1 - 20 of 250 Posts
2013 Stock Nav Hacking Thread
The more discussions and findings have been discussed in the 2010-12 thread a 2013 specific repository is needed. This thread will serve that purpose.
***NOTE: This is a WORK-IN-PROGRESS especially currently in the early stages. I am trying to credit the original members that researched and found posted data referenced. I apologize for anyone not mentioned either as of yet, or due to missing the author info. If I am missing any of this data please let me know so I can update.
2013 Stock Navigation Details
Excerpts from Tom's Hardware Article: "Hyundai Genesis Coupe 3.8 Track: Telematics And Infotainment..."
Tom's Hardware Article said:
  • 7" resistive-touch LCD
    • 800x480 resolution
    • 24-bit color support
  • Navigation with SiriusXM traffic data
  • CD Drive
  • Concealed connectivity hub at the bottom of the center stack
    • USB port
      • USB media playback (system reads files and folders)
      • Apple iPod (requires Hyundai dock connector)
    • 1/8-inch auxiliary input
  • HD Radio support
  • SiriusXM support
  • Voice recognition
  • Phone connectivity via bluetooth
  • Texas Instruments OMAP3530 system-on-chip (SOC)
    • Single ARM Cortex-A8 (based on ARMv7 instruction set)
    • Operates at 600 MHz
    • IVA 2+ advanced imaging, video, and audio engine
      • Contains TI's TMS320C64x+ DSP core for MPEG-4, H.264, and VC-1 decode acceleration
        • Hyundai's system doesn't expose that functionality
    • PowerVR SGX530 3D graphics engine
Engineering Mode
TIP: I recommend using a stylus pen for accessing and/or navigating any of the hidden modes. It makes it a lot easier.​
Accessing Engineering Mode: Thanks to Ryengoth
  1. Go into FM or AM radio mode.
  2. On the screen tap the top right 1x time. (aprox 1/8th inch away from the corner)
  3. On the screen tap the top left 6x times. (aprox 1/8th inch away from the corner)
  4. Engineering Mode should open.
  • 1. Version
  • 2. Tuning
  • 3. AVC
  • 4. Debug Messages
Engineering Mode Notes:
the settings in engineering mode reboot back once you turn the car off and on again.
Almost certain "battery" is the stupid chirping you hear when you leave the headunit on for too long without ignition powered on.
Video being checked is VERY suspect as in all the other engineering mode examples from korealand, it's not checked, except for the k5 which DOESN'T have reverse camera from the factory.
Wonder if it's a disable button. A theory would be to uncheck it, throw the car in reverse and see if the screen goes black. Car is getting a reverse signal from it, so if it's in fact the reverse camera disable, it will go black as it's trying to display a video feed from a non-existant camera.
Would also make sense that it's disabled, since the car doesn't have a camera, so obviously having the screen go black in reverse would look silly for Hyundai.
Really need to compare with a 2014 with a reverse camera.
Or, someone taking a chance and hitting the button, and seeing what happened. Obviously since we don't definitvely know what it does... could cause weird behavior.
While the chance is slim, the risk is still there.
Windows OS
Accessing Windows Embedded Automotive OS (aka Windows CE Auto): Thanks to Dreadie
***NOTE: You will lose your presets (and possibly some other settings may revert to default)
  • Turn on the nav/head unit/radio.
  • Hold the FM/AM + MAP + EJECT buttons (all 3) for 15 seconds.
  • The screen should go black (power down), let go of the buttons.
  • The screen should reboot into Windows desktop.
  • To exit turn off and on your vehicle.
Mounted Drives:
  • CD Disk: Believe to be the CD slot. Haven't tested functionality within Windows.
  • DiskA:
  • DiskA2: Believed to mostly hold map & navigation data
  • DiskA3:
  • DiskB: USB drive. Has been tested with flash drives & external hard drive (500GB) access. Able to copy files from other drives onto USB.
Data Dump Notes:
These lib functions look mighty tasty!
Function Name : lSetAuxSignalStatus
Address : 0x00101348
Relative Address : 0x00001348
Ordinal : 1 (0x1)
Filename : LibVideo.dll
Full Path : C:\Users\Glen\Desktop\2013GC\DiskA\application\AV\LibVideo.dll
Type : Exported Function
Function Name : lVideoBegin
Address : 0x00101010
Relative Address : 0x00001010
Ordinal : 2 (0x2)
Function Name : lVideoClose
Address : 0x00101020
Relative Address : 0x00001020
Ordinal : 3 (0x3)
Function Name : lVideoGetRearViewStatus
Address : 0x00101338
Relative Address : 0x00001338
Ordinal : 11 (0xb)
Function Name : lVideoInit
Address : 0x00101000
Relative Address : 0x00001000
Ordinal : 22 (0x16)
Function Name : lVideoSetRearviewStatus
Address : 0x00101240
Relative Address : 0x00001240
Ordinal : 37 (0x25)
Function Name : lVideoShowRearView
Address : 0x00101084
Relative Address : 0x00001084
Ordinal : 49 (0x31)
Screenshots:
Map Update version 7U03 USB Source
This is the file list and source from the version 7U03 map update USB drive:
Thanks to Lovetodrive2000
***NOTE: You will NOT be able to update your nav unit with just the USB files/drive. The actual map update process requires providing a generated (or pulled) Device ID to MnSOFT with your order number. Once vetted through their system you are given your authentication code that allows the update to continue.
Directory of C:\7U03
04/30/2014 23:50 <DIR> .
04/30/2014 23:50 <DIR> ..
04/30/2014 22:10 <DIR> BK
04/30/2014 22:10 <DIR> BK_A
04/30/2014 22:10 <DIR> BK_C
04/30/2014 22:10 <DIR> BK_CA
04/30/2014 22:12 <DIR> COMMON
04/30/2014 22:13 <DIR> GD
04/30/2014 22:13 <DIR> GD_C
04/30/2014 22:13 <DIR> GD_CM
04/30/2014 22:13 <DIR> GD_M
04/30/2014 22:13 <DIR> HG
04/30/2014 22:13 <DIR> JK
04/30/2014 22:13 <DIR> UD_nd
04/30/2014 22:13 <DIR> YF
04/30/2014 22:13 <DIR> YF10MY
04/30/2014 22:13 <DIR> YF12MY
04/30/2014 22:13 <DIR> YF12MY_C
04/30/2014 22:13 <DIR> YF12MY_C_MIC
04/30/2014 22:13 <DIR> YF12MY_MIC
04/30/2014 22:13 <DIR> YFE
04/30/2014 22:13 <DIR> YFE_C
04/30/2014 22:13 <DIR> YFE12MY
04/30/2014 23:50 0 7U03_files.txt
02/17/2009 00:15 7,168 AVNRecovery.exe
05/20/2013 22:26 170 install.crc
05/14/2013 18:39 348,160 install.exe
05/07/2013 16:34 16 install.md5
03/04/2013 15:54 7 install.nfo
03/31/2013 22:17 40,624 MAP.hdr
03/23/2010 02:10 54,784 zlibce.dll
8 File(s) 450,929 bytes
Directory of C:\7U03\BK
04/30/2014 22:10 <DIR> .
04/30/2014 22:10 <DIR> ..
05/07/2013 21:28 416 ACC.hdr
05/07/2013 21:28 0 ACC.spd.000
05/07/2013 21:28 38,376 APP.hdr
05/07/2013 21:28 34,010,941 APP.spd.000
11/28/2007 21:41 768,054 bkgnd.bmp
05/07/2013 21:26 464 BSP.hdr
05/07/2013 21:26 13,536,623 BSP.spd.000
05/07/2013 21:29 2,903 install.ini
05/07/2013 21:26 360 MICOM.hdr
05/07/2013 21:26 228,719 MICOM.spd.000
05/07/2013 21:25 78 model.bin
11 File(s) 48,586,934 bytes
Directory of C:\7U03\COMMON
04/30/2014 22:12 <DIR> .
04/30/2014 22:12 <DIR> ..
06/17/2013 23:46 40,624 MAP.hdr
03/31/2013 22:07 1,065,138,363 MAP.spd.000
03/31/2013 22:10 1,055,997,517 MAP.spd.001
03/31/2013 22:12 1,061,919,405 MAP.spd.002
03/31/2013 22:15 1,059,834,997 MAP.spd.003
03/31/2013 22:17 792,494,992 MAP.spd.004
6 File(s) 5,035,425,898 bytes
USB Drive Source (directory/files split into 26 file rar archive):
USB Drive Source Notes:
  • It looks like the folders correspond to different versions/regions of the nav update. From quickly looking in the files I believe the US GC update is located in the BK folder......not too sure though.
  • These are the folders. They all seem to have the same 11 files with variations for ver/region:
    • \7U03\BK_A
    • \7U03\BK_C
    • \7U03\BK_CA
    • \7U03\GD
    • \7U03\GD_C
    • \7U03\GD_CM
    • \7U03\GD_M
    • \7U03\HG
    • \7U03\JK
    • \7U03\UD_nd
    • \7U03\YF
    • \7U03\YF10MY
    • \7U03\YF12MY
    • \7U03\YF12MY_C
    • \7U03\YF12MY_C_MIC
    • \7U03\YF12MY_MIC
    • \7U03\YFE
    • \7U03\YFE12MY
    • \7U03\YFE_C
Links:
Contributors: Big Thank You to everyone who contributed information including (but not limited to):
Swollen Member
subbed, hoping to get a 2013 skin upgrade like the one offered by ravv for the previous model years and willing to pay for it.
Tons of us shared knowledge in the other thread... let's ensure they get the credit they deserve.
Yes I agree 110% I am trying to quote the original sources it's just taking a bit longer since I either know the data already from reading it, or have it written down in my notes, or im referencing the other thread.
This is definitely a big Work-In-Progress at this initial stage. I am trying to go back through the other thread and give credit to the original posters, it's just taking some time, promise.
Swollen Member
Someone could go to a dealership, take a 2014 for a test drive, and check the settings while they're away from the dealership...
the settings in engineering mode reboot back once you turn the car off and on again... tried it earlier to disable the annoying battery thing. was hoping to disable the map "warning" message where you have to press agree before you see anything. couldn't figure out which button it was, but even then pretty sure it would be useless without figuring out a way to make the changes save.
"AGREE" button is likely in the executable for the navigation program. Some time and a hex editor would likely easily solve that.
I'll make this simple for you 2013 guys.
Following is needed:
1) 2014 Nav Engineering Screen Shots
2) Full directory listing from 2014
3) Full directory listing from 2013 map update USB drive
4) Possible files from 2013 map update USB drive
Until someone does this, keep holding your breath.
Discussion Starter · #12 ·
So we need a 2014 to chime in, and someone who just did the 2013 update.....I saw a couple people on the boards complete it.....chime in please
Read the other thread you posted in - somewhere in the 39 pages the steps are listed.
Thanks Dreadie for your replay
Actually I searched the 34 page thread , I didn't find the screen resolution for wince6 , I tried yesterday to run I go primo appliction ,
Unfortunately a pop up screen appear said that your resolution (480*1600) !!!!!
I will appreciate your help to send me link for screen resolution and believe me I search alot on the thread and on web but without result
Thanks again
Someone uploaded the 2013 update USB stick. Once I get on a laptop I'll edit the post, share it and give credit where to the person who uploaded the files.
Discussion Starter · #17 ·
Just posted the 2013 Map Update (ver 7U03) USB file list & source:
    • \7U03\BK_A
    • \7U03\BK_C
    • \7U03\BK_CA
    • \7U03\GD
    • \7U03\GD_C
    • \7U03\GD_CM
    • \7U03\GD_M
    • \7U03\HG
    • \7U03\JK
    • \7U03\UD_nd
    • \7U03\YF
    • \7U03\YF10MY
    • \7U03\YF12MY
    • \7U03\YF12MY_C
    • \7U03\YF12MY_MIC
    • \7U03\YFE
    • \7U03\YFE12MY
    • \7U03\YFE_C
1 - 20 of 250 Posts
