1 - 20 of 71 Posts
Doing my 2nd LS swap and figured I would document the progress and help the community at the same time for those who might choose to go down the same road. All OEM functionality is retained, including tach, temp etc. I'm midway through the swap, so I'll update as I go along.
**Disclaimer** I realize that this is not for everyone and not everyone is receptive to an LS swap. So if you feel butthurt, please move along and refrain from crapping up the thread.
Alright, with that out of the way....here we go. I will be using the Enjuku swap kit and headers, forged bottom end, ported heads and an LSA blower.
The patient
The donor. A 2007 LQ4 w/ 300k miles :grin: After selling the parts from it that I didn't need it was free.
A little filthy....actually it was a little more than filthy.
Stripped down and filthy
A little cleaner
For a 300k mile engine it was surprisingly clean on the inside. I imagine since it was a work van they probably kept up on the maintenance to some degree.
Block tore down and ready for the machine shop.
Time for engine to come out of the gencoupe. 29k miles on the clock.
aaaaand it's out
Gaping hole >:D
Sold the engine. Palleted and ready to be picked up
to be continued once mod approves thread.......
Discussion Starter #2
moving on.....
Truck harness blue/green deloomed or is it unloomed?
Keeper pile that will be made into a usable harness
Extra wires that will be discarded. Lot of extra stuff for 4WD and automatic transmission and other random stuff
Gencoupe harness waiting to be taken apart
All looming and tape removed. I will depin and remove all engine related wires with the exception of coolant temp and crank position sensor.
Lesson learned from previous swap...easier to depin leaving the body harness in place and reloom when done.
Enjuku swap kit showed up, headers and all
Pistons and rods also showed up....forgot to take pictures of the rods but I went with 6.125" Callies H-Beams
Another pile of parts......I need them gone lol...I have stuff all over the place.
got the block back from machine shop...skipped a few steps but reassembly is not that interesting anyway. Bored 0.030 over, decked, line honed, opened oil passages up for additional oil flow etc etc. Compression should be right around 9.8:1 using LS9 gasket 0.051 thickness.
Block cleaned up real nice
As of today I'm waiting the heads and cam to show up and then on to actually start wiring some stuff and getting the transmission and engine into place.
Can't wait to see that beast and especially those headers in that gaping hole:grin:
Reactions: mille_3
I'm really Asian
nice. how are you getting all the factory stuff to still work? I'm no wiring genius at all, so how hard is it to convert the harness?
Wiring looks overwhelming, but it's pretty simple if you can read an electrical diagram. I eliminate all the engine related wires and keep the rest.
The tach is run off a trigger wheel mounted to the balancer.....although this time around I might try to fit one in a similar location to the genesis in the transmission housing. The temp gauge is mounted in the opposite head. This will require running both the genesis ECU and the GM ECU.
shorttrack
FN OUTSTANDING job sir ,outstanding !!!!! .That's what I'm talking about , out of the box thinking and the execution of whatever it takes to get sh!t done . Shorttrack USMC . I like it !!.
Reactions: mille_3
Awesome build and great thread. How do you plan to tune it?
Discussion Starter #9
Haven't gotten a whole lot done with the holidays and an unexpected surgery that I'm recovering from, but engine mounts are installed and heads are back from cnc porting with new stainless intake and exhaust valves along with dual springs good for .660" lift
Hoping to have the engine put back together in the next couple of weeks and start routing the wiring.
I'm also pulling up a chair to see this girl come to life. Thanks for sharing a quality build with tons of information now and to come. Good luck with everything and God speed with your recovery.
Discussion Starter #12
Thanks I appreciate the kind words. I'll update my first post once she's running with a parts list and wiring diagrams and such to help others achieve the same thing, should they choose to.
Subbed. I honestly had no idea that Chevy vans used LS engines lol.
Reactions: Jttwin1
Discussion Starter #15
progressing slowly. Still trying to source a blower for a decent price, so doing what I can in the meantime.
Cam showed up
So the newer iron blocks don't have a provision for the chain tensioner, but trickflow has a neat solution
ARP hardware
Block assembled
Discussion Starter #17
Thanks. Getting closer and once I have the blower I can start wiring. I have the genesis harness ready to go, just need a few more pieces on the GM side to finish routing wires. It's all downhill from there though.
Looks very interesting..... Subbd
TJ
2013 Gen Coupe Track 6sp
Man I have always wanted to do this since I bought the gencoupe. Couple questions. First where did you post your engine for sale, Craigslist? Second are you going to have hood clearance for a blower? And third did you ever think about an Ecoboost 3.5l engine (There are alot out there)?
AHHH!! This is just what I needed. That wiring does look like hell. Not sure how I feel about taking that on. Subbed! Looking to start my own LS project within the year. Probably next winter. I did just find a van with an old LS in it for $350.
1 - 20 of 71 Posts
