After accidently posting in the V6 dyno sheets thread I figured I'd make one for the 2.0T. Searched but didn't see one yet, if I missed it, sorry. Stole the layout for the results from Formsim
HP - 224 Tq - 269
1. Type of Dyno: Dynojet
2. Gear used : 5th
3. Temp : 52 degrees
4. Elevation: ~500'
5. Mods: Dynojet CMD @ 20psi peak trailing to about 14 at redline and CP-E Intake
Will update in a week or two. I got exhaust, boost controller, injectors, and actuator since then. Should break 250whp hopefully.
Hmmm, tweak that some more and you can probably get another 30 Lbs of torque with the same Hp. Check out BR's thread on their custom tune making slightly better results. I already have a PA flasher so that's the best route for me. Good job though on the tune.
Here are some more dyno sheets I've downloaded as I've seen them posted. If one of them is yours and you want it removed or information corrected, just let me know. Obviously I don't have full details of these ones but I've posted what I had noted.
wow allmost everyones loses power between 3-4k and i found one on the internet that was at ATPTURBO with their aftermarket actuator and it seemed to fix that and if they want me to remove this just let me know i will be more then happy
ON that dyno I was running the 18psi map from PowerAxel. Plus it was done on a Dynapack dyno. IF anything my #'s are higher or lower than what is listed if it was done on a Mustang dyno. The tq shows that is low but trust that I know my car producess more tq than listed.
Oh ok, I don't have much experience with dyno's I know that certain ones read different than others but that is the extent of my knowledge with them. I use to in the driveway then make passes down the road with my a/f gauge, adj SAFC ect, never dyno'd one of my cars.
Hi guys i have some issues getting my car tuned right and i need some help with some information and maybe someone here can point me in the right direction. So here is the deal :
The genesis coupe tuning scene here in sweden in non existent, there are 160 bk1s and 50 of them are 2.0t and i...
Because no one wants to approve my build thread, imma post here.
Last thing I worked on was the head I think a year ago.
ate away at the head in the lobe travel areas to allow my tomei 11mm lift cams to fit.
I made a jig out of some pipe, a dremel, and some nylon spacers.
I still have to...
so imma order my 2.0t pretty soon from the dealership, its going to be a daily/track car. target horsepower is mid 500s and i have blue printed the rb26. but can i make that kind of numbers with the 2.0t?
I just installed my HKS bov on my hot side by my turbo. Everything was going well and sounded right. I could hear my air intake and it had a higher pitch so that was cool. A few days passed by and instead of my intake making a noise it switched to a flutter noise or pigeon noise. It been making...
