussion, but its 2019 now so why not? Maybe there is some fresh info. out there.
My current situation (not dire by any means) is with front end link options. Car is lowered on Parts Shop Max coils. Original setup was the stock OEM 2013 front end links. Those actually held up pretty good for about a year, then started to crap out (had about 42,000 miles on them). Then decided to try out the WHITELINE adjustable links. Did the whole PRELOAD setup and used ramps to dial it all in. These felt great at first, and no more clunks or pops lol.
Well that lasted about 5-6 months and they are dead as an end link can be, I mean they are basically just flopping around in there, and kinda sounding like popcorn when turning at low speeds
So I happen to have a spare NEW set of those that I could throw in there, and was just about to do so. But then I read what looks like a new EDIT on the PBM website that clearly states "USE ONLY OEM END LINKS TO PREVENT BINDING". So that got me to thinking to take a step back and rethink this whole thing. I WILL be tracking this car and doing some mountain runs now and then, but for fun so wont ever be corner balancing it. I am starting to lean back to OEM style end links as they held up WAY better than the WHITELINES. I mean sure, I can throw these in, but I am pretty sure in about 3 months or so, I will be back here searching the forums again lol.
So as of May 2019.... What current options do we have for "beefier" OEM style front end links (not adjustable). I know there were some MOOG options a while back, but wasn't sure on part numbers or if they are even worth it. Just looking for end link part numbers/options/lengths for a lowered 2013 CG on PBM coils (have the BK1 and BK2 mounting spots) that are built like bricks so I don't have to keep wasting time on the dam sway bar lol.
If anyone has any experience with certain brands, lengths/sizes or whatever else (talking about a 2013 here), please feel free to share thoughts and info on what may have worked well or not so well for you . More specifically some up to date part numbers or even links to the older threads that have them haha.
PFA
2013 Genesis Coupe 3.8 R-Spec BLACK 316whp / 286wtq
-SFR Custom "Mellow" Dyno Tune -Custom CBE -3P8P CAI -RPF1's 18x9.5+15F/18x10.5+15R -245/40/18F - 265/40/18R -PSM Comp Coils -JKS-2943 Frnt Endlinks -EBC rotors BSD-F/USR-R w/yellows -TITAN Leash -V3 Booster -Coolant Bypass -Ground Mod -GS Pheonolic Spacer -80mm Bored TB -Megan Trans Mount -OtHeR ThInGs... 2nd car_2011 Genesis Coupe 3.8 Track
superchode is offline
post #2 of 9 Old 05-11-2019
NOOB
Thraxbert's Avatar
Quoted: 35 Post(s)
PowerGrid 12M-130. Beefier than stock, adjustable, and work with PBM coils.
//edit: eBay or direct from Powergrid by mailing [email protected].
TKJode likes this.
2013 Grand Touring 3.8: R2C SRI | ISR Single Exit | Manifold Riser | TROS Potent Boster 2 | Engine Leash | Saikou Michi | Klutch KM20 | Whiteline Sways | Parts Shop MAX Competition | Moog & Powergrid Links | Brembo Swap | Android Auto
Thraxbert is offline
post #3 of 9 Old 05-11-2019 Thread Starter
superchode's Avatar
Quoted: 324 Post(s)
There we go.... Will check them out. Hoping anbuzi will chime in and link those jeep ones he likes.
Also kinda looking for non-adjustable too.... That are replacements for OEM stock size just a hair stronger 😉 but this is good fresh info.
Thanks 😉
-SC
post #4 of 9 Old 05-11-2019
andbudzi's Avatar
Quoted: 471 Post(s)
JKS-2943. ...yes from jeep.
Will never brake .. your mounting brackets on coils will wrip our before end links will go.
Birdoflight likes this.
andbudzi is offline
post #5 of 9 Old 05-11-2019 Thread Starter
superchode's Avatar
Quoted: 324 Post(s)
U da man. Sorry I always get ur name wrong lol
post #6 of 9 Old 05-11-2019
andbudzi's Avatar
Quoted: 471 Post(s)
andbudzi is offline
post #7 of 9 Old 05-28-2019 Thread Starter
superchode's Avatar
Quoted: 324 Post(s)
So ya.
These end links completely fixed ALL of my issues. Now I do need to run them for while to confirm. But ZERO noise, no more clunks at all and actually better and smoother steering feel overall. So happy camper right here. Funny how much better they are actually built than the whitelines. Sure they are heavier and you need to remove a bolt (top or bottom) to adjust length. But they ARE fully adjustable and I will gladly trade that extra step for duarability any day. So far so good 😉
-SC
post #8 of 9 Old 05-31-2019
socrbob's Avatar
Quoted: 15 Post(s)
superchode, endlinks look great. Can you tell me if they would fit on a 2010 R-spec? Getting some of the sounds you mentioned.
2010 R-Spec|Tsukuba Red|Some mods
socrbob is offline
post #9 of 9 Old 05-31-2019 Thread Starter
superchode's Avatar
Quoted: 324 Post(s)
They should fit. Just need to cut the rods to correct size like I did. The mounting bolts are slightly larger diameter (about .02" larger). So in my case I just had to ever so slightly open up those upper mounting holes on the coils.... Just a little bit of back and forth with a drill bit till the bolts move freely. I did not need to open the holes on the sway bar.
But I dont know if you are running coils, lowered on springs or stock suspension. If stock suspension than the correct size OEM moog replacements may be a good option. I think 2010 actually had 2 different possible lengths for end links. So if going with an OEM replacement just want to make sure you get correct length for your car. Best just get in there and measure with wheel off. While in there pop an end off and see how loose it is and check anything else that could be causing your issue (make sure Both front wheels are off the ground as there will be tension on the sway bay with one wheel on the ground). Both sides would be same length btw. These JKS's are pretty beefy so not sure how they would treat the OEM shock mounts, so need to just be weary of that going in, as with customizing anything on these cars 😉
Andbudzi gave us the part number for these jeep links above 🙂. Dont know the Moog or OEM part numbers off hand lol
The FINAL Official 2013 Genesis Coupe Thread N2OInferno General Discussion 2576 12-17-2018 12:49 PM
Official Texas Roll Call - *Updated 12/28/2012* WildBill Texas 115 05-04-2018 05:26 AM
2013 DIY grill delete/cross member paint PICS! K.Johnson3130 Exterior 38 04-23-2017 06:00 PM
Second 2013 Genesis Coupe thread, now obsolete unless you just want to carry on OT Tigert99 General Discussion 4873 09-04-2012 05:59 AM
Benefits of RWD vs FWD... ER101160 Engine 12 06-02-2008 04:12 PM
