My car was running fine till I installed the mishimoto intercooler. Can someone help with any tips? I made sure to tighten all the clamps. When I press the gas the car struggles to make it to 20 mph. Any ideas ?
The car is likely in limp mode.
If I have to guess, something happened with the ambient temp sensor or the air intake temp sensor.
I forgot where the ambient temp sensor is, since I've moved mine.
It's either clipped to the crash bar, or the center vertical support in front of the radiator/condenser.
The air intake temp sensor is on the intercooelr pipe closest to the throttlebody.
Disconnect/reconnect them, then you're going to want pull codes to make sure it isn't something else. Clear codes and then see if it's fixed.
