So i have a 2013 genesis coupe 2.0t and all my abs light came on i checked the fuses and everything pulled my e brake up and down and nothing is there a abs module connector pinout or something that i can reference off of?
b1102,b1329,b2502,b1334,b1493,b1684You need to buy or borrow a ABS capable OBD scan tool and see what codes are causing the ABS light to come on.
b1684
yea my gauges and stuff starts flickering and and when i turn the key the starter clicksDon't know about the Coupe.
On my 05 Silverado and 15 435iX a weak battery caused communication errors (and lots of other trouble codes to pop up).
You've got a battery voltage code along with the other codes. How old is your battery?
Might want to check the battery ground cable at the fender for corrasion or a bad connection.
[/QUOT
