Belt Squeaky
10329 Views 24 Replies 10 Participants Last post by  Moley
When I first start my car in the morning after a cold night ( -5 or lower ) the belt will make a squeaking noise ( at least I think it is the belt ) for about 30 seconds or so. I don't think anything major is wrong but it is worrisome and annoying. I took it in to have it checked out and Hyundai said there is nothing wrong and it's normal for that sound to be heard on a cold start. Somehow I don't think so. Anyone know what's going on?
1 - 20 of 25 Posts
Go to an auto part store and ask for belt dressing, spray it on the pulleys and the belt serp belt.
I never thought of that. Worth a try I guess assuming it's the belt making the noise. Thanks. I just can't see why a car with only 18,000km on it would make such a weird sound on startup. Hmmm.
I have the same thing going on. It's just condensation on the smooth surface of the belt because of the cold weather. This happened to me last winter(when my car was new) as well as this year. No squeaking during other seasons. So it's normal.
This makes sense and I hope that's all it is. I am curious to know though just how cold it gets in Muharraq, Bahrain for you to have this same issue.
This winter, the weather went as low as 12 degrees centigrade(don't know how much is that in fahrenheit). But we get 80-95% humidity almost on a daily basis.
I know this may not be a problem right now but also by keeping your engine bay clean, it will help with belt and pully noises...I once owned a pontiac sunfire 2004 up intill about a year ago and never had a probelm with extra noises coming from the engine bay.
Don't apply belt dressing as it is only a temporary fix & will cause the belt to squeal even more after a while. You need to adjust your belt properly to alleviate the squeal & adjustments are covered 12 months/12k miles. If you are within those limits, you can drop your car off with Hyundai svc the night before so that they can do a cold start & duplcate the concern & thus fix it. If you are past 12 months & 12k miles, adjust yourself according to Hyundai Service website using the tensioner. We charge 1/2 labor of adjusting belt = $45.50.
They did try it on a cold start and they did hear the noise. They checked the belt and said it was fine. Hmmmm....
I did look up belt dressing after that post and I would agree to not use it unless absolutely necessary. Funny how you mention the warranty being 12months/12k miles for adjustment. I have had it more than a year and Hyundai didn't charge me anything. They are nice people at my dealership.:) They also fixed my airbag light problem and then vacumed and washed the car. That is all fine and dandy but my belt still squeaks.:(
I wonder what they meant by "checked the belt" if they didn't pull the belt off an inspect it, they didn't really check it. i'd guess that spend 8 seconds looking for cracks on one part of the belt and found nothing.
I live closer to the coast, but have had very similar temperatures as you, and no belt squeal. i work at a shop, and every belt noise we have come in, (and can hear) we can fix. either belt, pulley or tensiooner, there's something wrong.
keep trying, and if no luck, try the next dealer. aren't there 3 different places between penticton and vernon?
hope you get it fixed, no new car should have that noise!
That's it? We can get to -20c at times. I looked up where you live and I was curious as to how cold it got there. I don't think you have belt issues because of the cold but the humidity might be a different story. 80-95% is crazy high so condensation might be a factor. I am not a mechanic but I think that is a fair assessment. The humidity here in the winter is about 70-80% so I don't think thats it for me. IDK. I just want it to stop.
Ya, they definitely did not take off the belt. They did say they checked the tension though. IDK but they said it's normal which is BULLSHIT! I think I should take it to a different dealer like you said or just keep complaining to the one I take it to now. The closest would be Vernon. (crap hole that it is) I am thinking it is for sure from the cold but why? What do you think? It goes squeak squeak in intervals and not one solid squeal till the belt gets going. Almost sounds like it does it till the oil starts to flow so mabye it's not the belt. How long does it take for oil to start flowing on a cold morning? Sorry for all the questions. I hope that's ok. (take advantage of a guy that works in a shop why don't I):D
well to test your oil theory you could change your current stuff with a 0w30 synthetic, it will flow better and faster than whatever you have in there now. I doubt that's the problem though. for arguments sake though, what oil are you running? haha
I've seen belts (more likely a pulley) pick up strange things and make belt noises, or shred belts. faulty tensioners can make noise, but you mentioned a squeak squeak as apposed to a solid howl which usually comes from a loose belt. something like an AC compressor or alternator or PS pump going bad can make that noise as well.
I did actually have a belt squeal one morning, but later that night the power steering pump blew up, so I think that was from the PS fluid leaking onto my belt!
you could check for small leaks, or anything that doesn't look right.
where abouts are you?
I'm using the oil that is on the cap I guess (5w20) as long as that's what the dudes at the shop put in last time I got it changed. You figure I should try 0w30 huh. I don't think I will just change the oil on a whim but then again it could just be it. But I suspect a pully too. I hope it's not the alternator cause I max that sucker out all the time with my stereo. Don't freak me out like that.:woah:
Sorry about what happened with your steering pump....that sucks.:(
I am in K-town and I can't wait for summer! Chicks Chicks and more Chicks!:D:D:D:D
after seeing your post in the audio forum, I can say that your alternator could very well be the problem hahaha.
compare how many amps the hifonics pulls to what the alternator puts out.
Have you beefed up the electrical system in any way other than the wiring?
and go answer my post in the audio thread!
Haha better not be. I have done the big 3 with 0 gauge but that is it. They don't make high output alts for this car yet. The Hifonics pulls 200 amps and the stock alt does 110. I don't run my amp to full potential at all. If I did the alt would surely be done by now.
I did think of another thing that came up this week. not exactly the same, but I had put new belts on a mazda protege a month ago,and she came back saying they were squealing. Pretty normal for belts to stretch, and this wasn't the type with an auto tensioner, so I tightened the belts up. seemed fine at first, but with the heater on, i heard the belt squeal!
I double checked the belts and they were both tight, clean, in line etc. it turned out she had a bad alternator. still putting out amperage and charging the battery, but when we turned on the blower motor, it started to howl.
she had to leave, but a new alternator will fix her squeal.
It is a different story, this one loud from age, and at any temperature, after start up etc, but it's something that could have happened :(
i wonder if you unplugged the 'plug' from the alternator if you'd still have the squeal. (temporarily)
Stop freaking me out!
I think I might try the unplug thing though.
Weird.....I fired it up this morning and no squeak. It was -10c. I hope it stays that way.
1 - 20 of 25 Posts
