1 - 3 of 3 Posts
Hi guys. New Genesis Coupe owner here. I was thinking about getting a catch can to put in. I see A lot of 2.0 turbo guys doing two. Will the 3.8 L only need one and if so where would the one be placed? Sorry if this conversation has been brought up before. Thank you in advance!
I put one in my 3.8 last year, I meant to do it sooner but you know how that goes.
On the V6 you only need one on the passenger side (pcv), I mounted mine on the firewall where the sound tube from the stock intake was located.
If you are a 3.8 NA BK1or BK 2 you can use two. The passenger side on runs on the vac line coming from the PCV valve and going to the side of the plenum. This OCC must be of the sealed variety. This is the one which will accumulate gunk over time. The second line on the driver side formerly would go to the intake to recycle or burn. This OCC may have a bleeder filter on top. Being a NA you will not have much accumulation in this one. Turbos especially tuned high boost will have accumulation.
1 - 3 of 3 Posts
