I am in desperate need of help and expertise. My 2013 Genesis Coupe has begun "hard shifting", only when upshifting. For example, if I go from 2nd to 3rd, its delayed and jerks hard into gear, furthermore from 4th to 5th, it does the same thing shifts "hard" into gear. The action is quite erratic. I believe the problem is a faulty shift solenoid?
All other gears are fine, so it leads me to believe it may not be mechanical.
Has anyone else had this problem?
Can it be the ECU?
Is it the shift solenoid?
Can it be the ECU?
