2011 2.0t Turbo Noise
1410 Views 3 Replies 3 Participants Last post by  krisdadto3
Hi all, there is a similar post out there of someone having this same issue but they were running a non-stock turbo unlike me. There is a rattling/grinding noise between 2000-2500rpm that is specific to that rev range, regardless of gear. It sounds like it is coming from the turbo side of the engine bay and based on how similar the sound is to the one in the video I found, I am assuming it is a similar issue. Attached is the video from the other thread I mentioned as well as a video of my own.
Video I was referencing:
Video of my car making the same sound:
2011 Genesis Coupe 2.0t Turbo Rattle
Any insight would be great, I didn’t want to poke around with stuff too much as the car makes boost and drives fine and it is my daily and only vehicle at the moment.
Sounds like a pulley. Mine does this too. Do you have a cold air intake? Are your lines connected properly to it? Also check the radiator fan frame work support bolts. The after market cai kits have you bolt into it for support. These bolts fail and you need to use a bigger size with some super glue. This almost sounds like the fan framework rattling
mine makes the same noise, 2010 2.0T with K&N cold ait intake, its really starting to irritate me, has anyone figured out what this is yet?!?!
my shop said flywheel. Nothing worry about, it’s normal
