Turbo-ing a non turbo car is a lot more involved than a turbo upgrade on an already turbo'd car. The factory turbo car is already designed (especially the world engine) with boost in mind, so there is a lot less likelihood that things will break under the strain.
Also, Factory turbo'd cars are already running lower compression, so it is much easier to turn the boost up than to have to run low compression pistons in a N/A car since that would require (at the very least) dismantling the top end of the engine, and more than likely pulling the engine entirely.
Now that is not to imply that you cannot run boost with higher compression setup, you just can't run nearly as much boost before you start seeing detonation issues and you have to upgrade to race gas/alcohol/etc...
Now, supercharging a V6 is considerably easier than turbo-ing one, as there is nowhere near as much plumbing involved. If you buy a kit to do it, it really can be an almost bolt on affair to get it installed. In fact the Sniper kit from NGM for the V6 Tiburon was literally a bolt on affair that would net you some very decent numbers.
