If I turn my lights on in my coupe the hid on the drivers side comes on ..but not on the passenger side.
If I shut the lights off and snap them back on the passenger hid will come on for a second and go out. A third attempt and the same results. Finally on the 4th attempt of shutting the lights on and off...it will stay on and work properly. Once they have been on for a few minutes, I can shut my lights off and then back on without a problem. Is this a bad ballist or switch?
Thanks
Try taking the ballast from the driver side and switch it with the passenger side. If the problem changes to the driver side now, then your ballast is bad. If the problem stays, could be a loose connection maybe if you already ruled out bulbs.
