1 - 16 of 16 Posts
Hey guys and gals I have a little issue
Whenever I get into boost my car starts backfiring like crazy and I loose all power
Any help would be appreciated
Check to see if any of the coils have a tear on the boots. Squeeze them to check, cracks are hard to tell just by looking at them.
Napa sells replacement boots.
SMP No: 806SPP176S
P0237 Manifold absolute pressure (MAP) sensor A, TC system – low input Wiring short to ground, MAP sensor, ECM
Did you look over the wiring for the MAP for a short? Maybe the MAP itself is bad.
P0106 Manifold abosolute pressure (MAP) sensor/barometric pressure (BARO) sensor – range/performance problem Intake/exhaust leak, wiring, MAP sensor, BARO sensor
1 - 16 of 16 Posts
