Moderator
<p class="p1">A clean engine is a more efficient engine (and also a more powerful one), so a fuel injector cleaning is an important part of maintaining your car. While you can always visit a mechanic to get this service done, this is actually one of a few maintenance items that are pretty idiot-proof when it comes to at-home DIY. How simple? You can do it at home without any tools or garage space. We previously went through <span class="s1">our list of favorites over on AutoGuidehttps://www.autoguide.com/top-15-best-fuel-injector-cleaners, and we recently discovered that four of our selects are currently on sale! Here's what you need to know:</span>
<p class="p1"><span class="s1" style="font-size: small;">Royal Purple Max-Clean Fuel System Cleaner and Stabilizer is 19% off</span>
<p class="p1"><span class="s1" style="font-size: small;">Lucas Oil 10512 Deep Clean Fuel System Cleaner is 32% off</span>
<p class="p1"><span class="s1" style="font-size: small;">Lubegard 77012 Fuel System Booster Cleaner is 11% off</span>
<p class="p1"><span class="s1" style="font-size: small;">Marvel Mystery Oil 50665 Ultimate Fuel and Motor Treatment is 14% off</span>
<p class="p1">
<p class="p1">
This Techron fuel system from Chevron is a great mid-range cleaner from a well-trusted brand. The directions on this cleaner are very clear: it is best used on your engine about every 3000 driven miles. It will break down and clean up tough deposits on the fuel injectors and help to maintain your engine, keeping it running smoothly, efficiently and quietly.
This Best Fuel Injector Cleaner 2020 is safe to use with diesel engines. It is suitable for older to more modern engines, and performs well with mineral diesel, bio-diesel and blends. The patented, specialized Techron formula is meant to tackle harmful deposits on the nozzle as well as internal diesel injector deposits. It is a high-concentrated formula, so even though the standard bottle size is small, a little bit goes a long way.
These best Fuel Injector Cleaner 2020 is safe to use with diesel engines. It is suitable for older to more modern engines and performs well with mineral diesel, bio-diesel, and blends. The patented, specialized Techron formula is meant to tackle harmful deposits on the nozzle as well as internal diesel injector deposits. It is a high-concentrated formula, so even though the standard bottle size is small, a little bit goes a long way.
As long as you stick to well-known brands and follow the instructions, there should be no harm and since most products have very cheap one-time use sizes for like $20-25, you're not risking your wallet either.
