So I'm doing a 2jz swap on my 2013 2.0T, then I realised that the talk about making the interior equipment is hard and very expensive to wire up. So I need recommendations on who and where can help me with this. I would greatly appreciate it!!!
Think as the chassis as just a shell.
Basically yank all the hyundai computers and wire in a supra body wiring harness.
Speed sensors are basically the ABS sensors.
ok so will that make all the instrumentation work cluster, a/c, ect.?
you're going to have to yank all that our and put in something else.
You can probably reuse the HVAC unit, and wire a different controls to work, unless you want to pay someone $$$$ to translate the CAN bus and then program something else to work.
MAYBE... you can swap in a body harness and computers from a 3.8, then use a pnp haltech, then grafting in the 2jz engine harness, since they the 3.8 and 2jz both have 6 cylinders. but you would have to contact haltech to see if it will even work. Then you wouldn't have to remove the controls and gauges.
