1 - 19 of 19 Posts
Quite a bit. It depends on year and model too. If you go to
https://www.hyundaitechinfo.com/
You need to use IE 32 bit, set up an account, allow popups, and have the Adobe SVG viewer installed to view the pictures.
Using the 2L and 2012 as an example there are two pages of drawings that show the inputs and outputs.
Look under the EMT manual>GENESIS COUPE(BK) >2012 > G 2.0 T-MPI > Body Control Module (BCM) System > Schematic Diagrams
Discussion Starter · #14 ·
Bcm is not the problem, found out toda that the plug just behind and under headlight assembly the cap was removed and never put back on, the cap has metal inside it purposely shorting out certain terminals, compared to right side and cap was there
Anybody know of a salvage yard in the orlando area that has a coupe in their yard?
Beware as there are several different part numbers depending on the model trim for the 2010 year. Best to be sure of the part number on the one you have.
2010 Genesis Coupe BCMs
954002M500 UNIT ASSEMBLY - BCM
5AT 2WD (SHIFT LOCK SYSTEM - ELECTRONIC TYPE, IGN. KEY INTER LOCK SYS-ELECTRONIC TYPE, SMART KEY-FR DR) .
6AT 2WD (SHIFT LOCK SYSTEM - ELECTRONIC TYPE, IGN. KEY INTER LOCK SYS-ELECTRONIC TYPE, SMART KEY-FR DR) . $131.48
954002M501 UNIT ASSEMBLY - BCM
(AUTO - 5 SPEED 2WD) (SHIFT LOCK SYSTEM - ELECTRONIC TYPE, IGN. KEY INTER LOCK SYS-ELECTRONIC TYPE, SMART KEY-FR DR). $131.48
954002M510 UNIT ASSEMBLY - BCM
6MT 2WD (SMART KEY-FR DR) . $131.48
954002M511 UNIT ASSEMBLY - BCM
(MANUAL T/M-6SPEED2WD) (SMART KEY-FR DR). $131.48
954002M520 UNIT ASSEMBLY - BCM
5AT 2WD (SHIFT LOCK SYSTEM - ELECTRONIC TYPE, IGN. KEY INTER LOCK SYS-ELECTRONIC TYPE)
6AT 2WD (SHIFT LOCK SYSTEM - ELECTRONIC TYPE, IGN. KEY INTER LOCK SYS-ELECTRONIC TYPE) $193.48
954002M521 UNIT ASSEMBLY - BCM
(AUTO - 6 SPEED 2WD) (SHIFT LOCK SYSTEM - ELECTRONIC TYPE, IGN. KEY INTER LOCK SYS-ELECTRONIC TYPE). $193.48
954002M530 UNIT ASSEMBLY - BCM
6MT 2WD . $193.48
954002M531 UNIT ASSEMBLY - BCM
(MANUAL T/M-6SPEED2WD). $193.48
Gooood! GOOOOOD!
Best to check fuses next time this happens.
6MT 2WD . $193.48
Why my BCM part no is not included here?
95400 2M221?
1 - 19 of 19 Posts
