1 - 5 of 5 Posts
Hi I am new here. I have a 3.8 coupe with p0018 code bank 2 sensor a out of sync. dealer replaced drivers side ovc valves intake and exhaust. Light still on. has zero power like out of time. if i restart the car with drive great with plenty of power then reverts the bog again. any idea's? can tensioner? loose timing chain? other sensors cause? did dealer replace wrong side ocv for p0018
I would check actual valve timing.
This will tell you if the there is something wrong with the cvvt, chain, or something else with the timing.
with 94k miles, I would think its a worn chain.
1 - 5 of 5 Posts
