have you, or anyone, tried that 2nd part of the first dot where it says *Notice under the "disarmed stage" section?
I already called service this morning and they have no knowledge on how to disarm the alarm system without the remote... completely uselesshave you, or anyone, tried that 2nd part of the first dot where it says *Notice under the "disarmed stage" section?
Havoc, read the info you posted. It says in the notice:have you, or anyone, tried that 2nd part of the first dot where it says *Notice under the "disarmed stage" section?
Avoid trying to start the engine while the alarm is activated. The vehicle starter motor is disabled during the theft-alarm stage.
If the system is not disarmed with the transmitter, insert the key into the ignition switch, turn the ignition switch to the ON position and wait 30 seconds. Then, the system will be disarmed.
So, use the key or the valet/service key to unlock it. The alarm goes off. You get in, put the key in, turn it to the ON position and give it 30 seconds. Alarm should go off. You then turn off and then start the car normally. That's how I read that.
