So I'm having issue with my driver's side headlight. I've blown two hid ballasts and a led bulb on that side. Only the low beam does not work. As of today, I've added a new hid harness and a new hid kit. Took the driver's side headlight and plugged it into the passenger side to make sure the headlight wiring is ok. Checked the module 3 fuse inside the car and the big fuse under the hood I think it was b+3 and b+4, both good. What else could be causing the malfunction? Any help or tips are appreciated. Thank you.
