Battery died while driving, I replaced the battery, and it ran for a bit but battery would die, then I tested the alternator, said the voltage regulator failed, so I replaced the alternator, voltage regulator failed again, so then I got another new alternator, voltage regulator failed again, car would run alright but had less power, once the battery got low lights would come on and displays would turn off, once I charge the battery it will run but the alternator is not charging the battery, can’t figure out the issue, maybe the wiring harness is faulty, any help would be great.
The negative one was corroded but I cleaned it out with warm water and baking soda and a wire brush, should I just replace it completely?
