1 - 11 of 11 Posts
I recently bought a btr tune and as soon as I put it in and drive around I get a cel for p0170 and p2192 but I can put my stock ecu in and no codes will come up after driving for a while. I have fmic, bov, turboback exhaust, and aem cai. Is the tuned ecu messed up? I figured if something was actually wrong it would show up on my stock ecu as well. My car rough idles and will stall out with the btr tune and I tried cleaning my o2 sensors which didnt help at all. Thanks in advance
Are you saying the car runs fine without the BTR ECU ? If so maybe you got the wrong tune. If not it's possible your spark plugs or something isn't optimized for the tune
Are you saying the car runs fine without the BTR ECU ? If so maybe you got the wrong tune. If not it's possible your spark plugs or something isn't optimized for the tune[/QUOTE]
It runs fine without it yeah but it's just a canned tuned and everything matches to what I needed. Bk1 turn key 91 octane auto trans
I would try another ECU if your octane is correct. I doubt spark plugs or A/F ratio would be that bad if it runs without the canned one. Also how old is the tune? Maybe the ECU itself is just a poor one for your car. Also do you know if the TCU (transmission) is tuned?
IG: jasonlikedthis
Did you do the key dance?
Im not sure if the tcu is tuned. I bought my car from someone who was paying from a dealer and they didnt know if it was already tuned but I'm pretty positive the ecu that came with the car when I bought it is tuned but the btr tuned ecu is much more responsive and fun to drive so I havent wanted to give up on it just yet
Discussion Starter #11 (Edited)
No, I was just curious about the driveability while moving. Rough idle is tune related and sometimes a vacuum/boost leak.
I saw another thread on here with the exact same codes after he got a tune and it was because the tune wasnt set up for his injectors which I have no clue if I have stock injectors or not but I'm gonna look after work so maybe that's the problem. whoever owned the car before me did a lot of work to it so it wouldnt surprise me if he put in aftermarket injectors
Also the ecu that come with it isnt stock after I read some things on the obd2 it was installed in Oct 2017 and has a different serial number. That would explain why my cel doesnt come on for my exhaust set up
1 - 11 of 11 Posts
