1 - 14 of 14 Posts
Vendor
Depo Racing Genesis 2.0t O2 housing. This is finally done, I have not seen anything close on the market, the cast bellmouth is the best for the extreme turbo side glowing heat. This attaches to the HOT side of the turbo, this portion of the turbo glows red. Cast has no welds that can break after repeated high and low temp changes, this is why cast is best , plus its just has superior flow. Of all the parts I make, only 2 parts I would say are better then anything else made, not equal too, better, this is one.
– 2013+ 2.0t
– 3 inch Straight through design (test pipe) eliminates restricted cat section.
– 2 bungs
– Direct bolt on fitment
– Gaskets included.
– 304 stainless steel
– 15 mm thick flange
- See more at: Depo Racing
1 - 14 of 14 Posts
