I can’t seem to find any threads for this issue and not sure exactly where to post so I went with general.
I was having a hissing noise coming from the glove compartment area for a couple weeks. I was told it probably just needs a charge which I thought was odd since it’s a 2015 but who knows.
Today I was sitting in my car and all of the sudden my fan slowly died out and nothings working now. The fan won’t even start if I switch to max heat.
If anyone’s got any suggestions I’d appreciate it. Thanks!
Likely the blower motor resistor.
just to be sure, when was the cabin air filter last replaced?
to access the filter,
open the glove box
remove the 2 catch so the box can drop lower
behind it, there will be a long cover that you can unclip to remove, behind it is the filter
Pull it out just to check if there are any holes in it (never know if something got in there)
If fine, reverse removal.
This is for the resistor
skip to about 2:40
the white wire connector is where the resistor is.
Awesome thank you! The filter hasn’t been replaced in at least 3 years…..my bad hahah. I’ll check it out today. Just really hoping I don’t have to replace the compressor.
