This is a DIY on the 2010 2.0t automatic, similar process to all other automatic years.
I filled up with whatever ATF drained out which was 4.1 qt., it may be different for you.
I decided against using the overfill plug since my tranny is over 120 000 km and has been running great so I didn't want to change the oil fluid dynamics.
Amsoil ATF Multi Vehicle ▶︎ https://goo.gl/UiPaAG
Torque Spec:
Drain Bolt: 50 ft lb
Fill plug: 15 ft lb
Tools:
Drain bolt: 17 mm socket
Fill Plug: 8mm Allen (hex) key
Torque Spec:
Fill plug: 15 ft lb
Tools:
