1 - 3 of 3 Posts
I have a 2013 coupe. Today the air conditioning would not blow. Everything sounded just like it was working. It would get louder as I turned it up higher but you could not feel air coming out of the vents. It sounded just like it was working fine. I thought it might be coming out where the defrost comes or out at my feet but nothing. I have had this happen before but when I would cut off the air and cut it back on, it would work. Today I could not get it to work even thought I drove the car several times. It finally started working normal the final time I drove it. Has anyone had this happen or know what the problem is? Thanks for any info.
Korean Asswhoopin
Sounds like flaps sticking on your HVAC box. You're sure the fan is blowing?
Thanks for the reply. I def think so as you could hear it get louder with each time I turned it up a higher level. Everything sounded normal, you just couldn't feel anything come out.
Thumb5;44[PHP said:
[/PHP]85658]Sounds like flaps sticking on your HVAC box. You're sure the fan is blowing?
1 - 3 of 3 Posts
