1 - 3 of 3 Posts
Hi guy, I have installed on my car the HKS bov valve with bypass T for stock valve, You think is best choise remove the stock valve and close the hole with a plate Or leave it mounted with T tube bypass?
remove it.
the stock valve will open before the bov.
functionally it makes no difference, unless you are running higher than stock boost, but since you got the hks, I assume you want more of the whistle.
remove it.
ok, I have the HKS SQV4, so I remove the stock bov ( by-pass valve) and use the plate.
This is my actual installation of the bov with sotck by-pass valve mounted.
1 - 3 of 3 Posts
