I was hoping to pick up a SFR adjustable clutch rod, but it looks like they are long gone. Is anyone else making an alternative?
Thanks!
shorttrack
Get up with member '' the_Engineer''.I showed him how to make them .Check the thread ,SFR Adjustable Clutch Rod install DIY -the stuff nightmares are made from-
Reactions: tdbill
Thanks for the heads up!
The circular "eye" on my clutch master was ovaled out from use. It had worn enough that reverse was nearly impossible to access with the car running any 1st wasn't much better. I was able to but a shim in there so i could drive it until the replacement arrived. New oem master is in and its operation is perfect, but i'd like to be able to adjust to my preference.
shorttrack
Yeah I made the switch to a wilwood aluminum racing master clutch cylinder and a homemade adjustable clutch rod(metal,not plastic) .
