1 - 20 of 74 Posts
Will start the tread unless something explode on version 3 should be running soon lol
Yes it does work
first testing phase
was hiding the project in a magarine bucket oh yeah
it did work fine for a while but arduino doesn't like to work that much over 12V
but it did work fine on my earlier use for other project
next build as a dc-to dc converter
i called some part for Version 2
but while waiting for it i saw much better so order version 3 lol
i built a plug and play extension to do the jobs outside the car and just plug it once in the car
first try was in 20 AWG but it doesn't do a good job
so redid the work in 22 AWG
Car wire is 28 AWG
you can only find one connector with pins the other gender only exist to fit on a board..so i had to improvise
Discussion Starter #2 (Edited)
the difference between BK1 and BK2 AC circuit
BK1 when you push the AC button it's hard wire to the pcm that when all condition are met will engage AC clutch
BK2 when you push the AC button ...to module send it request to the pcm via CAN BUS
when the pcm say it's ok hey send the info thru can bus
then the AC module will send a pulsed signal to the AC solenoid to start AC
Discussion Starter #3 (Edited)
CAN BUS info
sent by AC module
350 XX 10 XX XX XX XX XX XX : all off
350 XX 18 XX XX XX XX XX XX : AC off Fan on at low
350 XX 58 XX XX XX XX XX XX : AC off Fan on at high
350 XX 1B XX XX XX XX XX XX : AC on Fan on at low
350 XX 5B XX XX XX XX XX XX : AC on Fan on at high
for some reason the pcm read fan setting ...haven't seen any change about it in the haltech so will just get rid of that signal
the pcm reply with
316 05 XX XX XX XX XX XX XX : stop AC
316 45 XX XX XX XX XX XX XX : start AC
i saw one time 75 instead of 45 but 45,55,65,75 will start it anyway
but for some reason the ac module will not start AC with only the 316 45 XX XX XX XX XX XX XX : start AC
it need to have adress 329 and 18F present on the CAN BUS present whatever the data...probably a safety thing
but all this is irrelevant for the fix
Fix how does it work
the arduino read the can bus...if 350 adress data become 1B or 5B is change an output state ...to tell the haltech holla AC request
when AC is ok to start haltech will switch his output to advise arduino
arduino then start his pulsed output and drive the AC solenoid
having fun again
removing version 1
installing Version 3
but for some weird reason digital input don't activate AC request $%^* but they dont work for some other stuff
tried all input
finnaly endend trying the pulsed input....seem's to be working ...most of the time...talked to haltech about it will see what they say
that was the original idea...now wire have been moved a bit
like i said this work..
but not this
arggghh
Current arduino program
Sebastien Moreau at [email protected]
used
Hobbytronics Leonardo CAN-BUS board
Receive Test Data and set filters on ID
Send output data via serial port
Leonardo CAN BUS product page Leonardo CAN BUS board | L-CANBUS | HobbyTronics
Hobbytronics.co.uk
For mcp_can use this library https://github.com/reeedstudio/CAN_BUS_Shield
download the ZIP at the right of the screen
and insert what IN the zip folder into the library
rebbot arduino software
#include <mcp_can.h>
#include <mcp_can_dfs.h>
#include <SPI.h>
unsigned int rxId;
unsigned char rxLen = 0;
unsigned char rxBuf[8];
volatile unsigned char canData = 0;
int AcReq = LOW;
int AcInputValue = LOW;
int Pulse=0;
int AcMem = LOW;
MCP_CAN CAN0(17); // Set CS to pin 17
void setup() {
// put your setup code here, to run once:
Serial.begin(9600);
CAN0.begin(CAN_500KBPS); // init can bus : baudrate = 500k
attachInterrupt(4, can_receive, FALLING); // Pin D7 is Interrupt4 on Leonardo
Serial.println("MCP2515 Library Receive Example...");
pinMode(6, OUTPUT); // AC request status
pinMode(8, INPUT_PULLUP); // AC status input
pinMode(9, OUTPUT); // Variable output for AC solenoid
analogWrite(9,0);// AC solenoid to 0V
pinMode(23, OUTPUT); // Led output activation
// Basic Filtering on ID
// Bytes 1 and 2 of mask/filter apply to ID
// So the Mask and filter below will only allow ID 0x350 through
// ---- ID -----
CAN0.init_Mask(0, 0, 0xFFFF); // 1111 1111 1111 1111
CAN0.init_Filt(0, 0, 0x0001); // 0000 0000 0000 0001 - FAIL
CAN0.init_Filt(1, 0, 0x0001); // 0000 0000 0000 0001 - FAIL
CAN0.init_Mask(1, 0, 0xFFFF); // 1111 1111 1111 1111
CAN0.init_Filt(2, 0, 0x0001); // 0000 0000 0000 0001 - FAIL
CAN0.init_Filt(3, 0, 0x0001); // 0000 0000 0000 0001 - FAIL
CAN0.init_Filt(4, 0, 0x0350); // 0000 0011 0101 0000 - ACCEPT
CAN0.init_Filt(5, 0, 0x0001); // 0000 0000 0000 0001 - FAIL
void loop() {
// put your main code here, to run repeatedly:
if(canData)
canData=0;
CAN0.readMsgBuf(&rxLen, rxBuf); // Read data: len = data length, buf = data byte(s)
rxId = CAN0.getCanId(); // Get message ID
Serial.print("ID: ");
Serial.print(rxId, HEX);
Serial.print(" Data: ");
for(int i = 0; i < rxLen; i++) // Print each byte of the data
if(rxBuf < 0x10) // If data byte is less than 0x10, add a leading zero
Serial.print("0");
Serial.print(rxBuf, HEX);
Serial.print(" ");
Serial.println();
//Evaluate AC request status ON or OFF
switch (rxBuf[1]) {
case 0x10:
AcReq = LOW;
break;
case 0x18:
AcReq = LOW;
break;
case 0x58:
AcReq = LOW;
break;
case 0x1B:
AcReq = HIGH;
break;
case 0x5B:
AcReq = HIGH;
break;
if (AcReq != AcMem) {
AcMem = AcReq;
Serial.print(" AcReq ");Serial.println(AcReq);
digitalWrite(6, AcReq);
digitalWrite(23, AcReq);
} // end if
// Read Haltech output and put AC ON or OFF accordingly
if (AcInputValue != digitalRead(8)) {
AcInputValue = digitalRead(8);
Serial.print("ACInputValue ");Serial.println(AcInputValue);
if (AcInputValue == HIGH) {
for (Pulse=200 ; Pulse >=0; Pulse--){
analogWrite(9,Pulse);
delay (3);
else {
for (Pulse=0 ; Pulse <=200; Pulse++){
delay (10);
void can_receive()
// CAN Receive Interrupt
canData = 1;
Looks like youve figured out a way to make pretty much a plug and play solution?
Id definitely be interested if this lets 2013 guys dabble with Haltech with no negative connotations or loss in drivability (AC is a must here).
Discussion Starter #8
i will see what haltech will repond about these input not working with AC activation
my first setup was using a boomslang extension so it was using PCM pin ...but boomslang is pricy $$ around 500$ just for the extension
so i was looking for something that somebody without the extension could still work with
will see how this pulsed input behave on the long run
Discussion Starter #9
doing some debugging for some reason it doesn't start all the time on the first start in the morning
so did some self test in the routine and some nice text to help decipher what is happening
Discussion Starter #10
new version of code for computer wiz lol
used
Hobbytronics.co.uk
#include <SPI.h>
unsigned int rxId;
int AcReq = LOW;
int Pulse=0;
int AcMem = LOW;
long CommCheck1 = 0; //check if communication is working if not do a reset
long CommCheck2 = 0;
void setup() {
Serial.begin(9600);
pinMode(6, OUTPUT); // AC request status to send to haltech
pinMode(8, INPUT_PULLUP); // AC status input to read haltech AC confirmation
pinMode(23, OUTPUT); // Led output activation mimic AC request
// ---- ID -----
void loop() {
//*****************Check if comm is operational if not do a reset***************************
++CommCheck1; //increase loop counter and check for comm fault if no comm then reset comm port
if (CommCheck1 == 200000) {
CommCheck1 = 0 ;
if (CommCheck2 == 0) {
CAN0.begin(CAN_500KBPS); // reset comm port
// ---- ID -----
Serial.println("Had to reset comm port");
else {
Serial.print("Comm port is OK received X amount of data: "); Serial.println(CommCheck2);
CommCheck2 = 0 ;
//*************************End of comm check*****************************************
//************************If data is received treat it********************************
if(canData)
canData=0;
++CommCheck2; // increase if data is receive
Serial.print("0");
Serial.print(" ");
Serial.println();
switch (rxBuf[1]) {
case 0x10:
AcReq = LOW;
break;
case 0x18:
AcReq = LOW;
break;
case 0x58:
AcReq = LOW;
break;
case 0x1B:
AcReq = HIGH;
break;
case 0x5B:
AcReq = HIGH;
break;
AcMem = AcReq;
Serial.print("AC demand from car 0 NO, 1 YES: ");Serial.println(AcReq);
} // end if
//************************END of received data treatment***********************
//************* Read Haltech output and put AC ON or OFF accordingly************************
//*** max pulse is at 200 that give around 10V that is what i have seen on stock system***
Serial.print("AC confirmation from haltech 0 GO, 1 take a brake: ");Serial.println(AcInputValue);
delay (3);
else {
delay (10);
//************End of input and AC driving**********************************************
void can_receive()
canData = 1;
I have been reading through your post and code (good work btw). This might be a dumb question, you are just creating a conversion of the signal to the Haltech to output to the A/C to turn on? Couldn't you just bypass PCM communication and have the A/C switch directly communicate to A/C with Arduino?
Discussion Starter #12
pcm need to be in the loop...
since AC shut down in certain condition mostly in high rpm and high load
and AC pressure sensor goes to the PCM
and you can have different table in the haltech depending if you have AC on or OFF
Got it, out of curiosity why Haltech?
Discussion Starter #14
didn't find anything that would do the trick
most poeple were not able to tune bigger injector on stock pcm...it changing now
my first choice would be to reflash stock pcm...but not an option yet
I am in the same boat wanting to reflash stock PCM. The custom tunes that are being offered are different PCM units? I'll probably get more serious about extracting the ROM off the PCM when I get full bolt ons etc.
Does the Haltech come with a base fuel map for the Gencoupe?
Every car is different and perhaps the 'safety margins' of the tune may cover all gencoupes, but I am not convinced that this is the way to maximize efficiency/tuning on these cars (although they have been somewhat proven, I like having control of what I am tweaking).
Discussion Starter #16
you can get a custom tune on stock pcm if you send your
but the ROM definition is not open source..i think el domino gave on that working on win OLS was not perfect but was a good beginning
after that you need the tool the write into the pcm via the BDM port
yes haltech as a base map...for 2012 ...
you have to rescale map and tip and injector
after that your good to go...
my biggest problem ..(i'm no tuner just a electrician) is idle on startup and when AC kick in and out
and at some point you just want to drive lol...so the issue at start up are there for a couple seconds on a cold engine the rest is fine so i said good enough..for now lol
in my case a bought an haltech O2 wide band ,,that kinda helped...it's not auto tune...but since it's always there it help to tune
Discussion Starter #17 (Edited)
here is some of the part
arduino case 10.23 can$ + shipping
Box for Arduino - RobotShop
was an arduino originally so stuck with it
digistump mosfet kit DSK-0007
newark/element 14 part 87W9363 7.03 can$ + shipping
DSK-00007 DIGISTUMP More Tools & Production Supplies | 87W9363 | Newark element14 Canada
or here
Mosfet Kit - Digistump
but they seem to be always out of stock at digistump
the brain leonardo can bus
34.52 euro + shipping
pin for connector ..around 100 unit ...better have some spare lol
17.20 can$ for 100
1318143-1 TE Connectivity | Mouser
AC male connector
2.93 can$
1318389-1 TE Connectivity | Mouser
AC femel connector
9.68 can$
1376113-8 TE Connectivity / AMP | Mouser
Haltech aux connector
2.74 can $
1318386-1 TE Connectivity | Mouser
Wire ,, 20 awg a started with that but it's way to big for the connector
40.08 can$ for 100 feet
could probably all do it in 24
3053 BK005 Alpha Wire | Mouser
wire 24 awg neccessary for the connector... probably the only one needed...for a DIY
31.77 can$ for 100 feet
3050 BK005 Alpha Wire | Mouser
the dc to dc supply LM2596S
****ing cheap lol
http://www.ebay.ca/itm/1pcs-LM2596S-Power-DC-DC-Buck-Converter-Step-Down-Module-5V-3A-LM2596-/271351841796?hash=item3f2dd48404
and some 1/8 heat shrink with glue ...that i took locally
that about it for part
Discussion Starter #18
Ok building process
wire extender
you need 32 * 6 inch 24 awg jumper with pins on both end
you need some small needle nose plier to crunch pin flat..you can use the cutter of the plier to squiz it firmly...make sure it hold's firmly
then you insert all the wire except 34 and 35 than don't need to cross over (* indicate empty spot)
the pin need to be well crimp specialt side to side other wise it will be fun to insert into the connector
3 time 6 feet ddepending on your pcm location under hood it a bit short
WARNING this one show connector from back...previous was from front
you use tape/abrasion tape/loom or what ever
don't forget to mark you wire
you need 34* 1 1/4 (approx) heat shrink tube
insert the pin in the facing connector...start with the row with the most wire
make sur your connector is in the right position ...doh
push the shrink all the way, making sure not to cover the pin on the other side...
do the same thing on the other side and add the 2 solenoid wire (around 18 inch)
it should look like this
now heat gun time...do go to crazy and melt the connector
for extra safety i used a glue gun and jamm everything in there
after that use a sharp knive to remove 3,12,13,39 insulation....not your finger ....yes i did it ok ok
use 3 wire 18 inch and insert them in 12,13,39 and twist
i used the 34 solenoid wire and pass it thru and twist into wire 3 (power)
weld everything
use some real tape..not the cheap stuff..much better
mark the wire and tape them together
i you have 5 wire your good to go
Discussion Starter #19 (Edited)
weld the mosfet parts
weld some wire on the dc to dc converter
make it look good
find a 12V source ..a battery or a booster pack is good enough lol
and adjust the dc to dc converter to 5V output
Discussion Starter #20
time to start welding those wire
wire from the car
39-ground goes to gnd
3 hot in start (we used the wire into 34 and welded it to 3) goes into V In
35 goes into out
the P5 wire will go to D9 of the arduino
from car
12 (can low) goes to canL
13 (can high) geso to canH
for dc to dc regulator (adjusted at 5V)
out+ goes to V+
out- goes to 0V
from haltech connector
DPI1 (7)goes to D6
DSO1 (13)goes to D8
ground (12) goes to GND
the P5 from mosfet goes into D9
final welding
you need you weld theinput from the Dc to dc converter
in+ to Vin
in- to gnd
1 - 20 of 74 Posts
