1 - 20 of 130 Posts
Vendor
Thanks for all the support, I'm able to reduce prices.
Depo Racing Genesis 2.0t O2 housing. This is one of the best places to start on the genesis to make power. Its a pain to install so if you buy a poorly made one with bad welds, cheap stainless and flanges you will be replacing when it cracks.
- 2009- 2012 2.0t
- 3 inch Straight through design (test pipe) eliminates restricted cat section.
- 2 bungs ,one extended with small hole to avoid cel lights – sensor cant get bad smog reading
- Direct bolt on fitment
- Gaskets included.
- 304 stainless steel
- 10 mm thick flange
- See more at: 2008-12 Genesis O2 Housing | Depo Racing
yoooooooooooo
Any way I can get this shipped without a direct signature required? When I ordered the DP/TP it needed a direct signature and I had to sit at home all day waiting for it. Thankfully I didn't work that day so I could do that but it still sucked to sit at home all day.
Vendor
Discussion Starter #12
after fedex makes the first delivery attempt and leaves a tag call the 800 number and have them drop it off at the nearest
fedex office or fedex kinkos office, then go scoop it up when you can.
1 - 20 of 130 Posts
