I have a 2010 2.0t and I have saved up a good amount of cash to start doing engine modifications. I was just wondering where i should start...I was thinking of going with either the Forge or Synapse Blow Off Valve and the K&N Typhoon Air Intake. Are any other mods recommended for the start? I eventually want to put a Garret GT3071R but not quite yet.
Should I get the PA reflash as my first updrage with a SRI or a CAI...i think im going to go with the turbo back next from Exceladyne
LS1 Swap!
Enthusiast
If you can do it all at once look at the stage kits from companies like BTRcc and others. This will give you a good gauge if you want to piece it out for what is required.
I pieced mine together and started with a canned tune, tbe, cai, gauges. This is basically a stage 2 without a fmic. The next stage for me similar to you is a turbo upgrade. So to get me to a full stage 3 that would be turbo, injectors, fmic and retune.
Try to do things that will save on retunes. It's always an added cost depending on what your doing.
