1 - 3 of 3 Posts
2015 Genesis Coupe 3.8 Base
Not sure if this is what you're looking for, but the cam and crank sprockets are marked in these locations shown in the image. The chain marks should be colored differently at the areas where the cam and crank timing marks (not sure what colors are used, but the areas where the cam sprockets line up with the chain should both be the same color)
Font Auto part Drawing Fashion accessory Line art
On the cam gears, the lines are supposed to be facing each other, the dots are for the marked chain links.
1 - 3 of 3 Posts
