1 - 1 of 1 Posts
I am having some trouble finding some parts I need to fix this issue I have been having. The car has a fault in the tcm/transmission control module, in which the reverse lights are not working. This has caused my car many problems, sometimes I can start my car right up and it will drive normally but with a check engine light, other times I will start the car and I will have the abs light, parking brake light, check engine light, tpms light, and traction control light on. When this happens and my car has all these lights on I can not put my car into gear at all unless I use the bypass next to the shifter. I also have had the car go into limp mode a couple times and I was stuck inside 3rd gear. I took my car to my mechanic and he told me to get another tcm due to the electrical problems within the one I have right now.
1 - 1 of 1 Posts
