Bought this genesis coupe (used) drove maybe an hour and a half back home and engine blows white smoke and “sparks” on highway, I pull over check under the car and oil is leaking slightly above the oil pan then tow it home. Next day I take check oil which is black but no metal shavings and will not crank over. I’m making this thread just asking for some guidance or help on what’s the best way to get this car running again at an affordable cost because engines are upwards to $5k rn and the gencoupe store has rebuild kits for $800-$1600. I’m pretty new to Hyundai but I am willing to learn anything mechanical. Please help.
Edit. Oil light turned on, boost gauge started reading weird, steering wheel locked up, and power to pedal was cut when this happened.
