agreed, but i think a big part of it is having the block off plate to eliminate the stock BOV....and AMS hasnt released it yet ..This isnt a flywheel issue, by any means. Look at the 98-05 VW Jetta/GTI's. They are DBW, with a HUUGE dual-mass flywheel. But no rev hang? Because there is no turbo system with a poorly designed BOV
Everyone should read the post by AMS - you would see that they installed a Tial BOV along with the factory BOV, and the rev-hang was practically eliminated. Why? Because the factory BOV would stay open and continue to recirculate boost after you take your foot off the pedal, but the Tial valve would 'blow-off' any boost when you go into vacuum/begin to decel, and eliminate the concern.
Kristin - you could probably shead some insight because you have an aftermarket BOV installed. Do you still have a rev-hang issue?
-Nick
honestly, i think its worse when you dont drive spiritedly. I find the rev's drop fastest when you blip the throttle right before you shift just to build some boost to actuate the BOV...SO this only affects the 2.0T people who drive spiritedly?
Are you sure?But no rev hang? Because there is no turbo system with a poorly designed BOV
:dunno:Seoulfulracing said:same thing with we get complaints about RPM does not drop fast enought. This is got nothing to do with BOV itself, it's just that this throttle body on Gen Coupe responses very slow.
I HATE that. That is the one thing I miss most about my previous vehicles, is being able to rev match. There is nothing like going through some turns on a back road and not being able to rev matcvh. UGHHHH :mad2:Hell you can barely rev-match in this car. The ECU programming is and will continue to be the biggest beef I have with my rig.
I never owned a vehicle with DBW, need I say more?I HATE that. That is the one thing I miss most about my previous vehicles, is being able to rev match. There is nothing like going through some turns on a back road and not being able to rev matcvh. UGHHHH :mad2:
yeah man, first gear is HORRIBLEI took delivery of my 2.0T last night. When I test drove the car it seemed fine. At one point last night while out enjoying the new car, the throttle hung at the top of 1st gear so long I thought it was stuck open. Needless to say, I was not expecting that at all. After reading this entire post I'll be off to the dealership right after work.
Stage1
Good point.Whats the last 5 digits of your vin #??
It is better, but not not as good as it could be.This isnt a flywheel issue, by any means. Look at the 98-05 VW Jetta/GTI's. They are DBW, with a HUUGE dual-mass flywheel. But no rev hang? Because there is no turbo system with a poorly designed BOV
-Nick
