Is all this work really worth having brembos ??
  • YES
    Votes: 1 20.0%
  • NO
    Votes: 1 20.0%
  • Fukk it its brembos you need them
    Votes: 3 60.0%
  • coulda done other stuff like a tune
    Votes: 0 0.0%
  • Total voters
    5
1 - 19 of 19 Posts
Alrighty i was needing to do my brakes on my BK2 2.0T so i said screw it ill pull the trigger and do the brembos i've wanted to do.
So my plan was to either get drilled/slotted rotors from R1 Concepts, and get either ebc pads or whatever else i wanted.
Cost for R1 concepts Drilled/slotted rotors for base model was roughly $300 with tax.
EBC (Yellow/Red) Front & rear $300-400
Total for base brake job was going into the $700 range.
Used RR+ RL Brembo off ebay $200.00 shipped
Used FR+FL Brembo off car-part.com $275 shipped
(2) Carlson 41260 Rear seal rebuild kits for rear brembos $13 shipped
(4) update as of 5/13/20 Carlson 15348 Front seal rebuild kit for brembos $13 shipped
Centric smaller Replacement Piston for rear brembo Carlson 14628003 $7.50 Shipped
Centric larger Replacement Piston for rear brembo Carlson 14632009 $10.50 Shipped
Re Powder coating locally $80 per caliper
Stoptech SS braided lines Rear 950.51501 $46 off amazon
Stoptech SS braided lines Front 950.51001 $50 off amazon
Durago BR900796 + BR900798 Front + Rear Brembo rotors off rockauto $103
Centric 500.10010 + 500. 0531 Ceramic low dust pads $77 off rockauto front pads don’t come with hardware that’s another $15 rockauto refunded me the cost of the hardware
(8) Brake Bleeders M10 x 1.0 29mm long from Orielly auto parts h-9740-2
Brake assembly fluid off eBay
its alot but you know what they are gonna look phenomenal.
Rear calipers were dropped off at powder coating 5/1/20 1-2 week turn around, the fronts are coming 5/8/2020 to get dropped off 5/11/2020 1-2 week turn around. I have before photos i shall post it all once i get it back.
Discussion Starter #8
The fronts just got dropped off this week to powder coat and I have everything to rebuild them now including the fact I needed 4 rebuild kits for the front calipers. Each package does one side within the caliper ... had a brain fart lol
Discussion Starter #10
I just got the fronts back from powder coat I will attempt to rebuild them this weekend I shall post photos of the before and after Powder coat
Discussion Starter #12 (Edited)
75721
75724
little before and after for the fronts I have the Brembo decal to be installed after I rebuild them new pistons and seals. And I plan to do it the smart way with the brake caliper assembly fluid not brake fluid.
Discussion Starter #13 (Edited)
75722
Before and after of the rears. The powder coating company out of Milford, ct was phenomenal and it was a week turn around time !!
75725
Discussion Starter #17
Just an update i tossed the rockauto rebuild kits for the rear which were carlson 41260 and got the brakebest 41260 kit from oreillys any they make a difference. the outer edge is beveled which the carlson ones lack.
The carlson kit is to the left the orielly is on the right. it made a world of a difference. Also when installing these lube the piston up with brake assembly fluid i used mckay got it off ebay for $10. These seals you don't need to put the assembly fluid on. Lube the sides and bottom of the piston and slide it in only after the inner seals are lubed up and installed also by the way. Put the piston in 3/4 the way down then you slide the seal pictured over it and it slides right in the groove.
Discussion Starter #18
Here is the finished product. I made a youtube video on the how to rebuild these Brembos specifically and made a video of me placing the decal onto the caliper.
Decal Install Video Youtube Link-- >>
Rebuild Video Youtube Link -->>>
1 - 19 of 19 Posts
