1 - 20 of 36 Posts
Cynicism Embodied
Automobile Magazine has posted its review of both the 2.0T and 3.8 on its website and I hadn't seen anyone discuss it quite yet. Unfortunately, I can't post it because of my post count so if someone else could do that it would be much appreciated.
Definitely a new take on the 2.0T, they don't seem to be nearly as fond of it as the 3.8. That's not really a surprise, however the it's extreme understeer is news to me. Also, the comment about the lack of balance shafts is a bit disconcerting.
First Drive: 2010 Hyundai Genesis Coupe
February 26, 2009
By Jason Cammisa
It's all about derivatives these days. If they're not decimating your 401(k), they're invading your neighborhood car dealership. Although its similarity doesn't come across as well in photographs, the 2010 Hyundai Genesis coupe is a dead ringer for the Infiniti G37 coupe. In fact, it might as well be badged the Designer Imposter Infiniti G37.
It's not as gorgeous as the G37 coupe - what is? - but the Genesis coupe shares all the key measurements - any dimensional difference between the two cars is less than the length of your middle finger. Which is exactly the finger you'll be seeing if you ask someone in a Genesis coupe if they're driving the new Tiburon.
Not that there's anything wrong with the Tiburon, but there will be inherent marketing-related growing pains as Hyundai eases out of its entry-level, economy-car past and into its rear-wheel-drive, big-hitter-facsimile future - especially when it tries to appeal to enthusiasts. For that reason alone, many potential buyers of the more expensive G37 won't give the Hyundai a second look.
If it's performance they're looking for, though, perhaps they should. On paper, the Genesis coupe 3.8 is the near equal of the G37 - and for ten grand less. Its horsepower deficit (306 versus 330 hp) is nearly nixed by an almost 300-pound weight advantage, helping the Hyundai come within a half-second of the Infiniti's 5.5-second sprint to 60 mph. And that's despite engine programming that refuses to give power back after quick redline shifts. The Hyundai also matches the G37's very impressive braking performance and cornering figures, which are a near match for the BMW 335i's numbers. Do we have your attention yet? It may be a copy of a copy (Infiniti unabashedly targeted the 3-series with the G37), but the Hyundai's performance is anything but derivative.
The question is, though: who's going to buy this new coupe? Hyundai hopes the tuner crowd will embrace the two-door Genesis, especially the base model, which comes with a new, 210-hp, turbocharged 2.0-liter. Unfortunately, the new four-banger makes much better sense as a base engine for those who are looking for a Tiburon replacement - buyers wanting sporty looks and decent performance at a very low price. The 2.0T is tuned for lots of muscle in the low-rpm, daily-driving range, but it runs out of thrust quickly as the tach climbs past 4000 rpm. Worse, without balance shafts, the engine practically begs you to short-shift it, due to deafening boominess and vibrations severe enough to rattle the dashboard.
An even bigger issue for the 2.0T is that the 3.8 costs only $3000 more. Tuners like to tinker but they love speed, and even with three grand in modifications, the four-cylinder likely won't come close to the V-6's output - and it'll never match its sound and power delivery. Despite coming from less enthusiast-focused cars (can you say Kia Borrego?), the V-6 works surprisingly well in a sporty application. It's an overachiever of an engine, pulling like mad all the way to redline and filling the cabin with a ferocious intake honk, a sonorous exhaust wail, and just enough coarseness to say "sporty" without ever saying "thrashy."
Infiniti's 3.7-liter could take a singing lesson from it, in fact. The meaty clutch in the Genesis has a positive engagement point near the top of its travel, and the high-mounted shifter, although notchy when cold, is a pleasure to row through the gears. Pleasantly devoid of the torque steer that plagues all powerful front-wheel-drive cars, the Genesis's steering is quick, well-weighted, and accurate - but a bit lighter on feedback than we'd hoped.
The Genesis coupe will be sold in several trim levels - base, Premium, Track, and R-Spec for the 2.0T, and base, Grand Touring, or Track for the 3.8 only. A six-speed manual transmission is standard with either engine; alternatively, base and Premium 2.0T coupes can be mated to a five-speed automatic. All V-6 models are available with the same ZF six-speed automatic found in the Genesis sedan, but inexplicably, in this application, it doesn't match engine revs on downshifts and has no true manual mode.
Track models are the top-specification coupes and come standard with a full complement of electronics (minus a navigation system, which will become available later this year). Behind the nineteen-inch wheels (lesser models come with eighteens) are red-painted, four-piston Brembo calipers front and rear. The package also includes a Torsen limited-slip differential, stiffer springs, retuned dampers, and bigger antiroll bars.
Although the Genesis's pedals are spaced a little too far apart for easy heel-and-toeing, the Brembos give fantastic brake feel, and when we took the Genesis for hot laps around a racetrack, they refused to fade. The Track model's suspension, which adds an ever-so-slight amount of chop to the coupe's otherwise supple ride, helps the Genesis turn in more crisply and reduces understeer. Unfortunately, even the Track chassis plows resolutely, a situation not helped by the staggered wheels and tires. On smooth pavement, neither abrupt turn-in nor trailing throttle will coax the coupe's tail out, although midcorner bumps will throw the car sideways - an unfortunate trait also exhibited by the Genesis sedan with which the coupe shares its five-link rear suspension.
The base turbo engine's narrow power band, appreciable lag, and modest output (when teemed against 3400 pounds of curb weight) aren't enough to reliably overcome the understeer and kick the coupe's tail out. But that's a problem the 3.8 doesn't have. It lacks the G37's perfect chassis poise, but add loads of power and the six-pot Genesis becomes the drift champion that Hyundai has been promising all along. The steering wheel may communicate nearly nothing about what the front wheels are doing at the limit, but the Genesis's long wheelbase, broad torque curve, and wonderfully progressive limited-slip diff make ludicrous power slides easy. Professional driver, closed course, and all that jazz...
The Genesis coupe works well in daily driving, too. The cabin is finished with nice materials, and its great-sounding Infinity (no relation to the G37) sound system is powerful enough to drown out the considerable road noise at highway speeds. There's enough legroom in back for six-footers, but the coupe's raked roofline means their noggins will be firmly planted against the hard rear glass. The trunk's high load floor and the one-piece folding rear seat's small pass-through limit cargo-carrying versatility.
Of course, conventional wisdom says that if you need to transport lots of people and stuff, you buy a sedan. Then again, not even the most astute conventional wisdom would have predicted that Hyundai could pull off a car like this.
2010 Hyundai Genesis Coupe 2.0T Specifications and Test Data
Power: 210 hp @ 6000 rpm
Torque: 223 lb-ft @ 2000 rpm
Displacement: 2.0 liters
Weight: 3380 lbs
Weight distribution (percent, front/rear): 53.8/46.2
0-60 mph: 7.0 sec
0-100 mph: 17.7 sec
0-110 mph: 23.0 sec
0-120 mph: 28.4 sec
0-130 mph: 35.8 sec
1/4 mile pass: 15.4 sec @ 93 mph
Peak acceleration g: 0.6
30-70 mph "passing:" 7.5 sec
70-0 mph braking: 159 ft
Peak deceleration g: 1.1
Lateral Left: 0.93
Lateral Right: 0.88
Speed in Gears:
-1st: 30 mph
-2nd: 52 mph
-3rd: 77 mph
-4th: 105 mph
-5th: 129 mph
-6th: 133 mph
Wheel/Tire Info: Bridgestone Potenza RE050A
Front Tire Size: 225/40YR-19
Rear Tire Size: 245/40YR-19
2010 Hyundai Genesis Coupe V-6 Specifications and Test Data
Power: 306 hp @ 6300 rpm
Torque: 266 lb-ft @ 4700 rpm
Displacement: 3.8 liters
Weight: 3480 lbs
Weight distribution (percent, front/rear): 54.6/45.4
0-60 mph: 5.9 sec
0-100 mph: 15.4 sec
0-110 mph: 19.2 sec
0-120 mph: 23.1 sec
0-130 mph: 27.8 sec
0-140 mph: 38.2 sec
0-150 mph: 54.7 sec
1/4 mile pass: 14.9 sec @ 98 mph
Peak acceleration g: 0.57
30-70 mph "passing:" 7.2 sec
70-0 mph braking: 157 ft
Peak deceleration g: 1.05
Lateral Left: 0.93
Lateral Right: 0.87
Speed in Gears:
-1st: 27 mph
-2nd: 61 mph
-3rd: 88 mph
-4th: 116 mph
-5th: 142 mph
-6th: 151 mph
2010 Hyundai Genesis Coupe - First Drive Hyundai Sports Coupe Review - Automobile Magazine
Sound Man
I thought the gear ratios for the manual transmissions in the V6 and the 2.0T were the same. Why is it that they have different speeds at different gears? Was the rear end ratio different?
Sound Man
I noticed that 0-60 for the 2.0T comes in 3rd gear. That must is one of the reasons it's such a slow time.
Overall they didn't seem to impressed with it.
traction control off =]
yes the final drive or something i different i think? idk someone...i think it was mcfly but i'm not sure, posted that it would be an awesome mod for the V6 to grab the gearing from the 2.0t
just search for the post if your wondering haha it was a little while ago and i forget =p
Topless = More Fun 4 Me!
He's right with the middle finger, but it's toward him that I'm pointing it with the stupid ass G37 clone remark. Or he's either blind as a bat or just plain biased. He probably has a G37 tucked in his driveway and he's cursing the life of the price he paid to have a 10K cheaper car spank his brand new ride. :p
Some more inconsistent numbers, how the hell does the 4cyl be only .5 sec slower in the quarter and be 1.1 sec slower 0-60?? Hmmm under further review I suppose the more agressive gearing in the 2.0T could be why......
Sound Man
Like I said....the V6 can hit 60 in second gear. The 2.0T needs an extra shift to get there so it's time is a result of the lower powered engine and an extra shift time. But, in the 1/4 they both finish in 4th gear so there is no shift time deficit.
14.9 1/4 mile for the 3.8? I think all of these publications are hitting the rev-limiter and not adjusting their shifting to negate the "2-3 second loss of power" that doing so brings. I test drove a 3.8 track with ZF transmission and it seemed pretty damn fast to me. I hit 60mph in 2nd gear in no time and went up to about 80 before pulling off with no loss of power anywhere (the salesman was with me and told me to floor it). Looks like we won't know "real" numbers until more coupes get in the hands of people not looking to cut them down :dunno:
I hit 60mph in 2nd gear in no time and went up to about 80 before pulling off with no loss of power anywhere (the salesman was with me and told me to floor it). Looks like we won't know "real" numbers until more coupes get in the hands of people not looking to cut them down :dunno:[/QUOTE]
It's good to see based on all these test drives that the Hyundai dealers are making sure the proper break-in procedure is followed during test drives. A lot of people complain about how tough Mitsu and Subaru are about giving out test drives and how they can be driven during it. But those enthusiasts have learned long ago to insist on a very low (or no) mileage car due to sales reps allowing drag racing and drifting (apparently) during a test drive. I was also horrified of the video of the sale rep free reving a brand new (and cold by the looks of it) GC. Hopefully all the dealers keep a test mule around , but I doubt it. Nothing like saving your hard money to buy a car that was abused before you ever got your hands on it.
It's good to see based on all these test drives that the Hyundai dealers are making sure the proper break-in procedure is followed during test drives. A lot of people complain about how tough Mitsu and Subaru are about giving out test drives and how they can be driven during it. But those enthusiasts have learned long ago to insist on a very low (or no) mileage car due to sales reps allowing drag racing and drifting (apparently) during a test drive. I was also horrified of the video of the sale rep free reving a brand new (and cold by the looks of it) GC. Hopefully all the dealers keep a test mule around , but I doubt it. Nothing like saving your hard money to buy a car that was abused before you ever got your hands on it.[/QUOTE]
if you are worried about TibGuy revving an engine you got alot to learn, the "new" engine in your car has already been revved and such at the factory to make sure its put together correctly.....
This guy is an idiot. "Its similarity doesn't come across as well in photographs" because they don't look anything alike! Seriously that is one ignorant statement.
I also don't trust this guys driving skills anymore than his observations - he said pedals were too far apart for easy heel-toeing. I beg to differ - they're just fine and I have small feet for a guy.
Alot of these reviews are pretty disappointing. It sounds like that limiter after redline does get in the way. Maybe someone can get a chip to get rid of this (like a Cobb Accessport or something).
The 4-cylinder I suspect has too small a turbo. The way they described it sound like how an STI runs out in the high RPM band. But the buzziness of the 2.0 sounds disappointing. They also didn't mention if the 2.0t has the power limiter as well.
I read to this
And stopped.. Someone's never, ever touched a turbo car with mods before.
It's good to see based on all these test drives that the Hyundai dealers are making sure the proper break-in procedure is followed during test drives. etc etc etc...
I break in my cars like I drive them. That means I don't *****foot around town and I'm not afraid to get on it after the engine is warm. I've had ZERO problems directly relating to the engine.
K I'm done so this doesn't turn into another break-in thread. :D
1 - 20 of 36 Posts
