1 - 20 of 80 Posts
Is anybody getting a slight 6th gear grind? It doesnt happen everytime but id say 1 of every 5 i get a slight grind going into 6th.
wannabe guru
yep tranny replaced no issues since
Court Jester
I'm just started to get a grind when I go into 6th gear under acceleration... when I shift somewhat fast... :(
If I shift slowwwwwwwwwwwww... no problem.
If the engine isn't under load, no grind.
I get a crunching noise if I go into 2-3 and my 4th some times doesn't want to inguage, it goes to 4th but it does go into gear and it just seems like there do 4th gear until I take it out of 4th and retry, had this happen many times when I was racing some1
i have the same crunching noise/feel going into second, as if its hitting a gear. Not sure if this is normal or if anyone else is experiencing this, please let me know!
^^^sound like you may have just missed second, although i wont exclude it being a possible issue since other report issues to. sucks to here this, im at 6K and luckily have had NO issues with tranny. good luck with the replacements
^^^I have the EXACT same symptoms.
It grinds worse from 3rd (or 4th) to 6th than 5th to 6th under acceleration.
Court Jester
Got an app't at the dealer tomorrow....
Lets see what they say! :)
Court Jester
Service Manager took the car for a drive….
Came back and told me he has contacted the area Hyundai rep, plus a Hyundai engineer to come look at the car. Said something is going on in there (transmission)!
New app’t is set up for next Tuesday……
(I know this is a 2.0T thread.... but I have the 3.8 Track! :))
wannabe guru
and mines back again...
apt Thursday at dealer. First time they said they couldn't replicate it. Then I found out they never even put it in 6th gear. I swear they never listen to what you tell them.
so what happend? ive got a '13 2.0t rspec. same deal. i can go from 5th to 6th no problem, but it grids just a little 4th to 6th, 60% of the time
FS section ravager
Get your RPMS higher in 5th then go to 6th.
I had my trans replaced at 1600 miles.
They gave me a new transmission...no more grind, but everyone that does that, it ends up coming back...it looks like the best fix is changing to a higher quality synchro transmission fluid...that seems to completely fix it
Court Jester
It is hard to believe that if this was totally correct, that Hyundai wouldn't have switched fluids long ago!
I think there is a lot more going on in our trannys that Hyundai hasn't figured out a cure for! :(
i have 3.7k miles on mine.. no grind in 6th gear, is there anything specific i should look for? or hear? anyone know round about mileage this happened to them? Definately something i want to avoid lol.
I've got 20K miles on my' 2013 2.0T Base. I've noticed going from 5th to 6th is a bit tight, but nothing I feel concerned about. I was considering putting some fresh fluid in the tranny just for longevity reasons.
1 - 20 of 80 Posts
