DIY -- Front & Rear Sway Bar Install - Hyundai Genesis Forum
post #1 of 30 Old 08-20-2013 Thread Starter
FUNCTION OVER FORM
Tufast's Avatar
As always I hold no responsibility to any damage done to your vehicle or injury incurred from attempting this as this is only a guideline on how to install new anti-sway bars. I would rank this a 1 out of 5 on difficulty with 5 being most difficult like building an engine.
With that said you will need to decide on what replacement sway bars you want to go with. I recommend adjustable bars to help fine tune your suspension. I chose Eibach adjustable anti-sway bars due to their history, the fact I had a set on my BMW 540i M that and I loved the difference they made, the fact the color matches my car well and I was able to purchase them through one of my sponsors at a good price.
Next get the needed tools together. Besides a floor jack and 4 jack stands (or a lift more preferably), you will need the following: torque wrench, 3/8" pull bar, 3/8" short extension, 3/8" ratchet (preferably air ratchet), 17mm wrench, 17mm socket and 14mm socket.
First thing you will need to do is jack your vehicle up as high as possible and install jack stands at each of the jack points in front of the rear wheels and behind the front wheels. I found that I had to jack the front up first and install the front 2 stands some of the way up then go to the rear and use the differential as the lowest jacking point in order to get the rear as high as possible, then return to the front and jack it up the rest of the way until the jack was fully extended and move the adjustable jack stands up the rest of the way. Double check to make sure all 4 stands are the exact same height left and right as well as being level front and rear.
Once the car is in the air, get under the front and loosen up the four 14m bolts holding the U-brackets that contain the bushings that hold the sway bar up. You will need the 3/8" breaker bar with short 3/8' extension and 14mm socket for this.
Once loosened, you can then move to the ends of the front sway bar and loosen the tie rod end links. You will need the breaker bar again, but without the extension. Switch over to the 17mm socket and break the nut loose. You may have to lay down and put your food on the bar for leverage and press against it as these nuts a pretty tight from the factory.
Once broken loose you will need take your 17mm wrench and putt it on the other side of the tie rod end link so that it does not spin as you remove the nut. After both nuts are removed wiggle the end links out of the swat bar and out of the way not to damage the threads.
Now finish taking out the four 14mm bolts out of the 2 U-brackets holding up the sway bar using your ratchet, extension and 14mm socket being careful not to let It drop on your head as you near the end of the bolts coming out and set the sway bar aside once out. Remove the two U-brackets as you will need to reuse them on the new sway bar.
Now get out from under the vehicle and go over to your new replacement bar. You will first need to open the lubricant that came with the sway bar kit by cutting off the tip and squeezing it on to the tip of your finger. Then take your finger and run it along inside of the new bushing. Do the same with the 2nd bushing for the other side. If you are also doing a rear sway bar, go ahead and lube those 2 bushings at the same time and set them aside. You want to do this because the lube is very messy and very sticky.
Now you can install the bushings in the same location on the new sway bars as the old bushings are positioned on the old sway bars. Then pop the original clamps over the new bushings and you are ready to put the front sway bar back up.
Align the front sway bar in the same orientation that the original was in then go ahead and start the four 14mm bolts In the brackets by hand so not to cross thread them and that will allow for the sway bar to dangle there without effort or possible injury from falling. Now go to each end and install the tie rod end link bolts back through the holes of the new sway bar.
Note that the shorter holes further from the end of the bar will give a stiffer ride and create more under steer or push in corners as well as being slightly rougher riding and less controllable in the rain. Choosing the outer holes closer to the end will help with over steer, ride a little smoother and get a little more bite in corners.
After you have snugged the nuts down on the tie rod end links using your 17mm wrench to hold them in place and taking the ratchet with the17mm socket installed to tighten the nuts down, you can go back and tighten the four 14mm bolts into the brackets holding the bushings in place that hold the sway bar up. You will want to do these a little at a time on either side of the bracket until it lines up even.
Finally go back with your torque wrench and tighten the four 14mm bolts to about 35 ft/lbs and the 17mm nuts to the tie rod ends to about 48 ft/lbs. I will check the torque specs on the Hyundai Service web site soon to confirm my suspicion on tightening torque.
Final Picture of new swar bar installed
For the rear you will not need the 17mm wrench as both sides broke loose and tightened up without anything holding the other side. In fact I did not see where you could put something on the other side for leverage. Besides with the rear spring right there, room is limited.
Loosen the four 14mm bolts as before with the 3/8" breaker bar, 3/8" short extension and 14mm socket. Break the two end links loose like you did up front with 17mm socket and 3/8" pull bar and remove the nuts, then move the tie rod end links out of the way to avoid damaging threads. If your pull bar and socket combo is too thick, then use the 17mm wrench to break it loose. Once again you may have to use your foot on the tool and your leg as leverage as these are pretty tight.
Now go back to the 14mm bolts holding the brackets in place and remove them the rest of the way with the 3/8" ratchet, 3/8" extension and 14mm socket being careful not to let it fall on your head toward the end. Now take off the 2 OEM clamps as you will need these like up front and sit the old rear sway bar aside.
Get out from under the vehicle, install the lubed new bushings in the same spots on the new anti-sway bar as the old bushings were located on the OEM sway bar you removed. Now install the 2 clamps you took from the other bar onto the new bar around the new bushings. OK you are ready to go back with the new bar. Position it in the same orientation as the original was and install your four 14mm bolts in the bracket by hand in order to avoid cross treading and to get the bar suspended out of the way.
Once semi-secure, install the tie rod end link in the holes you choose. Remember the further out the hole toward the end the smoother the ride, better in the rain and less over steer you will have. Now snug the 17mm nut down and move back to four 14mm bolts tightening them with your 3/8" ratchet, extension and14mm socket each a little at a time to seat the bar and bracket with bushings evenly. Once everything is in place you can torque down like the front with 35 ft/lbs on the 14mm bolts and 48 ft/lbs on the 17mm nuts. If you can't get on the nuts with your torque wrench, just get a feel of how tight the front ones are and try to get as close as possible using what willl fit in there.
Originally I set both front and rear new adjustable sway bars to all the way stiff, but found the car pushing in corners resulting in some forward slide with not enough turnin creating under steer. So I went back and adjusted the front sway bar to the end holes of the bar making it softer giving me a bit more bite and it helped. I like the rear stiffer anyways as I'm keen on throttle steering a car at times and I consider over steer is a friend of mine even though I'm not a drifter.
Sponsored By:
Tufast is offline
post #2 of 30 Old 08-21-2013
Paps511's Avatar
Quoted: 44 Post(s)
nice write up.
IIRC those are 29/22mm correct?
The R-Spec suspension is 25/22 and base 23/19.
Why did you pick those over whitelines at 30/27 or others with a thicker rear?
Blue 2015 Mazda 3 iSport
6sp Manual
Black 2011 2.0T R-Spec
GT3071R
392whp @ 21#
Paps511 is offline
post #3 of 30 Old 08-21-2013
inertiamonster's Avatar
Quoted: 669 Post(s)
FYI, diameter of the bar is not always indicative of the stiffness, the wall thickness of the tube used to make them is also a factor, these would still be a noticeable upgrade over stock but not as aggressive as the Whitelines.
2013 3.8 Track Pearl White
inertiamonster is online now
post #4 of 30 Old 08-22-2013
Great writeup! Im going with the white lines in a few months. I hope.
Inb42slo is offline
post #5 of 30 Old 08-25-2013 Thread Starter
FUNCTION OVER FORM
Tufast's Avatar
I researched thoroughly as always and investigated Whitelines as well and decided since I don't drift (as a hobby) I didn't need something quite that stiff. I just wanted something adjustable so that was slightly stiffer so that I could set them to my preference for DD, WW & RR. You are correct though in that the Eibachs are only a slight upgrade in stiffness vs the Track/R-Spec sway bars.
Thanks for the feedback and insight for others though.
Inb42slo, thanks for the comment, because I almost didn't do a write up on this install due to the ease of its nature. However, I thought about it and remembered that there are still beginners out there that could use this kind of early mod to get their learn on, so why not give them a guide line and I was actually asked by a member on one of the forums to do it when I got around to installing these. (I've had them for over a year waiting until I had the opportunity to put them on).
I'm probably going to install my big bore throttle body today and as easy as it will be I will probably do a DIY as I normally do for those interested.
Sponsored By:
Tufast is offline
post #6 of 30 Old 10-05-2013
Severed member
sd_davis's Avatar
MONEY! Thanks for a great write up!
- PRW FMIC & Piping kit
- CP-E differential mounts
- K&N Typhoon SRI; Forge BOV
sd_davis is offline
post #7 of 30 Old 10-09-2013 Thread Starter
FUNCTION OVER FORM
Tufast's Avatar
Sponsored By:
Tufast is offline
post #8 of 30 Old 10-10-2013
how does the eibach sway bars ride? I have the eibach springs and thinking about getting the sway bars as well.
stunnadb is offline
post #9 of 30 Old 10-14-2013 Thread Starter
FUNCTION OVER FORM
Tufast's Avatar
close to stock R-Spec/Track sway bars on soft setting and some what stiffer on stiff setting, but the nice thing is I can leave my front on soft and put my rear on stiff to allow more oversteer which I prefer since they are adjustable.
Sponsored By:
Tufast is offline
post #10 of 30 Old 10-23-2013
First off, that was a nice write-up. Very clear with nice pics. Thanks for that. I'm a proponent of modding a car to handle and stop well before you add power and speed that makes it harder to handle and harder to stop.
It sounds like you went all the way stiff on the rear and all the way soft on the front. So, that means that you can only adjust stiffer on the front and softer on the rear. Given that, do you think you might ever want to make the front softer or the rear stiffer, talking from the perspective of a DD with maybe some track time occasionally?
You also mentioned that the Eibach bars ride
so could you get away with only installing a rear sway bar in your case?
Was this on a 2.0T or a 3.8? I believe the 2.0T is about 150 lbs lighter, probably mostly in the front due to the smaller engine.
wmsky33 is offline
post #11 of 30 Old 01-05-2014
hebrewcoupe's Avatar
whiteline 30mm front sway bar
does anyone know where i can find a longer end link for my front sway bar so it can be put on its stiffest setting?
hebrewcoupe is offline
post #12 of 30 Old 01-05-2014
Quoted: 669 Post(s)
You shouldn't need longer, if anything shorter since the stiff setting is the inside hole on the bar. Front or rear?
post #13 of 30 Old 01-05-2014
Whiteline 30mm front sway bar
Yeah that makes sense to get a shorter one. It's my front sway bar. Do you know where I can find a shorter end link? Thank you
post #14 of 30 Old 01-05-2014
post #15 of 30 Old 01-06-2014
Quoted: 669 Post(s)
Do a Google search for 'Powergrid Endlinks', the make adjustable front endlinks for our car, but they aren't listed on their site, you need to email them.
jesse82nc likes this.
post #16 of 30 Old 01-06-2014
Great thank you I will do that!!
post #17 of 30 Old 02-11-2014 Thread Starter
FUNCTION OVER FORM
Tufast's Avatar
You also mentioned that the Eibach bars ride so could you get away with only installing a rear sway bar in your case?
No, I actualy tried it with the front stiff as well, but the car pushed in corners more than stock so I went back to the softer setting which is perfect for my driving style and I feel will do well on the road track.
Sponsored By:
Tufast is offline
post #18 of 30 Old 02-11-2014
Cool. Thanks. I will be using this DIY as my manual when I install my sway bars.
wmsky33 is offline
post #19 of 30 Old 04-12-2014
...4, 3, 2, 1
AMBCoupe's Avatar
Quoted: 253 Post(s)
Great write up! :thumbup:
Installing my Eibach sway bars today or tomorrow.
2010 Acqua Minerale Blue
2.0T 6MT
Ultimate Racing SRI
Ultimate Racing Down Pipe / Test Pipe
CPe Catback
TurboXS RFL-cold side
AP Clutch Line
Uniq Rigid Collars
Eibach Sportline
Eibach F/R Sway Bars
OEM Strut Bar
BBM Spoiler
JCS Pod
ProSport EVO Boost & Wideband
'13 clutch
Megan tranny mount
Varrstoen ES2 (white)
255/35/19x9.5 +22
275/35/19x10.5 +22
-Built by 10Fintec
-Tuned by BTR
AMBCoupe is offline
post #20 of 30 Old 11-08-2014
Quoted: 50 Post(s)
UPDATE:
First of all, thanks for the write up. I used this to install my front 30 mm whiteline swaybar on my 2013 GC 2.0 base manual transmission.
Everything in this guide was accurate for my car except the end link nuts require a 19 mm socket, not a 17 mm. I'm not sure if it's the year model of the car or the trim that made it different for my car versus the OPS car.
Car feels awesome, I put it on the stiffest setting from the get go and I ain't turning back, loving it.
I stripped one of the bottom ending nuts a little bit since I didn't have a 19 mm socket, so I had to improvise a little. Anyone happen to have the part number for that nut? Or the specs so I can buy one at home depot or something? Thanks
DanceswithTurbo is offline
2013 GENESIS COUPE R-SPEC front & rear sway bar with bushings SteelyDan Suspension 0 07-06-2013 12:23 PM
DIY: GarageLine R-Spec rear sway bar installed on 2013!!! RustyHooks Suspension and Wheels 14 04-02-2013 03:28 AM
NEW PRODUCT!! Whiteline FRONT + REAR ADJUSTABLE Sway Bar!! [email protected] Suspension 39 06-22-2012 11:45 AM
Sportline Springs and Front and Rear Sway Bar Pics revcity Suspension 2008-2012 24 04-11-2012 04:12 PM
[GenRacer] Eibach Front & Rear Sway Bar Kit Special! GenRacer Support Suspension 10 09-23-2009 06:25 AM
Tags
diy , genesis coupe , suspension , sway bars , tufast
