1 - 20 of 40 Posts
3.5L TT but wrong body
Seems to have cured my knocking and everything seems to be running fine for 2 tanks now. Just figured I'd see if anyone has any input on ill effects? I'm just putting ~1.3 gallons of E85 before I fill the rest with premium (usually 11-12 gallons of 93 octane) so it may not be exactly E15 but close... Mainly just a stop gap until I put my methanol kit in. Filling from 2 pumps is a PITA.
I asked this earlier and never really got a straight answer. I have a station here that actually sells it straight from the pump.
Does the pump with E15 list the octane rating?
would gas milage be affected?
I would think a little bit but hopefully not too much.
you need to just hurry up and install the meth kit an tune! it does wonders!!!! and feels like NOS kicking in! lol
fragmuffin
Why don't you just tune your car again and make it safe to drive on pump gas instead of mixing your own?
Discussion Starter · #8 ·
I'm already running 11.X:1 a/f and the 91 octane Stage 3 tune, with 93 octane gas, with just about maxed injectors. Still need to send my EvoX injectors off to get flowed to make sure they're good before installing.
Basically out of tuning options aside from dropping boost down a couple psi. Something about seeing my boost gauge hold 21psi all the way to redline makes me not want to do that :)
The meth kit will take care of it but it's been cold and rainy for the last 3 weekends, so I haven't been able to install it. I only heard, what I think was knock, a couple of times near redline. The strange thing is though the ECU never pulled timing when i heard it so I'm not even 100% sure it was knock. I haven't heard it at all since switching to the E15 mix though.
None of this will be a concern once the ecu is cracked or Dynojet releases the timing module. Just reiterates the fact that we need a full tuning solution.
Hmmm. Was hoping it was a bit higher than that. Does it say what octane gasoline they start with?
Guess I might to have to do some math and see what octane 15 gallons of 93 with 1.3 gallons of 106 is. 94-95 is probably about right though.
MR TURBO 2 U
crooked your fine doing it i have been mixing e85 since 1990 just if the car is going to sit for more than 1 month run it out and use only premo till its back on the road
now dependant on if its corn or wheat etc based the octane rating varies heaps
usually though in the us its corn baased so the ethanol is approx 110 ron your us fuel i beleive is ron + mon / 2 = 93 not sure what mon of corn ethanol is but assume 100 so in us ratings ethanol is 105 approx so add 15% of the 105 with 85 % of the 93 and you have your approx rating its qtr past 3 am here so i cant be bothered but its close enough!!!
ps i think i'm right almost positive about the corn based?
Discussion Starter · #12 ·
Correct, corn based ethanol. Thx for the info!
MR TURBO 2 U
Discussion Starter · #15 ·
Not sure why you want to switch out your deatschwerks for the evox injectors.
they are both rated at 550cc at 43.5 psi.
You sure about the DW 550's? I thought they were rated at 550 @ 54 psi, since that's what the 2.0T runs for fuel pressure.
BadBoyBill flowed the Evo X injectors at ~640 at 54psi.
If the DW 550's are rated at 43.5 psi then the Evos would be pointless.
Positive.Almost all injector companies rate at 3 bar to keep it standardized.
You should have gotten an injector report it will say it on the sheet.
Discussion Starter · #17 ·
I did get a flow report, can't find it though. I think I scanned it in for a post you made a while back too. Can't find it though.
Discussion Starter · #19 ·
MR TURBO 2 U
actually 35 psi has been the standard for 30 odd years! cant see why the change?
1 - 20 of 40 Posts
